Dinadan67 Posted May 2, 2023 Share Posted May 2, 2023 I want to replace a mexican made CPU with a more reliable type. I found a vendor on Ebay which sells CPUs which are labeled "C014806-35 (C) Atari 1980" without any additional vendor or logo. Does anybody knows if this is a good batch? Quote Link to comment Share on other sites More sharing options...
TZJB Posted May 2, 2023 Share Posted May 2, 2023 51 minutes ago, Dinadan67 said: I want to replace a mexican made CPU with a more reliable type. I found a vendor on Ebay which sells CPUs which are labeled "C014806-35 (C) Atari 1980" without any additional vendor or logo. Does anybody knows if this is a good batch? I bought 2 of those and used both to replace fauly Sally chips, one in a 800XLF and one in a 130XE. They work a lot better than the ones I replaced them with! 1 Quote Link to comment Share on other sites More sharing options...
voy Posted May 2, 2023 Share Posted May 2, 2023 4 hours ago, Dinadan67 said: I want to replace a mexican made CPU with a more reliable type. I found a vendor on Ebay which sells CPUs which are labeled "C014806-35 (C) Atari 1980" without any additional vendor or logo. Does anybody knows if this is a good batch? I use it in my 800XE with a Rapidus card. It works very well, although it overheats a lot. So I bought a Fischer Elektronik ICK40B radiator and Thermalright Extreme II 85x45x1mm 14.8W thermal pad. 2 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted May 2, 2023 Share Posted May 2, 2023 No Atari chip should "overheat" -- that's a commodore thing. 2 1 5 Quote Link to comment Share on other sites More sharing options...
ACML Posted May 2, 2023 Share Posted May 2, 2023 10 hours ago, Dinadan67 said: I want to replace a mexican made CPU with a more reliable type. I found a vendor on Ebay which sells CPUs which are labeled "C014806-35 (C) Atari 1980" without any additional vendor or logo. Does anybody knows if this is a good batch? There are some good options on eBay if you're CONUS, but being located in Europe, these may not be a good option when considering shipping. I've had a few bad Rockwell (Mexico) 6502Cs, but I've had many more that are fine. It might have been just a bad lot or two that is getting all the bad press. Is the current one acting up? Quote Link to comment Share on other sites More sharing options...
ACML Posted May 2, 2023 Share Posted May 2, 2023 6 hours ago, kheller2 said: No Atari chip should "overheat" -- that's a commodore thing. The -35 has me scratching head. Never seen one in the wild installed in a machine. Not sure Atari used SALLY's in 1980. It's possible, but if they are truly 1980 production, you'd think they would routinely show up in production units. Plus the overheating is uncharacteristic of Atari VLSI chips. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 3, 2023 Share Posted May 3, 2023 It does seem strange though they did have weirdly early dates on some chips. My thought was that Sally was around the time of the 5200 and incorporated into computer CPU boards around the same time. Alternatively it could be around the time GTIA became available but I think that would be a too early estimate. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted May 3, 2023 Share Posted May 3, 2023 -35 were used in late 80s 7800s, I believe. Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted May 3, 2023 Author Share Posted May 3, 2023 7 hours ago, ACML said: Is the current one acting up? Yes, i have problems with Side3 on that machine. The older Side2 is working fine. I have ordered the C014806-35 and will report if something changes. 1 Quote Link to comment Share on other sites More sharing options...
voy Posted May 3, 2023 Share Posted May 3, 2023 This version of Sally is very stable and the only downside is the high temperature. I use it with Rapidus, Ultimate 1MB (first version from Candle), VBXE v2.1 and Evie (prototype sound card by Pasiu). IDE Plus rev.F, SIDE1, Ultimate Cart, AVG Cart (the first version with a black and white sticker) also work without any problems. Motherboard is C103579-001 Rev.1. 1 Quote Link to comment Share on other sites More sharing options...
TZJB Posted May 5, 2023 Share Posted May 5, 2023 (edited) On 5/3/2023 at 12:24 AM, ACML said: The -35 has me scratching head. Never seen one in the wild installed in a machine. Not sure Atari used SALLY's in 1980. It's possible, but if they are truly 1980 production, you'd think they would routinely show up in production units. Plus the overheating is uncharacteristic of Atari VLSI chips. (c) 1980 is just a copyright date and not a manufacturing date so can be misleading. Edited May 5, 2023 by TZJB 2 Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted June 1, 2023 Author Share Posted June 1, 2023 (edited) The C014806-35 Sally is more stable than my previous mexican CPU and solves the problem with Side3. But as @voy wrote, it is getting very hot. I put a passive cooling element on it to avoid problems with overheating. Edited June 1, 2023 by Dinadan67 Quote Link to comment Share on other sites More sharing options...
kenames99 Posted June 2, 2023 Share Posted June 2, 2023 On 5/2/2023 at 9:39 AM, kheller2 said: No Atari chip should "overheat" -- that's a commodore thing. hahahaha! I just thought that was funny Quote Link to comment Share on other sites More sharing options...
Geister Posted June 2, 2023 Share Posted June 2, 2023 18 hours ago, kenames99 said: hahahaha! I just thought that was funny I just bought two C64s locally because I was looking for a hobby project and every C64 you see on a YouTube channel is DOA and needs repairs. I was looking forward to a challenge. Both units I bought worked after some initial confusion about video hookups. Now that's hilarious to me, expectations subverted! Oh, it's national donut day! I need to get some donuts. Quote Link to comment Share on other sites More sharing options...
DrVenkman Posted June 2, 2023 Share Posted June 2, 2023 1 minute ago, Geister said: I was looking forward to a challenge. Both units I bought worked after some initial confusion about video hookups Don’t know how familiar you are with C64’s and WHY many of them need those repairs but don’t use vintage power bricks or you’ll get a challenge. Quote Link to comment Share on other sites More sharing options...
Geister Posted June 2, 2023 Share Posted June 2, 2023 Thanks, I already bought a replacement supply. I have to believe that the guy I bought these from put them away in 1988 and never powered them up again. At least I won't be spending a fortune on SID and PLA chips. 1 Quote Link to comment Share on other sites More sharing options...
BillC Posted June 3, 2023 Share Posted June 3, 2023 8 hours ago, DrVenkman said: Don’t know how familiar you are with C64’s and WHY many of them need those repairs but don’t use vintage power bricks or you’ll get a challenge. I believe many of the C64 vintage power supplies have the same +5VDC circuit as the Atari "INGOT" plus 9VAC on 2 of the DIN7 pins. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 3, 2023 Share Posted June 3, 2023 The overvoltage problem is on the 5V DC apparently and usually on the epoxy filled non servicable ones. I guess the AC side is probably OK - generally a transformer should work or not and the output voltage is determined the windings ratio and input voltage. Quote Link to comment Share on other sites More sharing options...
