thedocbwarren Posted August 13, 2023 Share Posted August 13, 2023 I'm having a lot of trouble getting the BlueScsi V2 to show some kind of drive on the desktop. The images are working (according to the log) but I don't see a drive. I imagine there must be something missing. I followed the setup for Ataris for the INI file. Any ideas? Is this a driver issue or something? Quote Link to comment Share on other sites More sharing options...
Fadest Posted August 13, 2023 Share Posted August 13, 2023 (edited) Which hard disk driver are you using ? For BlueScsi I think HDDriver is probably the best option. I don't know which steps you already did, so I will try not to forget one. - launch the driver program via a floppy (or another HD) so your Mega STE will recognize the hard drive - Launch the driver utility - If your image disk on the SD card is an Atari hard disk image (already formatted), skip the next step - If you have put a blank image disk on the SD Card, you must format it, and partition it. - If you have another hard drive with a driver installed on it skip the next step - You have to install the hard disk driver on your main partition so you will no more need to launch the driver from a floppy (HD will be recognised at boot) - Reboot the Mega STE, the driver should laucnh and recognise your hard drive at boot - Back on the desktop, select a floppy icon, and chose install icon option in the menu, give it the name C (uppercase) to create the icon for the C partition - Do the same for every partition - Save the desktop to keep the HD icons Edited August 13, 2023 by Fadest Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 13, 2023 Share Posted August 13, 2023 9 hours ago, thedocbwarren said: The images are working (according to the log) but I don't see a drive. What size are your partitions, there is a size limit on the ST/STE Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted August 13, 2023 Share Posted August 13, 2023 MegaSTe SCSI controller can't handle parity so that needs to be turned off in "bluescsi.ini" file. 1Gb max. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 13, 2023 Author Share Posted August 13, 2023 5 hours ago, snarkdluG said: MegaSTe SCSI controller can't handle parity so that needs to be turned off in "bluescsi.ini" file. 1Gb max. You are correct. I added to the ini file the following: [SCSI] Parity=0 ; Off MapLunsToIDs=1 ; On I get a log entry on the SD card that the partition images were mounted. I created two 512mb images. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 13, 2023 Author Share Posted August 13, 2023 12 minutes ago, thedocbwarren said: You are correct. I added to the ini file the following: [SCSI] Parity=0 ; Off MapLunsToIDs=1 ; On I get a log entry on the SD card that the partition images were mounted. I created two 512mb images. I just thought something. The SD card is 32GB. I don't know if that makes any difference considering the RPi Pico is mounting it and exporting the images. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 14, 2023 Share Posted August 14, 2023 10 hours ago, thedocbwarren said: The SD card is 32GB. I don't know if that makes any difference considering the RPi Pico is mounting it and exporting the images. The partition limit is a TOS thing, although I currently use a NetUSBEE as my hard drive interface has failed and boot from a floppy, I have to use BIGDOS, but I am using two 2GB USB drives with no problems Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 15, 2023 Author Share Posted August 15, 2023 20 hours ago, TGB1718 said: The partition limit is a TOS thing, although I currently use a NetUSBEE as my hard drive interface has failed and boot from a floppy, I have to use BIGDOS, but I am using two 2GB USB drives with no problems I'm not sure what you are saying. I did understand the TOS limit. So I wonder if there is a hardware config issue here preventing the ST from seeing the HD images? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 15, 2023 Share Posted August 15, 2023 3 hours ago, thedocbwarren said: So I wonder if there is a hardware config issue here preventing the ST from seeing the HD images? When you boot, do you see a SCSI device or any partition information from the drive as it boots. If you see nothing, then there is probably hardware problem. Even if you don't see any partitions you should at least see the hardware device and it's SCSI ID No. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 15, 2023 Author Share Posted August 15, 2023 15 hours ago, TGB1718 said: When you boot, do you see a SCSI device or any partition information from the drive as it boots. If you see nothing, then there is probably hardware problem. Even if you don't see any partitions you should at least see the hardware device and it's SCSI ID No. Ahhh, no I don't see anything. I'm booting with no drivers, just TOS and BlueSCSI connected. The old SCSI (real HDD) did boot but I think it had drivers. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 16, 2023 Share Posted August 16, 2023 9 hours ago, thedocbwarren said: I'm booting with no drivers You won't see anything without a hard disk driver, ICD Pro should see the device Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 17, 2023 Author Share Posted August 17, 2023 Ok I tried with the ICD Pro drivers and it does see the SCSI Lun 0/ID 0 Pico. I is unable to format the partition. Throws an error $47, TOS error 0. Would this likely be an image problem? Want to sincerely thank you for helping here. I love this machine and plan to start developing again on it and want to modernise the persistence devices to make this easier. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 18, 2023 Author Share Posted August 18, 2023 Bit more tinkering and it seems ICD tools can see the drive and able to kind of partition (not really) but fails trying to write at sector 2 if I wish to format a partition. I created two images in the BlueSCSI and it only sees the first as a disk. I think the issue is the image or maybe this device is just not compatible with the Atari at this point. I'm beginning to consider this and maybe if I can't get this working I'll close this project up and see what I can do from here. I don't have any idea how people run these machines these days to enjoy them as before. I had to replace the mouse as well and it's quite bad with the usb/mouse device so I think I'm running out of ways to use this machine. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 18, 2023 Author Share Posted August 18, 2023 From the logs: [10ms] Platform: BlueSCSI Pico [10ms] FW Version: 2023.01.25-release Jan 25 2023 08:22:29 Flash chip size: 2048 kB === SD Card Info === SD card detected, FAT32 volume size: 29648 MB SD Name: SL32G, MID: 0x03, OID: 0x50 0x54 === Global Config === Reading configuration from bluescsi.ini -- MapLunsToIDs is on -- Parity is disabled === Finding images in / === == Opening /HD00_512 512MB.hda for ID: 0 LUN: 0 ---- Image ready== Opening /HD10_512 512MB_2.hda for ID: 1 LUN: 0. ---> I can't see this drive on the ST ---- WARNING: file /HD10_512 512MB_2.hda is not contiguous. This will increase read latency. ---- Image ready === ROM Drive === Platform supports ROM drive up to 1692 kB ---- ROM drive image not detected === Configured SCSI Devices === * ID: 0, BlockSize: 512, Type: Fixed, Quirks: Apple, Size: 524352kB * ID: 1, BlockSize: 512, Type: Fixed, Quirks: Apple, Size: 524352kB Initialization complete!WARNING: Host used command 0x1A which is affected by drive geometry. Current settings are 63 sectors x 255 heads = 16065 but image size of 1048704 sectors is not divisible. This can cause error messages in diagnostics tools. WARNING: Host attempted read at sector 2088450+1, exceeding image size 1048704 sectors (512B/sector) Quote Link to comment Share on other sites More sharing options...
Forrest Posted August 18, 2023 Share Posted August 18, 2023 (edited) I’m a new ZuluSCSI owner with a 1040STE, so here are my comments. BlueSCSI Pico is similar to the ZuluSCSI RP2040, but not identical. 1. You are running the initial Firmware on your BlueSCSI. There have been 3 releases since then, that make lots of enhancements. You’ll find the newest releases here https://github.com/BlueSCSI/BlueSCSI-v2/releases 2. In your log file above, I see multiple references to .hda file and Apple images. This looks incorrect if you are using ICD Pro drivers, which require a .img drive drive. Try rebuilding your BlueSCSI.ini using one of the IMG types at the bottom of the list. Just my two cents. Edited August 18, 2023 by Forrest Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 19, 2023 Author Share Posted August 19, 2023 (edited) 22 hours ago, Forrest said: I’m a new ZuluSCSI owner with a 1040STE, so here are my comments. BlueSCSI Pico is similar to the ZuluSCSI RP2040, but not identical. 1. You are running the initial Firmware on your BlueSCSI. There have been 3 releases since then, that make lots of enhancements. You’ll find the newest releases here https://github.com/BlueSCSI/BlueSCSI-v2/releases 2. In your log file above, I see multiple references to .hda file and Apple images. This looks incorrect if you are using ICD Pro drivers, which require a .img drive drive. Try rebuilding your BlueSCSI.ini using one of the IMG types at the bottom of the list. Just my two cents. Got it. I may try to flash it. I have no idea how to create an image that works properly for this. I used the DD command to make a new image with no luck. dd if=/dev/zero of="HD00_512 1024mb.img" bs=512b count=4096 Edited August 19, 2023 by thedocbwarren Quote Link to comment Share on other sites More sharing options...
Forrest Posted August 19, 2023 Share Posted August 19, 2023 I would definitely update the firmware first - there are enhancements for the Atari computers Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 31, 2023 Author Share Posted August 31, 2023 On 8/18/2023 at 8:51 PM, Forrest said: I would definitely update the firmware first - there are enhancements for the Atari computers Hello, I wanted to followup. I've upgraded to latest (non-beta) firmware for V2 with no luck. Log now says: === Finding images in / === == Opening /HD00_512 1024m.img for ID: 0 LUN: 0 ---- WARNING: This image does not appear to be a valid Macintosh Device image. See: https://github.com/BlueSCSI/BlueSCSI-v2/wiki/Disk-Images ---- Image ready Obviously this is not for a Mac. It was created via DD. Using the ICD latest drivers is says unrecognizable device for Lun 0 on boot. full log: [10ms] Platform: BlueSCSI Pico [10ms] FW Version: 2023.08.10-release Aug 11 2023 01:25:40 Flash chip size: 2048 kB === SD Card Info === SD card detected, FAT32 volume size: 29648 MB SD Name: SL32G, MID: 0x03, OID: 0x50 0x54 === Global Config === Reading configuration from bluescsi.ini Active configuration: -- MapLunsToIDs is on === Finding images in / === == Opening /HD00_512 1024m.img for ID: 0 LUN: 0 ---- WARNING: This image does not appear to be a valid Macintosh Device image. See: https://github.com/BlueSCSI/BlueSCSI-v2/wiki/Disk-Images ---- Image ready === ROM Drive === Platform supports ROM drive up to 1692 kB ---- ROM drive image not detected === Configured SCSI Devices === * ID: 0, BlockSize: 512, Type: Fixed, Quirks: Apple, Size: 1048576kB Initialization complete! INFO: Pico Voltage: 3.164V. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted September 7, 2023 Author Share Posted September 7, 2023 I have been successful! After the firmware update and making the partition size closer to 512mb I have a working HDD. Next stop is getting the external Gotek to work! 1 Quote Link to comment Share on other sites More sharing options...
Raisin54 Posted December 28, 2023 Share Posted December 28, 2023 Bonjour, Pourriez-vous me dire étape par étape comment procéder s’il vous plaît ? Je suis dans la même situation que vous. Merci d’avance. Quote Link to comment Share on other sites More sharing options...
Raisin54 Posted January 1 Share Posted January 1 Le 28/12/2023 à 15 :45, Raisin54 a dit : Bonjour, Pourriez-vous me dire étape par étape comment procéder s’il vous plaît ? Je suis dans la même situation que vous. Merci d’avance. Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted January 1 Author Share Posted January 1 4 hours ago, Raisin54 said: For me, it was use a newer version of the firmware. The version I had was not working with my MSTe. After I did so I needed to make a disk imager that was under 512mb enough till it stopped complaining. Once I did, it worked perfectly and has ever since. It's not so much step by step as it's certain combos that did it for me. I used the ICD drivers vs paid stuff like HDDriver, for example. No issues so far. Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted June 18 Share Posted June 18 SO I am trying to do the same thing. You should be able to make say a 2gb or 4gb image on the SD card and then it is seen, and you can then format it or divide it into multiple 512mb partitions. I have tried to get this working with a 20mb partition or 50mb partition and have not had it working. Can you post a ZIP of your working SD card files? I would like to try them on mine. Thankyou. James Quote Link to comment Share on other sites More sharing options...
