newTIboyRob Posted May 30, 2023 Share Posted May 30, 2023 Hi, just wondering if someone can guide me here. I am in BASIC and just finished a simple program on the 2GS. I want to do a full system reboot: Open Apple, Cntrl, then the key at upper left that looks like <. I thought this was the procedure? I tried this several ways... all keys simultaneously... did nothing... then I tried first open apple, then cntrl, and then the final key, as a one by one separate conglomerate, but still nothing ... I couldn't get a full system reboot. Does that final key need to be simply pressed, or slid to the left as the arrow shows or a combo of those actions? Is there some special trick or something I am missing here? Just can't get the system to reboot. Please advise, thanks! Quote Link to comment Share on other sites More sharing options...
nick3092 Posted May 30, 2023 Share Posted May 30, 2023 (edited) Press Open Apple, Ctrl, <| (reset) all at the same time. Let go of reset only while holding OA-Ctrl. Once it starts to reboot, you can let go of OA-Ctrl. I will say the IIgs seems to be a little trickier timing wise than my //c or IIe when it comes to this. Like you have to keep holding OA-Ctrl a second longer on the IIgs than the others. Edited May 30, 2023 by nick3092 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted May 30, 2023 Author Share Posted May 30, 2023 Nick, thank you so much! Worked like a charm, and yes, you are definitely right, this is WAY trickier timing wise than my //c and IIe as well for this procedure. It really is: press and hold Open Apple while holding down Cntrl at the same time, then add in the <|, keep holding all 3 keys down, wait a second or two, then keep holding down the <| then finally release the OA Cntrl combo then the <| Wow. Thanks again Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted May 30, 2023 Author Share Posted May 30, 2023 Slight correction to above: release the <| first and then finally release the OA Cntrl combo. Quote Link to comment Share on other sites More sharing options...
Iamgroot Posted May 31, 2023 Share Posted May 31, 2023 Not at my IIGS at the moment, but I don't think the Reset key needs to be held. Just hold OA-Ctrl down first, then tap the Reset key while still holding OA-Ctrl down, only letting go once reboot starts. 1 Quote Link to comment Share on other sites More sharing options...
MarkO Posted July 29, 2023 Share Posted July 29, 2023 The Open Apple ( this is the same signal as PDL 0's Button ) and the Control are Modifiers, ( like the Shift Key ).. By themselves, they don't do anything, until another key is pressed.. The Original Apple ][s, pressing and releasing the RESET would RESET the Computer.. Being this caused a few Issues, the Apple ][ was then modified to require the Control to be held Down when pressing and releasing the RESET, to RESET the Computer. The Apple ][e added the Open Apple and Close Apple, and when Holding one of them down, while the Control was held down and pressing and releasing the RESET, would get a Reboot, ( Open Apple ) or Self Diagnostics ( Closed Apple ). Also, if there is no keyboard attached to the Apple ][e, the computer goes into an Endless Self Test... MarkO Quote Link to comment Share on other sites More sharing options...
