newTIboyRob Posted July 31, 2023 Share Posted July 31, 2023 Does anyone remember how to list files from the CAT command so they appear horizontally instead of vertically on the screen? This one disk I have has a slew of files and I would like to view them all at one time in PR#3 80 column mode. (I assume this command would also work going back to 40 column using PR#0) Thanks Quote Link to comment Share on other sites More sharing options...
Iamgroot Posted August 1, 2023 Share Posted August 1, 2023 (edited) You can do it in Applesoft by reading the file names into an array, then printing the array using a semi-colon and HTAB instead of a return. The CAT command by itself cannot print multiple files horizontally. Since file names can be 15 characters, and 1 for a space, 5 columns of file names can be displayed. You can limit the files displayed by using the ,T directive, such as CAT,TDIR or CAT,TTXT or CAT,TBAS CAT,TSYS CAT,TBIN Edited August 1, 2023 by Iamgroot Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 1, 2023 Author Share Posted August 1, 2023 I understood the terms you mentioned, but I don't know how to work that into a basic program. When you have a min, could you type out a program like that with some dummy file names? Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 1, 2023 Author Share Posted August 1, 2023 I don't know if this is exactly what you meant, as it does not use HTAB nor the CAT command within the program, but it does use the array concept, read and data statements: 5 HOME 10 FOR X=1 TO 6 20 READ F$ 30 PRINT F$; " "; 40 NEXT X 50 DATA FILE1,FILE2,FILE3,FILE4,FILE5,FILE6 achieving... FILE1 FILE 2 FILE3 FILE4 FILE5 FILE6 But what I was originally aiming for was using the CAT command within that program to achieve that same result. You mentioned that the CAT command by itself cannot print multiple files horizontally, but how exactly would it appear in the program used with HTAB and ; ? So it would be like... it is searching for a file, found it, listed it, found the next one, but listed it horizontally, etc. Would you tweak the program for me or show me what you came up with? Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 1, 2023 Author Share Posted August 1, 2023 Then once we nail the above program, I would like to just add one more concept in there which is using the GET K$ with the CAT command so that let's say in 40 column, there are 50 total files on the disk, but after, say file #15 is listed from the CAT, we had inserted the GET K$ command using it as a pause with a statement of "Press Any Key To Continue", then once any key is pressed, the CAT command continues listing the remaining file #'s 16 through 50. Is interrupting the CAT command with the GET K$ key strike concept like that even possible? Over my head, but maybe not over yours! Groot, see what you can do here and with the above, and/or if anyone else can help with the 2 "challenges"? Quote Link to comment Share on other sites More sharing options...
MarkO Posted August 2, 2023 Share Posted August 2, 2023 21 hours ago, Iamgroot said: You can do it in Applesoft by reading the file names into an array, then printing the array using a semi-colon and HTAB instead of a return. The CAT command by itself cannot print multiple files horizontally. Since file names can be 15 characters, and 1 for a space, 5 columns of file names can be displayed. You can limit the files displayed by using the ,T directive, such as CAT,TDIR or CAT,TTXT or CAT,TBAS CAT,TSYS CAT,TBIN DOS 3.3 can have 30 Character File names, with Spaces.. ProDOS is limited to 15 Characters.. The CATALOG Command in ProDOS is better on 80 Column, use the CAT Command for 40 Columns. I would think that a Driver for ProDOS could be made to get a Double Wide CAT Catalog... MarkO Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted August 4, 2023 Share Posted August 4, 2023 Under ProDOS-8, you can OPEN a directory and READ it and get the same data a CATALOG would give you. You can then parse that into a columnar format. I could prolly bang something together but it'd take some time. 1 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 6, 2023 Author Share Posted August 6, 2023 Oh, that is interesting The Usotsuki, I wasn't aware, as the Prodos I have is an oldie, I think 1.0.2. It's ok, you don't have to make any program, but I do appreciate your offer, thank you. Quote Link to comment Share on other sites More sharing options...
