News & Firmware Update Notifications
SainT
Firmware 23.07.3060
Added extra hardware flag support to debug console
Fixed missed COVOX audio on console audio
Correctly show 144K ROMs (not as 128K)
Added @460 to YM2151 mapper tag
Removed
There is an issue with some of the menu items being messed up, I'm removing this update until I've got the time to look into it.
Edited by SainT
  • Like 6
  • 2 weeks later...
Firmware 23.08.0858
Corrected AV-OUT TIA volume such that max volume matches the expected console volume
Changed default UI polling to left port only, not both due to ghost button presses on right port
Added per-game saving of audio, video and break settings
  • Like 8
  • Thanks 4
  • 2 weeks later...
Firmware 23.08.1839
Fixed dual POKEY bug, 2nd POKEY now working
More Details
The only dual POKEY audio demo which I've actually noticed a difference in (thanks to @darryl1970 for pointing it out) is the Popcorn audio demo. Other dual POKEY demos I can't hear any difference, which is odd given the 2nd POKEY wasn't actually producing any audio!
Edited by SainT
  • Like 4
Firmware 23.08.2562
Overhauled audio mixing to improve flexibility
Streamed audio (BupChip) now pauses correctly on break
More Details
There is now support for individual volume control of each POKEY as well as the streamed (BupChip, etc...) audio. For AV out the TIA is also mixed as the 7800 does, so you have external audio sources which are mixed together (POKEY, YM, COVOX, ADPCM) then this is mixed with the TIA last. This means AV out now matches what you hear through the console, however you have control over the TIA volume on AV out as well.
One of the more useful features of the new mixing is how the channels are mixed. All channels are mixed as a percentage by their volume and this mix then normalised. The resulting volume is then attenuated by the highest volume in the mix. The upshot of this is, if you turn down POKEY2 to zero, it no longer contributes to the mix and other sounds become relatively louder. In situations where you have dual POKEY, but POKEY2 is only used for IRQ's, then you can remove it from the mix to gain some more volume on other sound sources. When using AV out you can also remove the TIA entirely when it's not used to boost the volume (and quality) of the other sound sources. Audio devices which are not enabled are also shown as zero volume and cannot be altered in the audio volume menu.
For people who are only interested in playing the more mainstream games, you wont notice a difference with this update. However for games which use multiple audio sources and POKEY's just for IRQ's you can tweak things to get the most out of the audio. Where you are using internal audio through the console this is particularly useful and Portal is a good example of this. While the TIA is still overpowering on a stock PAL console due to the audio balance, you can at least tweak volumes to get the best out of it. And when you are using AV out you can of course drop the TIA volume and get it perfect.
Edited by SainT
  • Like 5
  • 2 months later...
Firmware 23.11.0741
Fixed bug in previous firmware causing the POKEY to be out of tune in some circumstances.
Most notable in the title / menu music on E.X.O., was fine previously in 23.08.1839.
Edited by SainT
  • Thanks 3
  • 3 weeks later...
Firmware 23.11.2863
Added support for 2600 EF mapper (Zippy the Porcupine)
Added auto-fix for bad headers for known ROMs
More Details
2600 EF mapper games are now running, most notably Zippy the Porcupine!
And given quite a few people have had issues with 7800 games not running and being confused by the incorrect A78 headers out there I've added known good mapper settings. Any known ROM's with incorrect mapper settings will now be corrected and you will get a warning about the bad header.
Edited by SainT
  • Like 10
