KrunchyTC Posted August 17, 2023 Share Posted August 17, 2023 I noticed a missing background layer, which is very odd. The left is obviously the cart video output, and the right is straight out of the console through RF. 3 Quote Link to comment Share on other sites More sharing options...
SainT Posted August 17, 2023 Share Posted August 17, 2023 Well spotted, that will be a bug of some kind in my Maria implementation. I’ll take a look at some point. 1 Quote Link to comment Share on other sites More sharing options...
SainT Posted August 18, 2023 Share Posted August 18, 2023 17 hours ago, KrunchyTC said: I noticed a missing background layer, which is very odd. The left is obviously the cart video output, and the right is straight out of the console through RF. Can you provide me a save state where this issue occurs? I'm having a play but haven't found it, and I look to be in a similar place. Quote Link to comment Share on other sites More sharing options...
Trebor Posted August 18, 2023 Share Posted August 18, 2023 1 hour ago, SainT said: Can you provide me a save state where this issue occurs? I'm having a play but haven't found it, and I look to be in a similar place. It is the start of Level 1 Round 5. A life needs to be lost though, at the beginning of the round, in order for a gem to be present to (re)acquire: 1 Quote Link to comment Share on other sites More sharing options...
SainT Posted August 18, 2023 Share Posted August 18, 2023 If someone can provide a save state, I will investigate. Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted August 18, 2023 Share Posted August 18, 2023 I think that there was a similar case on Ninja Golf with a missing background element : https://www.facebook.com/groups/29814905254/?hoisted_section_header_type=recently_seen&multi_permalinks=10160641811560255 Might not be related but thought it wise to mention it. Quote Link to comment Share on other sites More sharing options...
SainT Posted August 18, 2023 Share Posted August 18, 2023 1 minute ago, Muddyfunster said: I think that there was a similar case on Ninja Golf with a missing background element : https://www.facebook.com/groups/29814905254/?hoisted_section_header_type=recently_seen&multi_permalinks=10160641811560255 Might not be related but thought it wise to mention it. Unrelated. As far as I know that's just an incorrect ROM header (although I may be wrong), the guy contacted me on Twitter and I mentioned this but I've not had a response on if he's using the latest Trebor pack. Ninja Golf is working just fine on my NTSC machine. 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 18, 2023 Share Posted August 18, 2023 20 hours ago, KrunchyTC said: I noticed a missing background layer, which is very odd. The left is obviously the cart video output, and the right is straight out of the console through RF. What cable are you using for your 7800GD AV out that is on the left? Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted August 18, 2023 Share Posted August 18, 2023 Could it be the dark hues getting crushed due to the cable? I'll check in mine in a bit. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 18, 2023 Share Posted August 18, 2023 44 minutes ago, Muddyfunster said: Could it be the dark hues getting crushed due to the cable? I'll check in mine in a bit. This is my thought. I do know that while I did state that the Hyperkin genesis to HDMI cable works and it does, it also crushes quite a few of the darker hues and they simply just don't seem to get shown on screen. I mainly noticed it with Knight Guy as all of the background details were essentially just not being shown, but when I plugged in my s-video output, it was all there as expected. I didn't plug in my Rad2x when I noticed this but I should have now that I'm thinking about all of this... Again, I'm just asking questions here... Quote Link to comment Share on other sites More sharing options...
SainT Posted August 18, 2023 Share Posted August 18, 2023 2 hours ago, Trebor said: It is the start of Level 1 Round 5. A life needs to be lost though, at the beginning of the round, in order for a gem to be present to (re)acquire: I've got there, it looks exactly like that image both through composite and RGB AV out. Ah, PAL or NTSC? I'm testing NTSC. Quote Link to comment Share on other sites More sharing options...
KrunchyTC Posted August 18, 2023 Author Share Posted August 18, 2023 2 hours ago, -^CrossBow^- said: What cable are you using for your 7800GD AV out that is on the left? I am using the component cable that was paired with the GD. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 18, 2023 Share Posted August 18, 2023 5 minutes ago, KrunchyTC said: I am using the component cable What brand of cable and what scaler are you using? Quote Link to comment Share on other sites More sharing options...
SainT Posted August 18, 2023 Share Posted August 18, 2023 And also try turning the brightness way up or something with component, as there is definitely no missing graphics for me. Could well be your component cable is somehow wiping out the lower end colours. Quote Link to comment Share on other sites More sharing options...
KrunchyTC Posted August 18, 2023 Author Share Posted August 18, 2023 (edited) 38 minutes ago, SainT said: And also try turning the brightness way up or something with component, as there is definitely no missing graphics for me. Could well be your component cable is somehow wiping out the lower end colours. You are correct, I had the brightness way down, I forgot that I had turned it down so much. I thought that the brightness of the component output matched the RF output. My mistake! Edited August 18, 2023 by KrunchyTC 3 Quote Link to comment Share on other sites More sharing options...
