+Larry Posted May 18, 2023 Share Posted May 18, 2023 PM me if you have one to sell. All replies answered. Quote Link to comment Share on other sites More sharing options...
IndusGT Posted May 19, 2023 Share Posted May 19, 2023 there's one on e-bay: https://www.ebay.com/itm/266256043453?_trkparms=ni_actn%3Anav|ni_nt%3AWATCH_ITEM_ENDING_SOON|ni_apos%3A1|ni_sg%3A1|ni_pos%3A1|ni_st%3AREAD|ni_wh%3A1|ni_nid%3A726510807010|ni_nsid%3A266256043453|ni_et%3A1684548712000|ni_bn%3A1&_trksid=p2380424.m570.l5997 Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 19, 2023 Author Share Posted May 19, 2023 Thanks. I did see that one, but I sure don't need another 130XE with bad ram. If this doesn't pan out, then recreating a very similar one would be the next best bet. Hias' high-speed patch does the heavy lifting. The other (IMO) killer features of the US+ OS are the 720 sector ramdisks (single or double density) and the ability to swap drives. I don't believe coding of the drive swapping would be a big deal. But I think that the 720-sector ramdisk would be more difficult. Here's a question for the coders -- would some of the features like changing margins and screen color selection suggest that there is likely an SRAM inside the module? Has anyone ever taken one of the modules apart? Quote Link to comment Share on other sites More sharing options...
IndusGT Posted May 19, 2023 Share Posted May 19, 2023 (edited) 6 hours ago, Larry said: Thanks. I did see that one, but I sure don't need another 130XE with bad ram. If this doesn't pan out, then recreating a very similar one would be the next best bet. Hias' high-speed patch does the heavy lifting. The other (IMO) killer features of the US+ OS are the 720 sector ramdisks (single or double density) and the ability to swap drives. I don't believe coding of the drive swapping would be a big deal. But I think that the 720-sector ramdisk would be more difficult. Here's a question for the coders -- would some of the features like changing margins and screen color selection suggest that there is likely an SRAM inside the module? Has anyone ever taken one of the modules apart? Would be great, I asked tf_hh to add it to the Sys- Check but he said he was unable, it was just a little too big, would be awesome to have this available for everyone. I have one of these also in a a 130 xe ( sorry not for sale) and it's great. Edited May 19, 2023 by IndusGT Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 19, 2023 Share Posted May 19, 2023 Hello guys the US+ OS by CSS has no cassette handler and no relocatable code support IIRC. Maybe @reifsnyderb can add the disk swapping ability to his new OS, if there is enough room left for it. BTW IIRC US+OS also enables you to use D9: for the RAMdisk. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted May 19, 2023 Share Posted May 19, 2023 18 minutes ago, Mathy said: Hello guys the US+ OS by CSS has no cassette handler and no relocatable code support IIRC. Maybe @reifsnyderb can add the disk swapping ability to his new OS, if there is enough room left for it. BTW IIRC US+OS also enables you to use D9: for the RAMdisk. Sincerely Mathy What's disk swapping? Would that be some way to change D1: to D2: without a reboot? If so, why? Thanks! Brian Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted May 20, 2023 Share Posted May 20, 2023 24 minutes ago, reifsnyderb said: What's disk swapping? Would that be some way to change D1: to D2: without a reboot? If so, why? Thanks! Brian I'm not sure what Mathy meant, but I do know that I loved the ability to swap drive numbers around on the MIO. Booting from RAM disks are so cool. 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 20, 2023 Author Share Posted May 20, 2023 Boot from a drive other than D1:. Swap a disk for game play. D1: is a hard drive, and you need to boot from a floppy. Boot from a ram disk. I think those are all plausible. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted May 20, 2023 Share Posted May 20, 2023 What do you do when booting from a drive? Do you hold down a key to indicate you are booting from D2:? Does a boot menu come up? How's that work? Booting from a RAM disk implies that some sort of RAM disk software is part of the OS. Thinking about this and how it relates to the 1090XL....having a battery backed-up SRAM drive would be cool and doable. Hmmm..... Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 20, 2023 Author Share Posted May 20, 2023 Hot keys -- such as Start + Reset. If one ditches the Self Test and cassette code, it makes quite a bit of room. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted May 20, 2023 Share Posted May 20, 2023 9 minutes ago, Larry said: Hot keys -- such as Start + Reset. Would this be some sort of boot order change...such as provided by a modern BIOS? i.e. Boot from A:, D:, C:, in that order? 1 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted May 20, 2023 Share Posted May 20, 2023 (edited) Ok....I found a description of this drive re-numbering feature here: https://www.atarimax.com/freenet/freenet_material/5.8-BitComputersSupportArea/10.ProductReviews/showarticle.php?51 "One powerful feature of the OS is it's ability to reconfigure drives for different numbers and boot from any drive, including RAMdisk. When you hold down START after a RESET (warm or cold start), you'll enter a menu that has lists drive 1-9 and what each is assigned as. Normally, they are all assigned to themselves, except drive 4 which is normally RAMdisk. Say you wanted drive 4 to be drive 1 and drive 1 to be drive 4. You'd press RESET and START. You then press C for configure, enter the original drive (1), then the drive you want it to be (4). Then you repeat the procedure for drive 4. It's that easy! With this menu, you can also change your RAMdisk number just with R for RAMdisk, then enter whatever drive you want it to be." Edit to add: The information also states the following....which could be a problem for those who use SpartaDOS X: "Unfortunately, if you use SpartaDOS, the reconfiguring will have no effect due to it's using custom routines, bypassing the OS. Also the Virtuoso player will always go to the "real" drive 1 instead of whatever is configured as drive 1. Also SpartaDOS will not boot from RAMdisk, allow the keyboard functions (without a KEY OFF command), or allow high speed with the XF551 drive. But if you MUST use this DOS, it is easily modifiable with a built-in patch called by a simple USR command that will modify SpartaDOS to allow these things." Edited May 20, 2023 by reifsnyderb 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 20, 2023 Share Posted May 20, 2023 (edited) use the routines from the MIO or Black Box, they work across the board. SpartaDos allows swapping within itself too. But it's not quite the same. If you use this as part of 1090XL the config can be retained as long as the 1090XL stays powered or is flash/battery backed up etc. Same for any add on memory / OS card... saved in the RTC memory etc.. Edited May 20, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 20, 2023 Share Posted May 20, 2023 Hello guys Damn, I though I might have the US+ OS manual on my Docs page. I don't. If anyone has any of the CSS manuals that aren't on my Docs page yet in a high quality, please contact me. At the moment, I'm at the H.A.T.Z. meeting (see my meetings page). We do have Wifi here, but most of the time it's slooooooooowwwwwww. So no uploading of anything until at least sunday evening (very late). Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted May 20, 2023 Share Posted May 20, 2023 In my opinion, it should also be possible to run this OS from the Freezer. Of course one needs to have that piece of hardware.... Major detail of course. 🙂 BR/ Guus 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 20, 2023 Author Share Posted May 20, 2023 32 minutes ago, guus.assmann said: In my opinion, it should also be possible to run this OS from the Freezer. Of course one needs to have that piece of hardware.... Major detail of course. 🙂 BR/ Guus Hi Guus- But how? To date there is no successful dump of the US+ OS, at least that I'm aware of. But Doc is correct -- the Black Box gives you the major features. Even the 720 sector ramdisk is simulated by creating 720 sector hard disk partitions (99 of them!). And the BB menu gives you easy access to all the features. Plus you get that cool BB SIO sound at no extra cost! 😄 Edit: Or perhaps you are saying that you could freeze the US+ and then re-load it? I had not thought of that angle -- very interesting! I will give that a try. And thinking ahead, the freezer might provide a good dump. 2 Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 20, 2023 Share Posted May 20, 2023 (edited) Sorry, I misread the above. Please remove. Edited May 20, 2023 by Mathy Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted May 20, 2023 Share Posted May 20, 2023 21 hours ago, Mathy said: Hello guys the US+ OS by CSS has no cassette handler and no relocatable code support IIRC. Maybe @reifsnyderb can add the disk swapping ability to his new OS, if there is enough room left for it. BTW IIRC US+OS also enables you to use D9: for the RAMdisk. Sincerely Mathy Yes it is drive 9. When using real Hardware, my 320XE I purchased from CSS directly is my computer of choice. It came with a switch to change OS's. US Speed+, XE and FixXL. Holding start while starting the FIXXL OS, allows you to create menu disks. Cool system. 1 Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 20, 2023 Share Posted May 20, 2023 Hello Soulbuster 26 minutes ago, SoulBuster said: It came with a switch to change OS's. US Speed+, XE and FixXL. The UltraSpeed+ hardware always consist of these three OSs. Sincerely Mathy (who has both versions 1.4 and 1.5 of the UltraSpeedPlus OS by CSS) Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 21, 2023 Author Share Posted May 21, 2023 What are the differences between 1.4 and 1.5, and if you know 1.2? Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 21, 2023 Share Posted May 21, 2023 (edited) Hello Larry I'm at the H.A.T.Z. XXIII at the moment, so I can look look that up. And as I said, I don't have earlier versions than 1.4. Sincerely Mathy Edited May 21, 2023 by Mathy Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 21, 2023 Author Share Posted May 21, 2023 I spent a couple of hours today working with the US+ and the Freezer. I cannot get the Freezer to work with the US+ module. That includes the regular XL/XE OS contained in the module. Pressing the Freezer button locks up the system. The computer is a 320K XE and the US+ is a V1.5. I tried with other computers (no US+), and the Freezer works perfectly. So my conclusion is they are incompatible. ☹️ Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 22, 2023 Share Posted May 22, 2023 Which software version are you running on the Frreezer (check with "VER")? Might be worth retrying with the latest version. I've fixed a bug about a year ago that lead to a crash on freezing if the NMI vector in the OS is set to a specific value. Version 220626 contains the fix https://www.horus.com/~hias/freezer/software/beta/ so long, Hias 1 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 22, 2023 Author Share Posted May 22, 2023 Thanks! I'll try it this week. Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 23, 2023 Author Share Posted May 23, 2023 I updated the Freezer software, but it still results in locking up. So no luck with this approach. Quote Link to comment Share on other sites More sharing options...
