Nibur Posted June 12 Share Posted June 12 Hello, all, I am brand new to using Jagstudio. I am running into a problem with the first project under quickstart. It has you copy the 2 .bmp images it has (a spider and IDK) into the gfx folder (\assets\gfx\ folder.) Then has you do this: ABS,SPRITE_BUG,gfx_clut16,assets\gfx\bug.bmp next you open rapinit.s and has you copy a long line of code above ;Template line. After that you run it with cmd i.e. build yourprojectname press enter. Anyway it works, but, there are thick green lines all over the screen. I Don't know what happened, any help would be appreciated. Please and thank you :) Quote Link to comment Share on other sites More sharing options...
Sporadic Posted June 14 Share Posted June 14 Are you able to take a screenshot/photo of the green lines? I assume it ran in Virtual Jaguar? You could also try "build projectname bigp" to see what that emulator does instead. Quote Link to comment Share on other sites More sharing options...
Nibur Posted June 20 Author Share Posted June 20 I dunno I've been busy, so I took a break from it. I went back to it again... and ... it doesn't work at all anymore :( I also don't know how to run it on the BigPemu. I do have that emulator and it's awesome, but, not sure how run something I coded on it. Quote Link to comment Share on other sites More sharing options...
Jag_Mag Posted June 21 Share Posted June 21 (edited) Use "build gamename bigp" gamename is the name of your project Nibur Can you post your "rapinit.s" as your talking about copying and Raptor examples don't have you copy anything. Edited June 21 by Jag_Mag 1 Quote Link to comment Share on other sites More sharing options...
Jag_Mag Posted July 15 Share Posted July 15 Another one bites the dust?or.......figuring things out on his own. Quote Link to comment Share on other sites More sharing options...
