OX. Posted June 14, 2023 Share Posted June 14, 2023 Found these 6 new adventures contained in a zip from this site :- https://microheaven.com/airlock/ A1RL0CK, by Marco Innocenti Blorp!, by Shawn Sijnstra A Clean Getaway, by Michael Bub The Fantasy Dimension, by Johan Berntsson Lucid Night, by Dee Cooke Submarine Sabotage, by Garry Francis They cover many platforms, the Ti99/4a being one of them. I think the game Airlock has already been made available on here but the rest I cannot get to work, looks like they use the Infocom interpreter but maybe the main files are not available on the disk or not converted to TI99 format. Any help please? 5 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 14, 2023 Share Posted June 14, 2023 If whoever created the collection used the same script to convert the files as was used for Tristam Island, file allocation is problematic if any of the files are fractured (i.e., if the file uses more than a single, contiguous set of sectors). If no one else looks at this by the weekend, I'll take a look at the images. Also, the game files must be version 3 (z3) to work with the /4A interpreters. 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 14, 2023 Share Posted June 14, 2023 I took a quick peek at the disk images and you are correct, only A1RL0CK contains an actual story. the LOAD programs are missing the game title and author, which I think is also part of the automation. I would suggest reaching out to the site owner to find out if the process can be re-run to fix the incomplete /4a disk images. Maybe someone incorrectly used Stefan's build process or tried to convert the z5 files instead of the z3 files. 1 Quote Link to comment Share on other sites More sharing options...
OX. Posted June 14, 2023 Author Share Posted June 14, 2023 Thanks InsaneMultitasker. The sources for the games are listed in the documentation as :- A1RL0CK: https://jpking.itch.io/a1rl0ck Blorp!: https://sijnstra.itch.io/blorp A Clean Getaway: https://bud1oo.itch.io/clean-getaway The Fantasy Dimension: https://johanberntsson.itch.io/the-fantasy-dimension Lucid Night: https://dee-cooke.itch.io/lucid-night Submarine Sabotage: https://warrigal.itch.io/submarine-sabotage So I suppose the Z3 files from these could be converted and added to the disk images? I don't how to convert them to TI99 format myself. 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 14, 2023 Share Posted June 14, 2023 I took a quick look at the Submarine Sabotage link and there is are z3 and z5 formatted files there. Have not looked at the other links. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 14, 2023 Share Posted June 14, 2023 11 minutes ago, OX. said: So I suppose the Z3 files from these could be converted and added to the disk images? I don't how to convert them to TI99 format myself. Yes, if a Z3 file exists, I would think it can be converted to run with the /4a interpreters. The reason I suggested reaching out to the site owner/ZIP owner was so that the images can be corrected and posted at the source. An alternative is what you suggest: that someone here converts them and shares the corrected images with the site owner. 1 Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 15, 2023 Share Posted June 15, 2023 (edited) Okay used my own tools, downloaded and converted the following PunyJam #3 entries: A1RL0CK: https://jpking.itch.io/a1rl0ck Blorp!: https://sijnstra.itch.io/blorp A Clean Getaway: https://bud1oo.itch.io/clean-getaway Falling Pieces: https://g0blin.itch.io/falling-to-pieces The Fantasy Dimension: https://johanberntsson.itch.io/the-fantasy-dimension Submarine Sabotage: https://warrigal.itch.io/submarine-sabotage Since I'm using my own toolset should I post the files here or send them to the site owner. It seems that the multi-platform toolset doesn't handle Z3 files that are under 65,536 bytes for the TI properly. The Z3 file needs to be padded to 64K and be in 512 byte chunks before being converted to the TI. This will fix all the smaller Z3 files that may be generated by PunyInform. Forgot to post this update for my XB tools. Edited June 15, 2023 by Torrax 3 Quote Link to comment Share on other sites More sharing options...
fredrik Posted June 15, 2023 Share Posted June 15, 2023 I'm the site owner. Thanks for your efforts! If you send me working disk images for games in the collection, I'll update the collection. Note that these are the games in the collection: A1RL0CK, by Marco Innocenti Blorp!, by Shawn Sijnstra A Clean Getaway, by Michael Bub The Fantasy Dimension, by Johan Berntsson Lucid Night, by Dee Cooke Submarine Sabotage, by Garry Francis I.e. Falling to Pieces is not part of the collection, but Lucid Night is. 2 2 Quote Link to comment Share on other sites More sharing options...
fredrik Posted June 15, 2023 Share Posted June 15, 2023 BTW, for both Lucid Night and Submarine Sabotage I used z3 files which were exactly 64 KB in size, and Ox said they still didn't work? 1 Quote Link to comment Share on other sites More sharing options...
OX. Posted June 15, 2023 Author Share Posted June 15, 2023 3 hours ago, Torrax said: Okay used my own tools, downloaded and converted the following PunyJam #3 entries: A1RL0CK: https://jpking.itch.io/a1rl0ck Blorp!: https://sijnstra.itch.io/blorp A Clean Getaway: https://bud1oo.itch.io/clean-getaway Falling Pieces: https://g0blin.itch.io/falling-to-pieces The Fantasy Dimension: https://johanberntsson.itch.io/the-fantasy-dimension Submarine Sabotage: https://warrigal.itch.io/submarine-sabotage Since I'm using my own toolset should I post the files here or send them to the site owner. It seems that the multi-platform toolset doesn't handle Z3 files that are under 65,536 bytes for the TI properly. The Z3 file needs to be padded to 64K and be in 512 byte chunks before being converted to the TI. This will fix all the smaller Z3 files that may be generated by PunyInform. Forgot to post this update for my XB tools. Great stuff Torrax, can you post the fixed disk image links here as well please? 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted June 15, 2023 Share Posted June 15, 2023 Definitely post the files here too--multiple online sources for useful data is a good thing (unless the data originator requests otherwise). 1 Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 16, 2023 Share Posted June 16, 2023 (edited) The Lucid Night page only has the Z5 file. Here are the PunyJam #3 Contest files plus the too late "Falling Pieces" which is mentioned on their web page. There are disk images plus a set of folders for Classic99. I just finished making the disk images with TI99DIR. Disk Layout: INF Geneve MDOS 80C Infocom Loader INF-DOC Geneve MDOS 80C Infocom Loader DOC's LOAD XB Auto-LOAD TIZIL40 TI Z3-ZIL 9918A 40C Interpreter EA-OPT5 Part 1 TIZIL41 TI Z3-ZIL 9918A 40C Interpreter EA-OPT5 Part 2 TIZIL80 TI Z3-ZIL 9938 80C Interpreter EA-OPT5 Part 1 TIZIL81 TI Z3-ZIL 9938 80C Interpreter EA-OPT5 Part 2 TIZILF18A TI Z3-ZIL F18A 80C Interpreter EA-OPT5 Part 1 TIZILF18B TI Z3-ZIL F18A 80C Interpreter EA-OPT5 Part 2 ZDAT1 TI Z3-DAT Format - Split File #1 ZDAT2 TI Z3-DAT Format - Split File #2 Your choice of format to download ZIP or 7-Zip. The 7z file is a quarter of the size of the ZIP. Enjoy PunyJam3_Contest.zipPunyJam3_Contest.7z Edited June 24, 2023 by Torrax Fixed Disk Layout Description 5 Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 16, 2023 Share Posted June 16, 2023 Oops it was "The Fantasy Dimension" that was the too late entry. Had the wrong "F" named game. "Falling to Pieces" placed 5th out of 8 entries. Here's the url: https://itch.io/jam/punyjam-3 1 Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 16, 2023 Share Posted June 16, 2023 Note to self read the INFO-DOC dummy!! Updated disk info. Disk Layout: INF Geneve MDOS 80C Infocom Loader (rename ZDAT1/ZDAT2 to GAME1/GAME2) INF-DOC Geneve MDOS 80C Infocom Loader DOC's LOAD XB Auto-LOAD TIZIL40 TI Z3-ZIL 9918A 40C Interpreter EA-OPT5 Part 1 TIZIL41 TI Z3-ZIL 9918A 40C Interpreter EA-OPT5 Part 2 TIZIL80 TI Z3-ZIL 9938 80C Interpreter EA-OPT5 Part 1 TIZIL81 TI Z3-ZIL 9938 80C Interpreter EA-OPT5 Part 2 TIZILF18A TI Z3-ZIL F18A 80C Interpreter EA-OPT5 Part 1 TIZILF18B TI Z3-ZIL F18A 80C Interpreter EA-OPT5 Part 2 ZDAT1 TI Z3-DAT Format - Split File #1 ZDAT2 TI Z3-DAT Format - Split File #2 2 Quote Link to comment Share on other sites More sharing options...
OX. Posted June 16, 2023 Author Share Posted June 16, 2023 6 hours ago, Torrax said: The Lucid Night page only has the Z5 file. I wonder if the z3 file could be obtained and converted back from either the C64 or BBC versions on that page? Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 16, 2023 Share Posted June 16, 2023 Looks like the C64 and BBC are using the Ozmoo interpreter which can handle the Z5 format. From the the Ozmoo page: Ozmoo supports version 1, 2, 3, 4, 5, 7 and 8 of Z-code. This means you can run all but version 6 games (version 6 = Infocom games with graphics). 1 Quote Link to comment Share on other sites More sharing options...
OX. Posted June 16, 2023 Author Share Posted June 16, 2023 2 hours ago, Torrax said: Looks like the C64 and BBC are using the Ozmoo interpreter which can handle the Z5 format. From the the Ozmoo page: Ozmoo supports version 1, 2, 3, 4, 5, 7 and 8 of Z-code. This means you can run all but version 6 games (version 6 = Infocom games with graphics). Ah well that's probably that then, unless the author is willing to supply a Z3 version. Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 18, 2023 Share Posted June 18, 2023 New files posted above. Final Release. Updated menu & descriptors. Added slashed zero to interpreters. Makes the zero in A1RL0CK more obvious. Thinking about a new font for the interpreters. Not liking the lower case descenders. Character test adventure: !ADV.7z A1RL0CK with Intro Pic: A1RL0CK_PIC.zip 5 Quote Link to comment Share on other sites More sharing options...
fredrik Posted June 23, 2023 Share Posted June 23, 2023 The z3 version of Lucid Night was used for all platforms in this collection. You should find it in the DOS (or MSDOS?) folder, possibly with a generic name like story.dat.it may also be in the Modern folder. My server is unfortunately down at the moment, but I should get it up in a day or two. 2 Quote Link to comment Share on other sites More sharing options...
fredrik Posted July 2, 2023 Share Posted July 2, 2023 My server is back online, and I have updated the collection with the new disk images for TI99/4a. Many thanks to Torrax for the help! 3 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted July 3, 2023 Share Posted July 3, 2023 (edited) 11 hours ago, fredrik said: My server is back online, and I have updated the collection with the new disk images for TI99/4a. Many thanks to Torrax for the help! Great Where can I find it ? OK, found it Edited July 3, 2023 by Schmitzi 1 Quote Link to comment Share on other sites More sharing options...
