Mike 800 Posted July 7, 2023 Share Posted July 7, 2023 Hi, I have just found my Atari 800 and disk drive in our loft. They both appear to start. Does anyone have any experience of an adaptor that will convert output to HDMI? Many thanks in advance, Mike Quote Link to comment Share on other sites More sharing options...
+MrFish Posted July 7, 2023 Share Posted July 7, 2023 If you search, there should already be at least a handful of threads on the subject here. Also, connecting an 800 to HDMI isn't going to differ (in most cases) from connecting an 800XL or 65/130XE to the same. So, if you find some threads talking about those machines, it will generally apply to your 800. Quote Link to comment Share on other sites More sharing options...
ACML Posted July 7, 2023 Share Posted July 7, 2023 (edited) 3 hours ago, Mike 800 said: Hi, I have just found my Atari 800 and disk drive in our loft. They both appear to start. Does anyone have any experience of an adaptor that will convert output to HDMI? Many thanks in advance, Mike This is inexpensive and works pretty good. Best results are found using S-video input vs composite. https://www.amazon.com/Tendak-Composite-S-Video-Converter-Upscaler/dp/B00V2ULHBS/ref=sr_1_2_sspa?keywords=s-video+to+hdmi+converter&qid=1688752044&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 Edited July 7, 2023 by ACML Quote Link to comment Share on other sites More sharing options...
scitari Posted July 7, 2023 Share Posted July 7, 2023 I have two posts on how to do this. I highly recommend the RetroTINK (second link) if you can afford it. Connect Your Atari Computer to an LED Screen (30-60 mins) – Atari Projects Purchase a RetroTINK for Conversion to Digital Video (10-15 mins) – Atari Projects 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted July 8, 2023 Share Posted July 8, 2023 On 7/7/2023 at 10:45 AM, ACML said: This is inexpensive and works pretty good. Best results are found using S-video input vs composite. https://www.amazon.com/Tendak-Composite-S-Video-Converter-Upscaler/dp/B00V2ULHBS/ref=sr_1_2_sspa?keywords=s-video+to+hdmi+converter&qid=1688752044&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 I noticed the following: "Upgrade Version: HDMI output is optional at 720P / 60Hz or 1080P / 60Hz 480i 480P/576P" Does the model you have include the additional output resolutions? If so, how do you select them -- the picture of the device shown only selects 720/1080. I think 480 would be very handy on large monitors. Quote Link to comment Share on other sites More sharing options...
ACML Posted July 8, 2023 Share Posted July 8, 2023 2 hours ago, Larry said: I noticed the following: "Upgrade Version: HDMI output is optional at 720P / 60Hz or 1080P / 60Hz 480i 480P/576P" Does the model you have include the additional output resolutions? If so, how do you select them -- the picture of the device shown only selects 720/1080. I think 480 would be very handy on large monitors. I think its just saying it will take a 480i or 480P/576P analog input (S-video or composite) and output (scaled correctly) to 720P or 1080P. 1 Quote Link to comment Share on other sites More sharing options...
griff3125 Posted July 8, 2023 Share Posted July 8, 2023 I'm assuming it's an original 800 and not the XL? If so, get yourself a decent well shielded S-Video cable, I'd recommend the one from Hercules.... https://www.herculesworkshop.net/atari and commodore video cables.html And then I'd recommend the Retrotink 2x, you may be able to find t cheaper on eBay or elsewhere but this is the official site.... https://www.retrotink.com/product-page/retrotink-2x-pro It scales beautifully, has several options for the ratio and scaling and has worked with every monitor and TV I've thrown it at. I've been through soooooo many crap HDMI converters on Amazon, in the long run I'd really recommend avoiding the headaches and grabbing the 2x. You might also consider the SIO2SD or SDrive Max, maybe the fujinet. Unless you're a purist and want everything on floppy, these inexpensive USB alternatives give you access to the entire library in one shot, every game, app, the whole enchilada. Anyhow, enjoy the 800, it's an absolutely wonderful machine and a piece of history! Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 8, 2023 Share Posted July 8, 2023 (edited) Here is a cheaper alternative to retrotink (latter if I recall isn't easily sourced outside of the US). I used this with my A8 setups when I first got back into the atati scene a couple of years back. (Since have gone the svideo way with various mods (UGV), also rgb (VBXE) and of course the excellent Sophia 2 DVI). Always get the best signal out of the A8 (eg svideo), to go into your chosen upscaler. As an external plug and play alternative to mods, and cheaper than retrotink, retroscaller 2 is pretty good. Retroscaller 2: https://www.amazon.co.uk/Dasing-Retroscaler2X-Converter-Line-Doubler-Consoles/dp/B0B31874RK Edited July 8, 2023 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Luke210 Posted July 8, 2023 Share Posted July 8, 2023 46 minutes ago, Beeblebrox said: As an external plug and play alternative to mods, and cheaper than retrotink, retroscaller 2 is pretty good. No, it's not good. It's horrible. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 8, 2023 Share Posted July 8, 2023 53 minutes ago, Luke210 said: No, it's not good. It's horrible. Ah, no worries. I seem to recall at the time I found it (Retroscaller 2) OK. Been a while mind. As I say I prefer modding the machines over outputting to upscalers. Highly recommend UGV and of course Sophia 2. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted July 9, 2023 Share Posted July 9, 2023 14 hours ago, griff3125 said: I'm assuming it's an original 800 and not the XL? If so, get yourself a decent well shielded S-Video cable, I'd recommend the one from Hercules.... https://www.herculesworkshop.net/atari and commodore video cables.html I thought Hercules went out of business several months ago? Was that announcement premature? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 9, 2023 Share Posted July 9, 2023 9 minutes ago, bfollowell said: I thought Hercules went out of business several months ago? Was that announcement premature? Robert's website is still up but I suspect it's just not been decommissioned as yet. Would love it if he was still trading. Quote Link to comment Share on other sites More sharing options...
