Dantaipan Posted July 29, 2023 Share Posted July 29, 2023 I would not sacrifice a controller like this again these days but 20+ years ago when I did it there seemed to be no end to supply. I pulled it out for the first time in many years. All the mylar contacts needed a clean but after that it still works great. It sure makes Kaboom hell a lot easier to play. Did anyone else do this hack? 4 Quote Link to comment Share on other sites More sharing options...
K-Rod 13 Posted July 29, 2023 Share Posted July 29, 2023 Did you make it or did you buy from somewhere/someone? I like the idea. Quote Link to comment Share on other sites More sharing options...
Dantaipan Posted July 29, 2023 Author Share Posted July 29, 2023 (edited) 28 minutes ago, K-Rod 13 said: Did you make it or did you buy from somewhere/someone? I like the idea. I made it but it has been so long I don't really remember the details. I am sure they are buried way back in this forum somewhere. Basically it involves replacing the pot that controls left-right with one that you can attach a knob to. Edited July 29, 2023 by Dantaipan Quote Link to comment Share on other sites More sharing options...
TrekMD Posted July 29, 2023 Share Posted July 29, 2023 It looks very nice. I know some folks have made paddle controllers for the 5200 as well. Cool idea for games that truly work better with paddle controllers. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 20, 2023 Share Posted August 20, 2023 I got this from ebay about 7 years ago for like 50 bucks. http://mvvg.blogspot.com/2016/01/custim-5200-paddle.html?m=1 Quote Link to comment Share on other sites More sharing options...
Dantaipan Posted August 21, 2023 Author Share Posted August 21, 2023 6 hours ago, 0078265317 said: I got this from ebay about 7 years ago for like 50 bucks. http://mvvg.blogspot.com/2016/01/custim-5200-paddle.html?m=1 That is quite the hack. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 21, 2023 Share Posted August 21, 2023 25 minutes ago, Dantaipan said: That is quite the hack. Yes he did good job. Just missing 3 buttons. But it's only the most often buttons used for paddle games he said. Quote Link to comment Share on other sites More sharing options...
juansolo Posted September 1, 2023 Share Posted September 1, 2023 (edited) On 7/29/2023 at 1:42 AM, Dantaipan said: Did anyone else do this hack? Yep. Had a controller where the stick was completely broken so no saving it. Turned it into a Pole Position controller (switch on the side changes gear). Buttons are on the other side. Everything else is connected as normal. Really good for paddle games. Edited September 1, 2023 by juansolo 2 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted September 1, 2023 Share Posted September 1, 2023 I made this one last year for a client. They sent in a set of 2600 paddles with broken plastics so I could use the pot and knob from them to make one good looking and working 5200 paddle controller. I found and used a couple of washers to fit within the center space to keep the pot stem centered, and a larger washer to lock it all together inside. I was able to reuse the controller boot to hide the nuts and washers holding it all together and was able to set it so it was quite near flush with everything making for a pretty stock look when it was done. If I were to try and do this again though, I think it would be best for someone to 3D print a bracket that would more easily fit in the space and secure the pot better etc. Would make it quite an easy task for those wanting one for breakout, or pole position...etc. 3 Quote Link to comment Share on other sites More sharing options...
RB5200 Posted September 2, 2023 Share Posted September 2, 2023 So roughly about 15 years ago, I did the 2600 paddle pot in the 5200 controller hack. And was really happy, untill I started to use it, to me there was just to many things I didn't like about it, the only thing I was really happy about was the look of it. So mostly with pole position in mind, I wanted something that felt better and could shift the gears, without external switches, it needed to look like it was factory made. So this is what I did, factory 5200 pots in there normal locations, the upper pot modified for switching gears, tied to a internal micro n/o switch on lower right side, and gear drive to run the lower pot. So since we're sharing here's mine. And then only a couple of years ago I made a twin brother, cause the one was lonely, lol. 3 Quote Link to comment Share on other sites More sharing options...
zylon Posted September 11, 2023 Share Posted September 11, 2023 I used a, then cheap and plentiful, SVAII controller for mine. 1 Quote Link to comment Share on other sites More sharing options...
