artrag Posted August 19, 2023 Share Posted August 19, 2023 My Lto Flash! isn't detected anymore by my new pc... I have moved to a new pc with windows 11 and I cannot make the Lto flash! work anymore. The gui does not detect the device, I have tried different cables and USB ports without success. I have manually installed the virtual com drivers without success... Any suggestion? Quote Link to comment Share on other sites More sharing options...
Games For Your Intellivision Posted August 20, 2023 Share Posted August 20, 2023 Have you tried running the application as an administrator? Quote Link to comment Share on other sites More sharing options...
artrag Posted August 20, 2023 Author Share Posted August 20, 2023 Not yet. I'll try asap Quote Link to comment Share on other sites More sharing options...
Rickster8 Posted August 20, 2023 Share Posted August 20, 2023 (edited) On 8/19/2023 at 1:06 PM, artrag said: My Lto Flash! isn't detected anymore by my new pc... I have moved to a new pc with windows 11 and I cannot make the Lto flash! work anymore. The gui does not detect the device, I have tried different cables and USB ports without success. I have manually installed the virtual com drivers without success... Any suggestion? Yes I had the same problem with my Windows 10, it didn't detect my LTO software. Then a user here told me the same thing that 'Games For Your Intellivision' said above. Run it as administrator. I did this and it still didn't recognize it or detect initially, but when I logged in again VOILA, everything worked perfectly..... Been working great ever since.... 👍 Edited August 20, 2023 by Rickster8 Wording Quote Link to comment Share on other sites More sharing options...
artrag Posted August 25, 2023 Author Share Posted August 25, 2023 I've just tried repeatedly to run LTOFlash.exe as administrator, but the chartridge stais not detected. Note that I cannot hear any sound when I plug in and out the USB cable in the PC port (the same cable works for other devices....) The chartridge, once in the Intellivision, works perfectly with its existing contents Any other suggestions ? Quote Link to comment Share on other sites More sharing options...
vroby Posted August 26, 2023 Share Posted August 26, 2023 Check the USB cable and change it if necessary. Maybe it's simply the door a little more precise Quote Link to comment Share on other sites More sharing options...
