prisbear Posted July 29, 2023 Share Posted July 29, 2023 I'm working on a fz-1 I received with a bunch of consoles. When I power it on I get a high pitched 1 second buzz from tv speakers and a black screen, it seems to be outputting something as my tv goes from no signal found screen brief flicker then black screen. Happens on both composite and svideo. Drive is spinning up and green access light is on. I've already fully recapped it and triple checked my soldering and nothing changed so I'm thinking caps weren't the problem. Power output seems fine as well. I'm pretty unfamiliar with this system so I'm not really sure where to go from here. Quote Link to comment Share on other sites More sharing options...
Wing_Commander Posted August 6, 2023 Share Posted August 6, 2023 On 7/29/2023 at 10:53 AM, prisbear said: I'm working on a fz-1 I received with a bunch of consoles. When I power it on I get a high pitched 1 second buzz from tv speakers and a black screen, it seems to be outputting something as my tv goes from no signal found screen brief flicker then black screen. Happens on both composite and svideo. Drive is spinning up and green access light is on. I've already fully recapped it and triple checked my soldering and nothing changed so I'm thinking caps weren't the problem. Power output seems fine as well. I'm pretty unfamiliar with this system so I'm not really sure where to go from here. Go to the 3DO discord and ask under "repairs"... I am sure someone can help ya therehttps://discord.com/channels/510877506744877066/908729376730927194 Quote Link to comment Share on other sites More sharing options...
