New emulator - BuLWiP
PeteE
Posted (edited)
15 hours ago, mr_gw454 said:
I did try to compile this on my Linux Mint 20.1 system but ran into an error:
Looks like it might be related to my version of SDL2? 2.0.10.
Yes, SDL_LockTextureToSurface was added in 2.0.12.  I think I can avoid calling that function.
19 hours ago, TheMole said:
Here's an example cart image and the output from objdump with (some) C code interspersed... For some reason there's large swaths of asm code without C code, but that's probably because I'm including a library that hasn't been compiled/built with the right C flags. Should still work for testing if this type of list format can be made to work with you debugger though...
Oh, and the program itself assumes 80 column text mode on an F18A, so won't run correctly in the emulator... I hope that's not an issue for you. I just picked a small-ish project I had lying around.
Looks like the listing parser handled it okay.  When the function loads a listing it prints out the segments that it found:
load listing test/malloctest8.lst
list 0-555 pc=6000-6014 bank -1
list 555-55886 pc=2080-2fce bank -1
list 55886-121015 pc=6f6a-7c50 bank 0
The list shows the file offset range and the program counter address range, as well as the assumed bank.  Bank -1 means all banks.  To detect the bank number in GCC listings, it looks for the text "Disassembly of section .bank" followed by the bank number.  I think you have to set this name in your linker script, like this (taken from fcmd)  You probably know about banking in GCC better than I do.
  /* overlays */
  OVERLAY : AT (0x10000)
    .bank0 {             /* list the set of modules in bank 0 */
      objects/api.o(.text)
      objects/b0_*.o(.text)
      __LOAD_DATA = .;   /* .data segment is appended here by makefile for final ROM .bin */
    .bank15 { objects/b15_*.o(.text) }
    .bank14 { objects/b14_*.o(.text) }
    .bank13 { objects/b13_*.o(.text) }
    .bank12 { objects/b12_*.o(.text) }
    .bank11 { objects/b11_*.o(.text) }
    .bank10 { objects/b10_*.o(.text) }
    .bank9 { objects/b9_*.o(.text) }
    .bank8 { objects/b8_*.o(.text) }
    .bank7 { objects/b7_*.o(.text) }
    .bank6 { objects/b6_*.o(.text) }
    .bank5 { objects/b5_*.o(.text) }
    .bank4 { objects/b4_*.o(.text) }
    .bank3 { objects/b3_*.o(.text) }
    .bank2 { objects/b2_*.o(.text) }
    .bank1 { objects/b1_*.o(.text) }
  } >bank_rom
13 hours ago, apersson850 said:
Like this?
Exactly!
Edited by PeteE
Posted (edited)
I pushed some changes to the github repo. The alternate debug key is F12. Use Shift-Insert to paste from the clipboard. Find keys are added. The SDL functions should work on SDL 2.0.10, as well as fixed the CRT filter on Mac, and also added 80-column text mode just for fun.
EDIT: Also fixes the bug with XB.  I forgot the post increment on CB instruction.
Edited by PeteE
I just pulled the latest updates and it now compiles for me (including the Raspberry Pi (ARM).
Thank you very much for making that SDL LockTextureToSurface change.
  • 2 weeks later...
4 hours ago, PeteE said:
Thanks, I'll take a look.  The music player decrements a counter to delay between notes.  Seems like I need to finish checking the instruction cycle timing.
Wonder if that's why Donkey Kong is so fast too.. probably
Found the bug: expansion RAM accesses are not adding their cycle time (2 cycles + 4 for the multiplexer), so they're effectively faster than scratchpad RAM.  Whoops.
  • Like 5
  • 4 weeks later...
I checked in the instruction cycle count fixes, at least for the instructions I care about.  If there's others, I don't want to know about it.  I made an automated test using XAS99 to generate various combinations of instructions with normal or multiplexed memory addresses, and used the "s+","s-","d+","d-" memory access speed annotations so that the cycle counts in the listing were accurate.  My test harness loads the binary, single steps through it sequentially, and compares the cycles executed to that instruction in the listing.
