Shift838 Posted April 17 Share Posted April 17 So, I have a MEGA ST4 that already has a network interface card (Kingston KNE20T - NE2000Plus compatible). I'm wondering if replacing it with a NetUSBee is worth it, what will the USB ports give me? Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted April 17 Share Posted April 17 Anything there are Atari USB drivers for... including printers, mice, keyboards, thumb drives, tablets, etc... Atari USB Drivers | perdrixapps Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 18 Share Posted April 18 If you still have a "real" hard drive, then using a USB thumb drive to back it up is really useful with NETUSBEE, I don't think the network software works very well, I never got STING to work just cased crashes when trying to configure it. The only thing I got to work was UIPV31_1.TOS which provides a drag and drop from your PC to ST or from ST to PC, all actions are done on the PC. Saying that, my NETUSBEE now refuses to use the network, the lights are on, but nobody's home rather disappointed as I hardly used it on the network. I've also used a mouse with it. 1 Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted April 18 Share Posted April 18 Interesting...I use mine on my home network all the time. STING works here, and I use FTP, IRC, and email software, plus you can browse the web through sites like frogfind and 68knews (though it's still frustratingly slow). Recently I've completed the pico wifi project (https://github.com/czietz/picowifi) and no longer even need to connect to the router via a cable. I guess everyone's mileage is different. 2 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 18 Share Posted April 18 9 minutes ago, Atari8guy said: Interesting...I use mine on my home network all the time. That's interesting because when I bought mine, I couldn't get any network utilities working and I was a little concerned about the lights that lit even when no network cable was connected, I sent it back for the supplier to test, he said it was all working fine and not to worry about the lights. As I said STING never works and now no network, I suspect it was faulty in the first place but a bit late now to do anything about it, had it too long, you live and learn Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 18 Share Posted April 18 25 minutes ago, Atari8guy said: Interesting...I use mine on my home network all the time. STING works here, and I use FTP, IRC, and email software, plus you can browse the web through sites like frogfind and 68knews (though it's still frustratingly slow). Recently I've completed the pico wifi project (https://github.com/czietz/picowifi) and no longer even need to connect to the router via a cable. I guess everyone's mileage is different. Pretty much the same results here... Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted April 18 Share Posted April 18 1 hour ago, TGB1718 said: That's interesting because when I bought mine, I couldn't get any network utilities working and I was a little concerned about the lights that lit even when no network cable was connected, I sent it back for the supplier to test, he said it was all working fine and not to worry about the lights. As I said STING never works and now no network, I suspect it was faulty in the first place but a bit late now to do anything about it, had it too long, you live and learn A lemon is always possible, but if you want to explore something....on Exxos site, there is a lot of discussion around how the NETUSB really just barely works and its very sensitive to it's power feed. I don't recall all the details of that convo as I haven't had issues, but if I remember one thing, I think it doesn't like a full 5V, it prefers a bit less...which means it doesn't work well with EXXOS own replacement power supplies. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted April 18 Author Share Posted April 18 i have submitted an order for one through The Brewing Academy. I am getting ready to put my MEGA ST4 back together since I painted the case, i'll post pics later. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 18 Share Posted April 18 1 hour ago, Atari8guy said: A lemon is always possible, but if you want to explore something....on Exxos site, there is a lot of discussion around how the NETUSB really just barely works and its very sensitive to it's power feed. I don't recall all the details of that convo as I haven't had issues, but if I remember one thing, I think it doesn't like a full 5V, it prefers a bit less...which means it doesn't work well with EXXOS own replacement power supplies. Now that is interesting, I bought a low power 68000 CPU from EXXOS some time ago, while the case was off, I checked the power supply voltages and they were a little low, so I did a re-cap which didn't make any difference, so I adjusted the voltage up to 5V. I had random hangs and crashes with the new CPU, so I put the old one back and the ST was fine again. Swapped back in the low power one and lowered the 5V back to where it had been before and the system was stable so the CPU was rather touchy running @5V , I decided to put the old CPU back in and adjust the 5V back to the correct value. Now what I don't remember is if the NETUSBEE network was working when the STE power was below 5V. Looks like open her back up again sometime and reduce the 5V, I think it was at 4.85V on load, so inside spec. and see if the network side of the NETUSBEE works again, the USB side is fine all the time. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 19 Share Posted April 19 Also, Lotharek is selling a newer version of the NetUSBee that has been modified to account for a few things...been thinking about upgrading myself. 1 Quote Link to comment Share on other sites More sharing options...
mdivancic Posted April 24 Share Posted April 24 (edited) I use my NetUSBee to get programs onto my hard drive on my TT using a USB Flash drive. Works great for this. Edited April 24 by mdivancic 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted May 6 Author Share Posted May 6 I have received my NetUSBee and found it to be quite easy to get programs from my PC over the network to my MEGA ST. I like it... 4 Quote Link to comment Share on other sites More sharing options...
