+Larry Posted May 27, 2023 Author Share Posted May 27, 2023 It is a bit like apples and oranges, but I have spent some time exploring the features of the Black Box and comparing those to the Ultra Speed Plus OS. Here's what you get, and what you are missing. Black Box Typically A user-selected single OS (usually the XL/XE OS). So you have no easily switchable OS selection. But you can have a multi-OS eprom board like the RamRod XL or a 4-in-1 using switches and a 27512 eprom. My everyday Atari computer is a 600XL with an Antonia 4MB, so that is another way to get multi-OS. I don't remember if the BB is compatible with the Ultimate 1MB. Easily swappable drives from the BB drive configuration menu. 96 partition selections chosen from the BB menu. High-speed (3X) SIO No special 720-sector ramdisk (as with the US+), but you can set up 720 (or 1040) sector partitions on your hard disk or compact flash card in single or double density. I've used ACARD SCSI to IDE converters, but now I use an "Aztec Monster" which includes a built-in CF adapter. It also works with SD card adapters. (Attached is a screen shot of the Drive Configuration page showing two 720-sector drives.) You also get RS-232 and a printer interface + optional print buffer, but I haven't used those in many years. You can also add the Floppy Board and get even more flexibility. Now, what you are missing from the US+ OS. Keyboard lock Screen DMA toggle Key click toggle Internal Basic toggle Key repeat selection Adjustable screen colors Cold start without memory loss Built-in mini sector copier Built-in configuration editor 38/40 column switchable Fast Math package Better memory test Many of these are just a POKE to the XL/XE OS. If I had to choose, I'd pick the Black Box, but the US+ is a really nice product, too, and well worth having. 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted May 30, 2023 Share Posted May 30, 2023 On 5/27/2023 at 9:30 AM, Larry said: 96 partition selections chosen from the BB menu. The BB allows you to point to specific sectors for the partition list. I used to keep track of multiple partition lists that I kept in a 720 sector partition itself, for back up purposes. Before ATR's I used to setup up 720 sector partitions and sector copy my software to them for faster loading. I have had 3 partitions lists of 96 partitions each setup at one moment in the past. Glad I Bought one back in the day. Still have 3. 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 30, 2023 Author Share Posted May 30, 2023 As can be seen in the (previous) Drive Configuration Page, after I got past the first large partition, I allocated 1000 sectors to the 720-sector drives for easy math. BITD with small drives, I wouldn't have been so wasteful. With the Floppy Board attached, it really is a beast, but I've 99% moved on to ATR's, so I will likely not use the FBs anymore. Quote Link to comment Share on other sites More sharing options...
