Macross_VF1 Posted August 3, 2023 Share Posted August 3, 2023 (edited) Yeah, as the title says, I need to know the size, or rather length, of the flat drive belt for the Hong Kong BPA7YJ Atari 1010 cassette deck. I know the width, it's about 2.8mm, but my belt is so old and stretchy that it has been lengthened quite a bit and is on the very verge of falling apart. Edited August 3, 2023 by Macross_VF1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted August 3, 2023 Share Posted August 3, 2023 You can just buy the specific 2 x belt pack so no need to measure. In the UK on ebay they are common and cheap. https://www.ebay.co.uk/itm/166169815752 Quote Link to comment Share on other sites More sharing options...
Macross_VF1 Posted August 3, 2023 Author Share Posted August 3, 2023 30 minutes ago, Beeblebrox said: You can just buy the specific 2 x belt pack so no need to measure. In the UK on ebay they are common and cheap. https://www.ebay.co.uk/itm/166169815752 The problem is that I have already bought a set but got the wrong one so in order for the seller to supply me with the correct one he needs the correct dimensions. Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 3, 2023 Share Posted August 3, 2023 (edited) 39 minutes ago, Beeblebrox said: You can just buy the specific 2 x belt pack so no need to measure. In the UK on ebay they are common and cheap. https://www.ebay.co.uk/itm/166169815752 That is not the right set for the flat belt version of the 1010. I bought an assortment lot from Aliexpress and in that lot are the right belts (the 3mm lot): https://www.aliexpress.com/item/1005001308047721.html/ These lots are very cheap and contain multiple belts of the same size, so for just € 2.65 multiple 1010s can be repaired 🙂 Edited August 3, 2023 by Fred_M 1 Quote Link to comment Share on other sites More sharing options...
manterola Posted August 3, 2023 Share Posted August 3, 2023 This is for the Hong Kong version with flat belt. I found an audio specialist store that sell flat belts and I play my chances and got 2 of different size... Both worked quite good... I will find the info and paste it here... Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted August 3, 2023 Share Posted August 3, 2023 Thanks all. Good to know as I assumed there was just the one set for all 1010s. Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 3, 2023 Share Posted August 3, 2023 (edited) 31 minutes ago, Beeblebrox said: Thanks all. Good to know as I assumed there was just the one set for all 1010s. Nope There are 3 versions: 1010 Japan square belt 1010 Hong Kong square belt 1010 Hong Kong flat belt (only the "flywheel" belt is flat, other belts in this 1010 are square) All belts are generic ones and can be bought very cheaply on Aliexpress and other big electrical component suppliers. The webshops that are selling specific sets are making a lot of money on these And do know that the belts do not have to be the exact same size, a little more loose or tight is not a problem. Belts are not rocket science Edited August 3, 2023 by Fred_M typo and pictures added 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted August 3, 2023 Share Posted August 3, 2023 Three?!?! I didn't know HK had two different mechs. Do we have pics of the various versions? Edit: Why yes we do: Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 3, 2023 Share Posted August 3, 2023 8 hours ago, Macross_VF1 said: Yeah, as the title says, I need to know the size, or rather length, of the flat drive belt for the Hong Kong BPA7YJ Atari 1010 cassette deck. I know the width, it's about 2.8mm, but my belt is so old and stretchy that it has been lengthened quite a bit and is on the very verge of falling apart. Here you are 🙂 Quote Link to comment Share on other sites More sharing options...
Macross_VF1 Posted August 3, 2023 Author Share Posted August 3, 2023 2 hours ago, Fred_M said: Here you are 🙂 Thank you, that was exactly what I needed! Quote Link to comment Share on other sites More sharing options...
manterola Posted August 3, 2023 Share Posted August 3, 2023 This is the thread about the 1010 flat belt. and this is the new url: 79-10.55 in stock = 60 (audiolabga.com) part no: 79-10.55 measurement: 10.5" x .025" x .125" Quote Link to comment Share on other sites More sharing options...
