derek.john.evans Posted March 20, 2023 Share Posted March 20, 2023 (edited) Benchmarking Atari ST BASIC's The BASIC's tested are Hisoft BASIC, STOS, Omikron & GFA I wanted to know which BASIC would be best for coding simple block based games. The benchmark test is: Define an array of 40x25 integers Fill the array with random colours (0-15) Draw the array via the builtin rectfill procedures using color from map Each block is to be 7x7 in size and spaced 8x8 pixels so a screen of 320x200 pixels is covered in coloured blocks Repeat 10 times The test is designed to see how suitable each BASIC would be for programs like Snake, Tetri$, Breakout, Pong, Game of Life, etc. The same method can also be used for board games like Chess, Checkers, and RPG games. In which case, rectangle fill's can be replaced with image blitting. Obviously, for each game type, you could optimize by using a "draw as you go" method, or record "dirty cells/cols/rows" to prevent overdraw. All the BASIC's tested support integrating machine code and each supply a variety of extra graphics functions for various purposes. I hope you find the test interesting. I coded these because I spent a few months coding in Hisoft BASIC, only to end up with less than Stella results. The test is not designed to compare BASIC to C, Pascal, etc. BASIC has some very attractive attributes if you want to work on a 520ST/Floppy system. BENCHMARK RESULTS (LOWER IS BETTER) All* Tests were made under TOS 2.06 without any ACC's or screen accelerators. Machine was a 520ST/E, except for Hisoft BASIC which required a 1040ST * Omikron BASIC 2.2 failed to run on TOS 2.06, therefore the interpreter test was done under 1.0. The resulting compiled version runs on TOS 2.06 OMIKRON BASIC 2.2 Interpreted: 48 Secs (TOS1.0) / Compiled: 41 Secs (TOS1.0) / Compiled: 28 Secs (TOS 2.06) OMIKRON BASIC 3.01 Interpreted: 24 Secs / Compiled: 17 Secs GFA BASIC 2.0 Interpreted: 44 Secs / Compiled: NA GFA BASIC 3.6 Interpreted: 39 Secs / Compiled: 26 Secs STOS 2.6 Interpreted: 278 Secs / Compiled: About the same. PRG Crashed Hisoft BASIC 2.10 Interpreted: NA / Compiled: 44 Secs CONCLUSION The clear winner is Omikron BASIC 3.01, which recorded an interpreted speed faster than GFA 3.6's compiled speed. While GFA speed improved from 2.x to 3.x, the improvement only barely beats Omikron BASIC 2.2 from 1986 I was expecting good things from Hisoft BASIC, but its speed is a clear 3rd place. Hisoft BASIC was woefully slow to compile and requires more RAM and screen space to accommodate its GEM interface. That said, Hisoft BASIC is the most advanced BASIC on the Atari ST and provides a fantastic experience when run in an emulator. And STOS.... Well, what can I say? 278 seconds is a rotten result. I was able to compile the program, but the speed wasn't that much better. The PRG crashed during testing, and I'm not overly interested to find out why. That said, STOS has been shown to work well, if you stick to using its builtin sprite engine. FINAL WORD Personally I love all this old software. While it's great to work with more modern software, the question is then, where do you stop? Do you limit yourself to 1992 versions, 1995? 2000? So, I'll be using Omikron BASIC. They all have faults, and really, 30+ years on, does it matter? Cheers Source and some PRG's are available here: https://sourceforge.net/p/atari-st-basic-benchmarks/code/HEAD/tree/ ' GFA BASIC VERSION Map_x%=39 Map_y%=24 Dim Map%(Map_x%,Map_y%) Cls Ti=Timer For Z%=1 To 10 For X%=0 To Map_x% For Y%=0 To Map_y% Map%(X%,Y%)=Random(15) Next Y% Next X% For X%=0 To Map_x% For Y%=0 To Map_y% Deffill Map%(X%,Y%) Xx%=X%*8 Yy%=Y%*8 Pbox Xx%,Yy%,Xx%+6,Yy%+6 Next Y% Next X% Next Z% Cls Print Timer-Ti Input A$ Edited March 20, 2023 by derek.john.evans Spelling 5 1 Quote Link to comment Share on other sites More sharing options...
derek.john.evans Posted March 20, 2023 Author Share Posted March 20, 2023 (edited) EXTRA INFORMATION To compare Omikron's 17 second result to a theoretical max-speed, I tried my old favorite language Hispeed Pascal 1.5. I used the graph unit since it provides an easy way to fill rectangles without starting up a GEM app. The result was 14 seconds, which i'm pretty sure would be close to the max. ie: the bottle neck would be GEM's fill rectangle code. As with Hisoft BASIC, HSPASCAL required a 1 meg machine to compile. So, there you have it. While Omikron is "predictably" slower than HSPASCAL, its not by much. In fact, I only achieved 14 seconds after switching off range and stack checking. Something I'm unsure the Omikron compiler supports. With range checking, HSPASCAL returns a 16 second result. I'm actually really impressed by Omikron's code generation. So, summing up.... If you want to relax on a 520ST/Floppy system, coding like its 1987 and let the annoying buzz of 2023 fade into the background, I highly recommend you try out Omikron BASIC 3.01+. Cheers fellow coders {$r-} {$s-} uses graph, bios; const map_x=39; map_y=24; var gd, gm: integer; map: array [0..map_x, 0..map_y] of integer; x, y, z, xx, yy: integer; ti: longint; begin initgraph(gd, gm, ''); ti := xgettime; for z := 1 to 10 do begin for x := 0 to map_x do begin for y := 0 to map_y do begin map[x, y] := random(15); end; end; for x := 0 to map_x do begin for y := 0 to map_y do begin xx := x * 8; yy := y * 8; setfillstyle(solidfill, map[x, y]); bar(xx, yy, xx+6, yy+6); end; end; end; clrscr; writeln(xgettime - ti); readln; closegraph; end. Edited March 20, 2023 by derek.john.evans 2 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted March 24, 2023 Share Posted March 24, 2023 Is Omikron still supported and updated? GFA Basic is and that might be a factor to consider in any decision... 1 Quote Link to comment Share on other sites More sharing options...
zzip Posted March 24, 2023 Share Posted March 24, 2023 Hard to believe STOS performs so poorly. STOS games always seemed to perform better than GFA games Maybe a wider variety of benchmarks should be tried? Quote Link to comment Share on other sites More sharing options...
derek.john.evans Posted March 24, 2023 Author Share Posted March 24, 2023 (edited) 21 hours ago, zzip said: Hard to believe STOS performs so poorly. STOS games always seemed to perform better than GFA game Maybe a wider variety of benchmarks should be tried? STOS has a sprite engine with auto-movement. so, it can appear to be preforming better. The benchmark was designed for the specific games I listed. eg: Tetris: As you can see from the Omicron code below, there are a lot of 2D table look ups. And everything is rendered using filled rectangles. STOS is great, but I prefer to have access to procedures, functions and a better compiler. 4-Tetris 5 6 Game_Init 7 8 WHILE 1 9 Game_Play 10 WEND 11 12 END 13 14 DEF FN Shape_Point(X,Y) 15 LOCAL Z=Shape_Size(Shape) 16 IF Shape_R=0 THEN A=Shape(Shape,X,Y) 17 IF Shape_R=1 THEN A=Shape(Shape,Y,Z-X) 18 IF Shape_R=2 THEN A=Shape(Shape,Z-X,Z-Y) 19 IF Shape_R=3 THEN A=Shape(Shape,Z-Y,X) 20 RETURN A 21 22 DEF FN Shape_Collide 23 LOCAL Result=0,X,Y,Z=Shape_Size(Shape) 24 FOR Y=0 TO Z 25 FOR X=0 TO Z 26 Result=FN Shape_Point(X,Y)<>0 AND Map_Colors(Shape_X+X,Shape_Y+Y)<>0 27 IF Result THEN EXIT 28 NEXT 29 IF Result THEN EXIT 30 NEXT 31 RETURN Result 32 33 DEF PROC Shape_Hide 34 LOCAL X,Y,Z=Shape_Size(Shape) 35 FOR Y=0 TO Z: FOR X=0 TO Z 36 IF FN Shape_Point(X,Y) THEN 37 PROC Map_Color(Shape_X+X,Shape_Y+Y,0) 38 ENDIF 39 NEXT : NEXT 40 RETURN 41 42 DEF PROC Shape_Show 43 LOCAL C,X,Y,Z=Shape_Size(Shape) 44 FOR Y=0 TO Z: FOR X=0 TO Z 45 C=FN Shape_Point(X,Y) 46 IF C THEN PROC Map_Color(Shape_X+X,Shape_Y+Y,C) 47 NEXT : NEXT 48 RETURN 49 50 DEF PROC Shape_Play 51 Shape_Show 52 Shape_Timeout= TIMER +Game_Delay 53 REPEAT 54 Game_Draw 55 IF TIMER >Shape_Timeout THEN 56 Shape_Timeout= TIMER +Shape_Delay 57 Shape_Hide:Shape_Y=Shape_Y+1 58 IF FN Shape_Collide THEN 59 Shape_Y=Shape_Y-1 60 Shape_Show 61 Game_Collaspe 62 EXIT 63 ENDIF 64 Shape_Show 65 ENDIF 66 K$= INKEY$ 67 IF LEN(K$)=4 THEN 68 K= CVIL(K$) 69 IF K=$500000 THEN Shape_Delay=5 70 IF K=$390020 THEN 71 Shape_Hide:Shape_R=(Shape_R+1) AND 3 72 IF FN Shape_Collide THEN Shape_R=(Shape_R-1) AND 3 73 Shape_Show 74 ENDIF 75 IF K=$4B0000 THEN 76 Shape_Hide:Shape_X=Shape_X-1 77 IF FN Shape_Collide THEN Shape_X=Shape_X+1 78 Shape_Show 79 ENDIF 80 IF K=$4D0000 THEN 81 Shape_Hide:Shape_X=Shape_X+1 82 IF FN Shape_Collide THEN Shape_X=Shape_X-1 83 Shape_Show 84 ENDIF 85 ENDIF 86 UNTIL MID$(K$,4)="a" 87 RETURN 88 89 DEF PROC Map_Color(X,Y,C) 90 IF Map_Colors(X,Y)<>C THEN 91 Map_Colors(X,Y)=C 92 Map_Change(0,Y)=-1 93 Map_Change(X,Y)=-1 94 ENDIF 95 RETURN 96 97 DEF PROC Game_Init 98 LOCAL I,X,Y 99 100 CLS 101 PRINT CHR$(27);"f" 102 103 'PALETTE 0,$700,$70,$770,$7,$707,$77,$444,$222,$200,$20,$220,$2,$202,$22,$777 104 PALETTE 0,$700,$70,$770,$7,$707,$77,$444,$222,$730,$20,$220,$2,$202,$22,$777 105 'OUTLINE OFF 106 107 LINE COLOR =4 108 BOX 0,0,319,199 109 LINE COLOR =8 110 BOX 1,1,317,197 111 112 Map_X=14:Map_Y=26 113 DIM Map_Colors(Map_X,Map_Y),Map_Change(Map_X,Map_Y) 114 115 READ Shape_Max 116 DIM Shape(Shape_Max,3,3),Shape_Size(Shape_Max) 117 118 FOR I=0 TO Shape_Max 119 READ Shape_Size(I) 120 FOR Y=0 TO Shape_Size(I): FOR X=0 TO Shape_Size(I) 121 READ Shape(I,X,Y) 122 NEXT : NEXT 123 NEXT 124 RETURN 125 126 DEF PROC Game_Clear 127 LOCAL X,Y 128 FOR Y=0 TO Map_Y: FOR X=1 TO Map_X 129 IF X<3 OR X>Map_X-2 OR Y>Map_Y-2 THEN 130 PROC Map_Color(X,Y,9) 131 ELSE 132 PROC Map_Color(X,Y,0) 133 ENDIF 134 NEXT : NEXT 135 RETURN 136 137 DEF PROC Game_Draw 138 LOCAL X,Y 139 FOR Y=1 TO Map_Y: IF Map_Change(0,Y) THEN 140 Map_Change(0,Y)=0 141 FOR X=1 TO Map_X: IF Map_Change(X,Y) THEN 142 Map_Change(X,Y)=0 143 FILL COLOR =Map_Colors(X,Y) 144 PBOX X*7,Y*7,6,6 145 ENDIF : NEXT 146 ENDIF : NEXT 147 RETURN 148 149 DEF PROC Game_Collaspe 150 LOCAL X,Y,Z,Gap 151 FOR Y=Map_Y-2 TO 0 STEP -1 152 Gap=0 153 FOR X=3 TO Map_X-2 154 IF Map_Colors(X,Y)=0 THEN Gap=-1: EXIT 155 NEXT 156 IF NOT Gap THEN 157 FOR X=3 TO Map_X-2: PROC Map_Color(X,Y,1): NEXT 158 Game_Draw 159 FOR X=3 TO Map_X-2: PROC Map_Color(X,Y,0): NEXT 160 Game_Draw 161 FOR Z=Y TO 1 STEP -1: FOR X=3 TO Map_X-2 162 PROC Map_Color(X,Z,Map_Colors(X,Z-1)) 163 NEXT : NEXT 164 Game_Draw 165 Y=Y+1 166 ENDIF 167 NEXT 168 RETURN 169 170 DEF PROC Game_Score(A) 171 IF Game_Score<>A THEN 172 Game_Score=A 173 A$= MID$( STR$(A),2) 174 PRINT @(1,16);"PLAYER" 175 PRINT @(2,16); STRING$(6- LEN(A$),"0")+A$; 176 ENDIF 177 RETURN 178 179 DEF PROC Game_Play 180 Game_Delay=50 181 Game_Score 10 182 Game_Clear 183 WHILE 1 184 Shape= RND(Shape_Max+1) 185 Shape_X=6:Shape_Y=0:Shape_R=0 186 Shape_Delay=Game_Delay 187 IF FN Shape_Collide THEN EXIT 188 Shape_Play 189 WEND 190 RETURN 191 192 DATA 6 193 DATA 1,6,6,6,6 194 DATA 2,0,10,0,0,10,0,0,10,10 195 DATA 2,0,4,0,0,4,0,4,4,0 196 DATA 2,0,7,0,7,7,7,0,0,0 197 DATA 2,0,3,3,3,3,0,0,0,0 198 DATA 2,2,2,0,0,2,2,0,0,0 199 DATA 3,0,0,5,0,0,0,5,0,0,0,5,0,0,0,5,0 Edited March 25, 2023 by derek.john.evans spelling Quote Link to comment Share on other sites More sharing options...
derek.john.evans Posted March 24, 2023 Author Share Posted March 24, 2023 2 hours ago, DarkLord said: Is Omikron still supported and updated? GFA Basic is and that might be a factor to consider in any decision... True. I really really tried to give GFA Basic a chance. But, I really need pointer to functions. 1 Quote Link to comment Share on other sites More sharing options...
lp060 Posted April 9, 2023 Share Posted April 9, 2023 (edited) In GFA random() returns a float which causes extra internal conversion, use rand() for an integer. http://gfabasic.net/stg/gfabasic.htm#RAND This bit of code is not seconds, it's 200th of a second: ti=TIMER ' do some stuff PRINT timer-ti Correct way to get seconds: ti%=TIMER !returns a long ' do some stuff PRINT (TIMER-ti%)/200 http://gfabasic.net/stg/gfabasic.htm#TIMER If you don't need GEM, typical for a game, ARECT will outperform PBOX. http://gfabasic.net/stg/gfabasic.htm#ARECT All coordinates are in word range, perhaps word variables will impact the speed. I can only conclude you didn't read that manual. The test is flawed. I'm not an expert at the other languages, but if this is how you conduct tests perhaps all of them are inconclusive. FYI, GBE supports pointers to procedures with some limits. Edited April 9, 2023 by lp060 typo Quote Link to comment Share on other sites More sharing options...
derek.john.evans Posted April 9, 2023 Author Share Posted April 9, 2023 (edited) RE: Timer. Yes, all results were converted to seconds by hand. Otherwise I would have been posting numbers like 7764 seconds... RE: Rand() vs Random(). The doc's do state "Random() produces a random integer between 0 and x". That said, Rand() is slightly faster, and dropped the GFA result by 1 second. RE: 16bit vs 32bit. I tried both, and didn't notice any change in speed. RE: ARECT vs PBOX. yes, you are absolutely right. The LineA ARECT command is significantly faster than PBOX. So much so, the GFA time dropped to 5 seconds. Omikron doesn't have builtin LINEA commands, but, after I added some, Omikron dropped to 6 seconds. I've attached the PRG's below. RE: inconclusive? I would say the test is valid. I stated in my first post: "All the BASIC's tested support integrating machine code and each supply a variety of extra graphics functions for various purposes." ie: I am well aware there are various optimizations options for each language. All source code is provided. GFA3.PRG OMIKRON.PRG Edited April 9, 2023 by derek.john.evans Quote Link to comment Share on other sites More sharing options...
lp060 Posted April 9, 2023 Share Posted April 9, 2023 (edited) 1 hour ago, derek.john.evans said: RE: Timer. Yes, all results were converted to seconds by hand. Otherwise I would have been posting numbers like 7764 seconds... RE: Rand() vs Random(). The doc's do state "Random() produces a random integer between 0 and x". That said, Rand() is slightly faster, and dropped the GFA result by 1 second. RE: 16bit vs 32bit. I tried both, and didn't notice any change in speed. RE: ARECT vs PBOX. yes, you are absolutely right. The LineA ARECT command is significantly faster than PBOX. So much so, the GFA time dropped to 5 seconds. Omikron doesn't have builtin LINEA commands, but, after I added some, Omikron dropped to 6 seconds. I've attached the PRG's below. RE: inconclusive? I would say the test is valid. I stated in my first post: "All the BASIC's tested support integrating machine code and each supply a variety of extra graphics functions for various purposes." ie: I am well aware there are various optimizations options for each language. All source code is provided. The gfa manual is notorious for inaccuracies and typos. I don't have a vintage 520st. That said the gfa build runs on my 040 setup, the omikron build freezes it. Omikron is plagued with lots of other problems, if it don't run the speed means nothing. I fully agree STOS isn't great if one is used to a structured language, but there's lots of extensions that push it beyond it's default abilities. Edited April 9, 2023 by lp060 typo Quote Link to comment Share on other sites More sharing options...
derek.john.evans Posted April 10, 2023 Author Share Posted April 10, 2023 (edited) RE: That said the gfa build runs on my 040 setup, the omikron build freezes it. Omikron is plagued with lots of other problems, Maybe, maybe not. My Omikron LINEA code just used some pokes and inline "A005". Which worked fine on ST's. Dont blame Omikron for that. I have a feeling I need to add some register push/pulls for TOS 4+ I did avoid LINEA calls for this reason. I really am not overly fussed by what language I use. Personally I prefer C & Pascal. But, Im putting together some code for simple games using software from 1988, so that rules out Pure C/Highspeed Pascal and Pure Pascal. As far as Falcon support, (Aranym for me), I have had the least problems with Omikron 5. (Other than trying to read German/French manuals) Anyway, this test is one of ~4 which I've been running. The others include line, blit and GEM development. I'll always consider GFA, but so far Omikron has been more productive for me. Edited April 10, 2023 by derek.john.evans Quote Link to comment Share on other sites More sharing options...
lp060 Posted April 10, 2023 Share Posted April 10, 2023 (edited) Shouldn't have to do anything special on TOS 4 for a line-a call. I can tell you that gfa does nothing special for line-a calls on TOS 4 because I build the entire gfa library from source code. I'd bet it's something else causing the freeze. The omikron build from your repo also freezes my system, but I see the boxes before it hangs. Edited April 10, 2023 by lp060 updated Quote Link to comment Share on other sites More sharing options...
derek.john.evans Posted April 10, 2023 Author Share Posted April 10, 2023 (edited) Mmmm. Ok, So it looks like I might have to rethink my dev plan. I prefer Omikron 3.6+ code folding, GEM library and function pointers with parameters, but GFA does fly nicely with its LINEA function set. I like the function pointers because my GUI library provides embed-able , autonomous reusable controls. ie: I need function pointers. I'll give GFA another try over the next week. My line drawing benchmark is: (GFA Source) HIDEM ti=TIMER FOR j&=1 TO 15 FOR i&=0 TO 199 ALINE 0,i&,319,199-i&,j& AND 15,-1,0 NEXT i& FOR i&=0 TO 319 ALINE 319-i&,0,i&,199,j& AND 15,-1,0 NEXT i& NEXT j& PRINT TIMER-ti OMIKRON 3.01 Interpreter=2394 Compiled=2323 GFA 3.6 Interpreter=2117 Compiled=1914 So, it does look like GFA would improve my 3D rotation code and my 2D Vector Asteroids game which I'm coding. Mmmm. I'll have rethink. Edited April 10, 2023 by derek.john.evans 1 Quote Link to comment Share on other sites More sharing options...
MrMaddog Posted May 3, 2023 Share Posted May 3, 2023 On 3/24/2023 at 2:06 PM, zzip said: Hard to believe STOS performs so poorly. STOS games always seemed to perform better than GFA games Maybe a wider variety of benchmarks should be tried? Looking at the code, there's no screen swapping between the physical screen (what you see) and the back screen (in memory) that was the common technique in STOS programming. It makes the animation run at the same refresh rate as the screen (50 or 60 Hz). The OP's code is a straight up drawing right on the screen which is what all BASIC programs do, and hence why they are all so slow for making arcade games. Quote Link to comment Share on other sites More sharing options...
Christos Posted May 7, 2023 Share Posted May 7, 2023 On 3/24/2023 at 8:06 PM, zzip said: Hard to believe STOS performs so poorly. STOS games always seemed to perform better than GFA games Maybe a wider variety of benchmarks should be tried? I don't think that's true at all. GFA is generally much faster. Can you point me to an example? Quote Link to comment Share on other sites More sharing options...
zzip Posted May 8, 2023 Share Posted May 8, 2023 19 hours ago, Christos said: I don't think that's true at all. GFA is generally much faster. Can you point me to an example? Just a feeling based on the games I used to see in STOS and GFA. STOS seemed to have better games- more fleshed out, better performing. But since I've never coded in STOS, I don't know for sure. As a GFA programmer, I often felt like I was using the wrong language when I saw what was being done with STOS Could just be a case of "the grass is always greener..." Quote Link to comment Share on other sites More sharing options...
