CORTEX BASIC
i have been playing around with Cortex BASIC to get an idea of what it is capable of doing. Here is a video showing it running a LINES program. It appears that the Cortex interpreter is contained within expansion ram. If so, it may be possible to save a Cortex BASIC program as an EA5 program. If that is possible, then it may be possible to save a Cortex program as a cartridge. But that is a lot of ifs and only time will tell.
Edited by senior_falcon
  • Like 10
4 hours ago, Asmusr said:
Unfortunately it only frees up 14K.
Cortex BASIC includes a system command ("NEW sys(7)") that frees an additional 1K of RAM, leaving a total of 15,446 bytes free when running from FinalGROM, 6358 bytes when running entirely from RAM (very desirable vis performance when running on a console equipped with 16-bit RAM). Combining the latter with a SuperCart for 8K of fast integer storage opens up a lot of possibilities - successfully running the full BYTE sieve using an 8192 element array, for example, which can't be done in Extended BASIC even with expansion RAM.
Also - Running Cortex is probably the fastest way to do floating point math on the TI - much faster than calling console routines in Forth or assembly.
Is it using a much smaller floating point number format Bill?
Posted (edited)
Three times is a charm!
When I looked at it with the debugger, it looked like a normal TI format number, but of course, I wasn't paying attention to how many bytes were used. Is this Radix 100 like the TI uses, but with 6 bytes total instead of 8?
I actually found the 'maths' a bit surprising. If you print powers of 2 you get:
16
32
64
128
256
512.00000001
1024
2048
4096.0000001
8192.0000001
16384
32768.000001
65535.999999
Although the errors are very small, I'm just used to the values being correct as per TI BASIC.
Are you multiplying by constant 2, or taking 2^n?
2 has an exact representation: it's just exponent 1 and mantissa 1.
But 2^n is likely done by a power series approximation of log2. Can you show the source for ^ / pow /exp?
It may be the decimal format: if it prints  more decimal digits than the mantissa implies. It happens when the last remainder that  is partly beyond the precision. .
I was doing 2^n. Source says "Raise (R1) to the power (R2) using log and exponential functions" and I can see a hard-coded value for log2 in the source. So would TI BASIC do it the same way?
One of the great things about BASIC on the TI99 is the numerical accuracy.
10 X=0
20 X=X+.1
30 PRINT X
40 IF X=1 THEN 60
50 GOTO 20
60 END
On the TI this stops when X=1. On the TRS80 this does not stop because X never equals 1 exactly. I think this is true for Apple 2 and the Commodores as well.
I haven't tested Cortex yet to see how it behaves.
This is the usual IEEE 754 disease. People are often surprised to hear that all the single-decimal numbers  0.1, ... 0.9 are approximations with the exception of 0.5 which is precisely representable ... and that our TI, in contrast, can encode all of them exactly.
While the radix 100 format is utterly slow, it allows us to encode all interesting numbers without approximation - interesting in the sense that I'd like to use them as a numerical constant in the program. I'm not interested in 0.02734375, although this can be done with IEEE, but rather in 0.1 or 3.21 or the like.
7 minutes ago, senior_falcon said:
In my post above, the program stops when X=1, just like in TI BASIC/XB.
However, if you remove line 40 so the program does not stop, by the time you get to 2, the value printed is 1.999999999
Interesting...
How did that happen?
