Just Jeff Posted August 25, 2023 Share Posted August 25, 2023 (edited) Good Morning, I need to swap nybbles between two different bytes and have been trying to figure out some clever way to do it. Everything I try seems awkward. Does anyone have something slicker? So: These for two bytes .byte $AB ;Two sound bytes. Left ($A) cannot play, so it needs to move. .byte $CD ;Game data needs to be something like: .byte $CB .byte $DA ;So that B plays, then A plays. C and D can be any arrangement (re-assembled before use) Here's what I've come up with: RAM1 ;Swap space, no permanent game data RAM2 ;Game data .loop lda #$F0 ;2 2 Load a mask and RAM2,x ;4 5 Take the left nybble of the game data sta RAM1,x ;4 9 and store it in the swap space lda #$0F ;2 11 Load a mask and (ROM),y ;5+ 16 Take the right nybble of the sound data ora RAM1,x ;4 20 Add it to the left nybble of game data sta RAM1,x ;4 24 This byte is done. Game data in left nybble, sound in right. lda (ROM),y ;5+ 29 Load sound data asl ;2 31 Move D7 into carry rol RAM2,x ;6 37 and then into D0 or game data asl ;2 39 and repeat... rol RAM2,x ;6 45 asl ;2 47 rol RAM2,x ;6 53 asl ;2 55 rol RAM2,x ;6 61 Now the right nybble of game data is in left nybble and ;left nybble of sound data is in right. dex ;2 63 dex ;2 65 dey ;2 67 bpl .loop ;2/3 69/70 Additionally, it doesn't matter if C and D swap positions, or if their bits are reversed. They will be re-assembled before use. Also, the sound data ($AB) originates in ROM, so it cannot be manipulated until loaded. The Game data is only in RAM Edited August 27, 2023 by Just Jeff Added cycles count Quote Link to comment Share on other sites More sharing options...
glurk Posted August 25, 2023 Share Posted August 25, 2023 This code (I didn't invent it) nybble swaps a byte cleverly. Maybe you can make use of it somehow: ASL ADC #$80 ROL ASL ADC #$80 ROL 3 Quote Link to comment Share on other sites More sharing options...
Just Jeff Posted August 27, 2023 Author Share Posted August 27, 2023 (edited) Thanks! It will save 2 cycles with direct replacement. It does require using a byte of temp RAM but fortunately, that made me realize I could use that elsewhere for another 7 cycles saved. I could save another two cycles by introducing a 2nd temp byte to replace RAM1,x on the 3rd and 7th lines if I choose. Any other ideas anyone? RAM1 ;Swap space, no permanent game data RAM2 ;Game data .loop lda #$F0 ;2 2 Load a mask and RAM2,x ;4 5 Take the left nybble of the game data sta RAM1,x ;4 9 and store it in the swap space lda (ROM),y ;5+ 14 Load the right nybble of the sound data and #$0F ;2 16 apply mask sta Temp ;3 19 ora RAM1,x ;4 23 Add it to the left nybble of game data sta RAM1,x ;4 27 This byte is done. Game data in left nybble, sound in right. ;lda (ROM),y ;5+ removed ;and #$0F ;2 removed ;sta Temp ;3 removed lda RAM2,x ;4 31 and #$F0 ;2 33 ora Temp ;3 36 asl ;2 38 adc #$80 ;2 40 rol ;2 42 asl ;2 44 adc #$80 ;2 46 rol ;2 48 sta RAM2,x ;4 52 ;left nybble of sound data is in right. dex ;2 54 dex ;2 56 dey ;2 58 bpl .loop ;2/3 60/61 Edited August 27, 2023 by Just Jeff Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted September 2, 2023 Share Posted September 2, 2023 I once made a 256 byte lookup table for flipping byte patterns backwards. It's advantage was speed and needing no RAM, it's disadvantage was the high ROM usage. Not sure if it's applicable to this scenario of nybble patterns, but could be useful if ROM is plentiful. Quote Link to comment Share on other sites More sharing options...
Just Jeff Posted September 3, 2023 Author Share Posted September 3, 2023 I thought about something like that but I'd have to put it in all the banks where all the data is. Additionally, I'm not only flipping one byte, There are two bytes involved where they are flipped and switched out with the other byte- so it gets me almost nowhere.. I tried using a 16 byte table to at least flip the right nybble to the left nybble of the other byte but it didn't really help me. Thanks! Quote Link to comment Share on other sites More sharing options...
