masteries Posted March 4, 2023 Share Posted March 4, 2023 #### What is it? This is a small daughter board that fits into the socket of the "Sally" custom CPU in the Atari 800XL, 65XE and 130XE microcomputers (the RF shield must be removed, otherwise the daugher board won't fit inside). It replaces that CPU with a CMOS, modern, low-power, fully static, currently in production W65C02S CPU and some auxiliary logic.*The package contains the auxiliary logic chips, the capacitors, the resistances, 40 pin strip and the 4 layer board. Suitable W65C02S CPU is not included, you must search for one these, as recommendation, from trusted distributors.#### Why did you make it? Originally I manufactured these to repair two Atari XL computers; once the repair is completed, a set of materials remained, and these can be useful for another users.#### What makes it special? Obtain a Sally CPU is hard these times, with this daughter board you can replace a damaged Sally CPU using a W65C02S CPU that is more easy to find, as well more cheap. -------------------------------------------------------- Price is 10€ fon non assembled units (there are 9 of these), assembled unit cost 16€ (there is a single one), remember that the*The package contains the auxiliary logic chips, the capacitors, the resistances, 40 pin strip and the 4 layer board. Suitable W65C02S CPU is not included, you must search for one these, as recommendation, from trusted distributors. Tracked shipment 7.6€ for Europe, 8.20€ for America, 9€ Australia - Japan - New Zealand Quote Link to comment Share on other sites More sharing options...
