www.atarimania.com Posted May 5, 2023 Share Posted May 5, 2023 John Hardie just discovered a new version of Atari's Macro Assembler and Program-Text Editor. While all releases found so far were "V1.0A" editions, a "Company Confidential" disk with a hand-written "V1.0E" label was unearthed and dumped recently: http://www.atarimania.com/utility-atari-400-800-xl-xe-atari-macro-assembler-and-program-text-editor_14315.html 4 3 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 5, 2023 Share Posted May 5, 2023 The excutable really differs. Visible differences: Startup message ATARI Macro Assembler Ver 1.0A Copyright 1981 ATARI vs. ATARI Macro Assembler Ver 1.0E Copyright 1981 ATARI Inc. Additional error message Long Xref requires PS 3 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 5, 2023 Share Posted May 5, 2023 @tschak909 posted a copy of version 1.0C of the Macro Assembler a few years ago. I have the disks he posted, but I can't locate the original post he made, ATM. The reason I was specifically looking for that is because he mentioned the differences for that version in his post. Maybe he'll comment about it... Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted May 5, 2023 Author Share Posted May 5, 2023 My bad, I didn't know about V1.0C and found it on AtariWiki. Is it the same disk? The huge problem is that the density is wrong. Is the program from back in the day? What about V1.0D? Is this a hack? Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 5, 2023 Share Posted May 5, 2023 9 minutes ago, www.atarimania.com said: My bad, I didn't know about V1.0C and found it on AtariWiki. Is it the same disk? The huge problem is that the density is wrong. Is the program from back in the day? Yeah, AtariWiki has a copy of it (they got it from the same post here on AtariAge that I got it from). You'll have to find out from @tschak909 about it's origins. That's why I was trying to find his original post about it. I've forgotten what he had to say about it at this point. 9 minutes ago, www.atarimania.com said: What about V1.0D? Is this a hack? I think so; and they should be noting that. Quote Link to comment Share on other sites More sharing options...
invisible kid Posted May 5, 2023 Share Posted May 5, 2023 I do know that there was a popular hack to circumvent the copy protection which removes the grinding/seeking of your disk drive at launch. Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted May 5, 2023 Author Share Posted May 5, 2023 @MrFish Thanks for the information. Didn't notice V1.0C is actually a cracked executable on a compilation with other programming apps. It appears to be from Pokey Soft's collection. In short, it was already "floating around" in the eighties but there's no confirmation it had an official release. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 5, 2023 Share Posted May 5, 2023 V1.0C is a cracked V1.0A with one CMP changed ; code from V1.0A ; wild guess: this code is part of the parser because it checks for EOL 573C: A0 00 LDY #$00 573E: B1 8E LDA ($8E),Y 5740: C9 44 CMP #$44 5742: D0 1B BNE $575F 5744: 91 86 STA ($86),Y 5746: C8 INY 5747: B1 8E LDA ($8E),Y 5749: C9 3A CMP #$3A 574B: D0 0E BNE $575B 574D: A9 31 LDA #$31 574F: 91 86 STA ($86),Y 5751: E6 86 INC $86 5753: D0 02 BNE $5757 5755: E6 87 INC $87 5757: A9 3A LDA #$3A 5759: D0 14 BNE $576F 575B: C9 35 CMP #$35 ; CMP #$39 in V1.0C 575D: 90 03 BCC $5762 575F: 4C F2 57 JMP $57F2 5762: C9 31 CMP #$31 5764: 90 F9 BCC $575F 5766: 91 86 STA ($86),Y 5768: C8 INY 5769: B1 8E LDA ($8E),Y 576B: C9 3A CMP #$3A 576D: D0 F0 BNE $575F 576F: 91 86 STA ($86),Y 5771: A2 00 LDX #$00 5773: C8 INY 5774: B1 8E LDA ($8E),Y 5776: C9 9B CMP #$9B ; check for EOL 5778: D0 03 BNE $577D 577A: 4C F4 57 JMP $57F4 V1.0D is a slightly patched V1.0C (the crack was done exactly the same as in V1.0C) ; differences in V1.0D ; V1.0D opens a file R/O whereas all the other versions open it R/W 4FFA: A2 70 LDX #$70 4FFC: A5 8E LDA $8E 4FFE: 9D 44 03 STA ICBAL,X 5001: A5 8F LDA $8F 5003: 9D 45 03 STA ICBAH,X 5006: A9 04 LDA #$04 ; LDA #$0C in V1.0A and V1.0C 5008: 9D 4A 03 STA ICAX1,X 500B: A9 00 LDA #$00 500D: 9D 4B 03 STA ICAX2,X ; ; same area as in first code snippet 5749: C9 3A CMP #$3A 574B: F0 22 BEQ $576F 574D: 90 13 BCC $5762 574F: 29 5F AND #$5F 5751: C9 41 CMP #$41 5753: 90 0A BCC $575F 5755: C9 50 CMP #$50 5757: 90 09 BCC $5762 5759: EA NOP 575A: EA NOP 575B: EA NOP ; the changed CMP from the first 575C: EA NOP ; code snippet would be here 575D: EA NOP 575E: EA NOP 575F: 4C F2 57 JMP $57F2 4 1 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted May 5, 2023 Author Share Posted May 5, 2023 Appreciate your in-depth analysis, we have a clear picture of what all the versions are now. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 5, 2023 Share Posted May 5, 2023 (edited) 1 hour ago, www.atarimania.com said: Appreciate your in-depth analysis, we have a clear picture of what all the versions are now. There's one more thing The code in the above mentioned differing areas in V1.0E is the same as in V1.0A; except that it is moved in memory by $42 bytes ($577E vs. $573C). This leads to the conclusion that both C and D are not later releases but hacks for whatever reason. Edited May 5, 2023 by DjayBee 1 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 5, 2023 Share Posted May 5, 2023 Here's the thread where creation of the 1.0D patch version happened: Programmer editors for 80 columns 2 1 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted May 5, 2023 Author Share Posted May 5, 2023 @DjayBee Yes, definitely figured V1.0C / V1.0D were hacks after what you wrote. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 6, 2023 Share Posted May 6, 2023 Final analysis : The hacked code is not part of the parser but the check for entered file names. 1.0C extends the range of allowed drives from D1-D4 to D1-D8. 1.0D does the modification described by drac030 in the thread linked by MrFish : "named the version 1.0d. It should produce binaries of non-zero size, and accept drive numbers D1: - D9: and DA: - DO: at the parameter prompt. Also, 😧 should no longer be explicitly translated to D1:" 5 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 6, 2023 Share Posted May 6, 2023 so why not call the things as 1.Ch for hacked or 1.Eh if the latest one gets hacked for drive usage and sparta etc. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 6, 2023 Share Posted May 6, 2023 (edited) In case someone uses AMAC with SpartaDos, I applied @drac030's patch to 1.0E and changed the on-screen version to 1.0e (lower case e). AMAC-10e-Drac030patch.xex I cannot test myself, therefore please report back. Edited May 6, 2023 by DjayBee Changed the filename to differ from the original Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 6, 2023 Share Posted May 6, 2023 (edited) this is a confusion factory where revision numbers are concerned. Gotta be a way to make it clear in the program display as well as on file naming convention... Edited May 6, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 6, 2023 Share Posted May 6, 2023 5 minutes ago, _The Doctor__ said: Gotta be a way to make it clear in the program display as well as on file naming convention... Yes and no. The unchanged filename was a mistake I corrected now but I won't change the program display besides 1.0E vs. 1.0e because there is no space to add something and I do not deliberately remove copyrights etc. Quote Link to comment Share on other sites More sharing options...
