newTIboyRob Posted August 2, 2023 Share Posted August 2, 2023 Hello all, I recently brought my TL/3 back to life. I have a version of DOS 3.3 on a 3.5 floppy, just one single drive and brand new DS DD disks. I tried to just type FORMAT at the A>prompt with the DOS disk still inside, but it brings back the message: Drive letter must be specified. Is that floppy drive drive A or B or neither? I know the drive is working perfectly because I have used the Deskmate Series of disks in it. In short, how do I format a blank disk, in other words, what exactly do I need to type? Please advise, thanks. Quote Link to comment Share on other sites More sharing options...
Michael Kline Posted August 2, 2023 Share Posted August 2, 2023 Format A: Make sure you write protect your DOS master disk so that you don't accidentally blank your master. 2 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 2, 2023 Author Share Posted August 2, 2023 Do I take the DOS out and put the blank in and then type FORMAT A: or Do I leave the DOS in, type FORMAT A: and then it will ask me to insert the disk to be formatted? Quote Link to comment Share on other sites More sharing options...
Michael Kline Posted August 2, 2023 Share Posted August 2, 2023 (edited) You'll need the DOS disk in the drive so that the computer loads the command into memory. You will then see a prompt to press Enter to continue. BEFORE pressing Enter, that is when you swap out the disks. When the Disk is formatted, then swap it out with the DOS disk to execute any other commands or to load BASIC. Depending on what you will do next. If memory serves, I sent you a link for MS/DOS 3.3. You'll definitely want to go through it. https://archive.org/details/epson-ms-dos-3.3-ref/page/n259/mode/2up Edited August 2, 2023 by Michael Kline 1 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 3, 2023 Author Share Posted August 3, 2023 Ah yes, I neglected the infamous colon. FORMAT A: did the trick. Thank you Michael! 1 Quote Link to comment Share on other sites More sharing options...
