SviRu Posted March 24, 2023 Share Posted March 24, 2023 Any idea? Sometimes it works sometimes it does not. I can push as much as I want and it goes to basic. Also holding OPTION is not starting selftest. Selftest itself runs after BYE command and passes perfect. I think i have problems with SIO devices. Cannot force SIO2PC to work. Maybe once. It works on my 800. Thanks for ideas. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted March 24, 2023 Share Posted March 24, 2023 Does the option key work when you go into the self test keyboard ? sounds like you have a keyboard issue or a problem with GTIA Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 24, 2023 Author Share Posted March 24, 2023 3 minutes ago, kheller2 said: Does the option key work when you go into the self test keyboard ? sounds like you have a keyboard issue or a problem with GTIA I let it rest for a while and now I can disable basic. Option does indeed work on seelftest keyboard test. I do not think it is mechanical problem. This atari is almost brand new. It has to be something with the chips. SIO issues / communication. Was unable to load anything from 1010 - even thou it was working with cload and was trying to load something. Always with error 134 or it went into selftest after 1min of loading from 1010. Carts work fine. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted March 24, 2023 Share Posted March 24, 2023 Rubber bands on the 1010 may have deteriorated Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 24, 2023 Author Share Posted March 24, 2023 Just now, Wrathchild said: Rubber bands on the 1010 may have deteriorated I just changed them. Brand new - works perfectly. 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted March 24, 2023 Share Posted March 24, 2023 Are these existing recordings? What if you enter a small program, save and then power-reset and load? Quote Link to comment Share on other sites More sharing options...
vitoco Posted March 24, 2023 Share Posted March 24, 2023 (edited) 1 hour ago, SviRu said: Any idea? Sometimes it works sometimes it does not. I can push as much as I want and it goes to basic. Also holding OPTION is not starting selftest. Selftest itself runs after BYE command and passes perfect. In BASIC: 10?PEEK(53279):G.10 RUN It should show a 3 when the OPTION key is pressed... EDIT: I wrote that before the replies: Edited March 25, 2023 by vitoco Quote Link to comment Share on other sites More sharing options...
vitoco Posted March 25, 2023 Share Posted March 25, 2023 37 minutes ago, SviRu said: Option does indeed work on seelftest keyboard test. I do not think it is mechanical problem. Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 25, 2023 Author Share Posted March 25, 2023 6 minutes ago, vitoco said: In BASIC: 10?PEEK(53279):G.10 RUN It should show a 3 when the OPTION key is pressed... EDIT: I wrote that before the replies: Just connected 1050 it loaded a program fine but upon another boot 800xl was hanging on the cursor (no basic nothing). There is something wrong with the 800. My SIO2PC and 1050 work fine on my other 800. Can it be PIA? GTIA? POKEY? Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 25, 2023 Author Share Posted March 25, 2023 9 minutes ago, vitoco said: In BASIC: 10?PEEK(53279):G.10 RUN It should show a 3 when the OPTION key is pressed... EDIT: I wrote that before the replies: And yes it shows 3 after this command. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted March 25, 2023 Share Posted March 25, 2023 Can you swap out the Pokey as it may well be failing. Happened to one of my A8's. Replaced the Pokey and issues disappeared. If not I guess worth looking at the gtia. Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 25, 2023 Author Share Posted March 25, 2023 2 minutes ago, Beeblebrox said: Can you swap out the Pokey as it may well be failing. Happened to one of my A8's. Replaced the Pokey and issues disappeared. If not I guess worth looking at the gtia. Can I swap pokey from a800 to a800xl? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 25, 2023 Share Posted March 25, 2023 yes Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 26, 2023 Author Share Posted March 26, 2023 On 3/25/2023 at 12:57 AM, vitoco said: In BASIC: 10?PEEK(53279):G.10 RUN It should show a 3 when the OPTION key is pressed... EDIT: I wrote that before the replies: I managed to trigger this issue again. Booting straight to basic - option start not working. Cannot enter selftest. After writing your command OPTION is showing 3. So the key is ok. There is something wrong under the hood. SIO port is not working now. Usually it works couple of minutes maybe 2-3min and then it stops - get corrupted. Is POKEY the only chip that handles communication with SIO? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 26, 2023 Share Posted March 26, 2023 PIA (6520) handles the SIO command line. Quote Link to comment Share on other sites More sharing options...
SviRu Posted March 26, 2023 Author Share Posted March 26, 2023 1 hour ago, flashjazzcat said: PIA (6520) handles the SIO command line. thnx. Will try to change them Quote Link to comment Share on other sites More sharing options...
