Classic Pac Posted June 26, 2023 Share Posted June 26, 2023 I just got a copy of the game the other day and this Sonic Fan loves it. So many games, so many I never played before. There is a lot I still need to figure out and a lot of which I found. So I figured why not start this here. Extra Lives are coins Knuckles can get an Invincibility Monitor in Sonic 1 Marble Arch 1. Just go right to the wall and climb up. I discovered it hoping to bipass most of the level, but made my discovery. Quote Link to comment Share on other sites More sharing options...
digdugnate Posted June 26, 2023 Share Posted June 26, 2023 I do like that you don't run out of lives in the games. It's neat to try to do some of the unlockable stuff (with more stuff added in Plus), too. It's worth noting that the Game Gear games look like straight ports and don't add to your 'coin count' or any unlockable stuff. Quote Link to comment Share on other sites More sharing options...
Zap1982 Posted July 2, 2023 Share Posted July 2, 2023 I kid you not but I discovered something very interesting just now which I can now not replicate but someone needs to investigate this. YOU CAN PLAY WIDESCREEN WITH LIVES VIA A GLITCH. So all I did was resume my boss battle file on Sonic CD and for some reason was greeted with the 1-2-1 level select screen. I went back and was able to access what seems like left overs from the mobile version such as menus etc. I could then start a game from the first level, in widescreen with lives. This seems to be an exploit through the boss battle as you obviously have have lives there. I did work out that initially I was holding right on dpad and button A and as the 'Egg Conveyor' title card came up it went to the level select and from there on my Palm Tree Panic Act 1 widescreen with lives. However after doing something else, I can't replicate the glitch. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted August 8, 2023 Share Posted August 8, 2023 I have all the sonic genesis games except Sonic CD. Too bad Sonic spinball and Sonic 3D Blast are not on this. Been playing with Amy. Quote Link to comment Share on other sites More sharing options...
famicommander Posted August 8, 2023 Share Posted August 8, 2023 They really should have used the Master System ROMs instead of the Game Gear ones for Sonic the Hedgehog, Sonic the Hedgehog 2, and Sonic Chaos. The zoomed in view on the Game Gear versions makes them much worse to actually play. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted August 20, 2023 Share Posted August 20, 2023 Isn't the game gear a handheld master system? Quote Link to comment Share on other sites More sharing options...
Tanooki Posted August 21, 2023 Share Posted August 21, 2023 1 hour ago, bradhig1 said: Isn't the game gear a handheld master system? Largely yes, it's close, but not quite. And I don't just mean the larger amount of colors to pull from. I don't remember the actual coding level details, but I was made aware there are some abilities other than color they do not share so doing straight ports don't work well, though largely it can be lifted, some work is needed. I'm sure a google search could dig up your answer better than that. Quote Link to comment Share on other sites More sharing options...
famicommander Posted August 21, 2023 Share Posted August 21, 2023 17 hours ago, bradhig1 said: Isn't the game gear a handheld master system? Mostly but the Master System has a higher resolution that results in a less zoomed in view of the action, which gives the player more time to react to obstacles when running at high speed or dodging enemy projectiles. The Master System has the better resolution, the Game Gear has the wider color palette Quote Link to comment Share on other sites More sharing options...
TheGameCollector Posted October 22, 2023 Share Posted October 22, 2023 (edited) Sonic Chaos for Game Gear also has different music in Gigapolis Zone than the Master System version. Edited October 22, 2023 by TheGameCollector Quote Link to comment Share on other sites More sharing options...
