newTIboyRob Posted August 14, 2023 Share Posted August 14, 2023 I just wanted to make sure I am not missing something here. Let's say in a basic program you have 30 lines that you decide you need to take out for a big section of the program, line #'s 100-390. One way I know that works is to just type each line # in and hit enter. But since there are quite a few, 30 entries, I'm just wondering if Applesoft basic has a quicker way to remove that group of 30 lines in one command, without doing each one individually like that? I have tried all of the following to no avail: 100-390 {enter}, DELETE 100-390 {enter} , DELETE LINES 100-390 {enter} .. all SYNTAX ERROR No quicker and easier way to do this for a program in basic? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 15, 2023 Share Posted August 15, 2023 I think a better question is, what BASIC uses DELETE like this? Quote Link to comment Share on other sites More sharing options...
Iamgroot Posted August 15, 2023 Share Posted August 15, 2023 There are quite a few books with all the Applesoft tokens. You should familiarize yourself with them. The correct command is DEL 100,390. 2 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted August 15, 2023 Author Share Posted August 15, 2023 OhhI was so close! Instead of the - it was a comma. Luckily I was able to find the Apple 2 c User's Guide book in the last box I was searching in the cellar. I also found The Creative Apple And A Guide To Programming in Applesoft, which I've been finding especially useful (the latter book didn't mention the DEL concept Groot.) And then there is the green and white covered old Applesoft manual. Yes, I know DELETE then the filename deletes the actual file. Any other books stick out in your mind to be especially good like the above? I really like programs that do with small business, like sequential files with clients and the like, which the Guide To Programming In Applesoft has. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted August 15, 2023 Share Posted August 15, 2023 (edited) (removed due to redundancy) Edited August 15, 2023 by The Usotsuki Quote Link to comment Share on other sites More sharing options...
Casey Posted August 16, 2023 Share Posted August 16, 2023 22 hours ago, OLD CS1 said: I think a better question is, what BASIC uses DELETE like this? Commodore BASIC 7.0 in the 128 uses DELETE like this, presumably because the file deletion command is SCRATCH. But it is probably an outlier... 1 Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted August 16, 2023 Share Posted August 16, 2023 GW-BASIC uses DELETE that way too. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 20, 2023 Share Posted August 20, 2023 On 8/15/2023 at 9:26 PM, Casey said: Commodore BASIC 7.0 in the 128 uses DELETE like this, presumably because the file deletion command is SCRATCH. But it is probably an outlier... I honestly feel I missed out on a lot by not programming in BASIC 7.0. I used several wedges for BASIC 2 which added some of the DOS commands and F-keys, but then came JiffyDOS. Quote Link to comment Share on other sites More sharing options...
