+Larry Posted March 21, 2023 Share Posted March 21, 2023 Is there a utility similar to ATADIM that will allow you to check the directory and add/delete files? This would be a Windows utility. ATADIM is really handy, but only works for Atari Dos type disks. You simply drag an ATR to ATADIM and it shows you the contents. The you can add/delete files rename a file, etc. on the ATR. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted March 21, 2023 Share Posted March 21, 2023 Altirra does most of what you want under the Tools->> Disk Explorer as for seeing the contents as well, this does a pretty good job https://rossumur.github.io/esp_8_bit/atr_image_explorer.htm 1 Quote Link to comment Share on other sites More sharing options...
Ray Gillman Posted March 21, 2023 Share Posted March 21, 2023 As he says Altirra emulator has a Disk Drives dialog (Alt-D) Mount a Sparta Disk then click the > arrow to edit the contents 1 Quote Link to comment Share on other sites More sharing options...
