Crackers1964 Posted August 18, 2023 Share Posted August 18, 2023 Hi all, Does anyone have the password for Bios 24? The celebrate one doesn’t work. Thanks Quote Link to comment Share on other sites More sharing options...
davpa Posted August 19, 2023 Share Posted August 19, 2023 it really is Atar!C3l3br8te$50Ye4r$ that is a lowercase L between the 3s. It is a complicated password and easily mistyped. You also have to be sure your keyboard is outputting the keystrokes as some keyboards might default to using a keypad on the right half of the keyboard (typically the blue secondary letters). This can also be an issue with international keyboards. I flash and go into the BIOS multiple times a week. The password really does work. This morning I was on a conference call with someone in Brazil and he entered the BIOS (v24 even) with the password. Quote Link to comment Share on other sites More sharing options...
SoCalAttorney Posted August 26, 2023 Share Posted August 26, 2023 On 8/18/2023 at 5:45 PM, davpa said: it really is Atar!C3l3br8te$50Ye4r$ that is a lowercase L between the 3s. It is a complicated password and easily mistyped. You also have to be sure your keyboard is outputting the keystrokes as some keyboards might default to using a keypad on the right half of the keyboard (typically the blue secondary letters). This can also be an issue with international keyboards. I flash and go into the BIOS multiple times a week. The password really does work. This morning I was on a conference call with someone in Brazil and he entered the BIOS (v24 even) with the password. Any other suggestions for a moron like me? I've flashed the bios and tried this password many times, literally dozens. I've even tried use both zero and capital O after the 5. I made sure the caps lock is off and I just cant get it right. Quote Link to comment Share on other sites More sharing options...
davpa Posted August 27, 2023 Share Posted August 27, 2023 17 hours ago, SoCalAttorney said: Any other suggestions for a moron like me? I've flashed the bios and tried this password many times, literally dozens. I've even tried use both zero and capital O after the 5. I made sure the caps lock is off and I just cant get it right. One thing to make sure is that NUM LOCK is on. If the keyboard does not have a dedicated numerical pad, then the right half will have a number pad has (usually) blue letters accessed via holding an FN key or something similar. In the BIOS, those Blue Keys (the number pad) might be active and functional, so instead of typing a P or O, you are typing a 9 and 8. So be sure to have NUM LOCK on in the BIOS. My only other suggestion is to find a dirt simple keyboard than what you are using now. Something is going wrong with the input values being entered in the BIOS, which is hard to tell because all you see is *****. The BIOS password does work, and I don't have to downgrade the BIOS or any other weird walk-around I see other people doing. Quote Link to comment Share on other sites More sharing options...
davpa Posted August 31, 2023 Share Posted August 31, 2023 (edited) Ok, so I made a video where I take a VCS, one from our warehouse, flash it and update it (OS and BIOS) to the current states, and then go into the BIOS with the password. I just wanted people to see it work on a VCS that I didn't update the password or make any other changes. If you want to go right to where I type in the password, skip to 16:30. Edited September 2, 2023 by davpa fixed video link 2 Quote Link to comment Share on other sites More sharing options...
zzip Posted August 31, 2023 Share Posted August 31, 2023 There should be a pinned topic with those videos and links to downloads Quote Link to comment Share on other sites More sharing options...
