SlagOMatic Posted April 9, 2023 Share Posted April 9, 2023 First pic shows a directory on an SD card (which I use on my FujiNet) as seen by my Mac. Second pic shows that same directory on the same SD card as seen by FujiNet. Third pic shows that same directory hosted on my local server as seen by FujiNet. (I literally just copied the directory from the SD card to the server.) All of the ATR images within were duplicates of the same original ATR file. IOW, I made a 90K ATR file in FujiNet (saved on my server), then from my Mac duplicated that file a bunch of times, then renamed them appropriately. This is the first time I've done this process with the SD card which is why I'm asking this question. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 9, 2023 Share Posted April 9, 2023 disk images on SD card are 8.3 just the way local Atari and it's file systems like. disk images on network have long file names and paths the get greeked in the center so it fits your screen when you select or are over the abbreviated name/path the full filename appears at the bottom of the screen. disk images in you mac show the whole file name as you have the filename slider far to the right, moving it to the left will cause mac to abbreviate just like all others. Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted April 11, 2023 Share Posted April 11, 2023 To me it looks like MacOS skipped long file names and saved them in a standard, old DOS way. Not quite as they should be saved on a FAT32 partition. Don't ask me why though, I'm not using Macs and I have no idea. Quote Link to comment Share on other sites More sharing options...
