Trioptrooper Posted September 6, 2023 Share Posted September 6, 2023 (edited) Simple way to make the Bluetooth 8bitdo DB9 adaptor to work on the Atari 2600 Without any warranty voids is to make a crossover cable. It Worked for me On Atari Junior 2600. Simply Disconnect Pin 7 from The Female side of the crossover cable with the 8BITDO and connect Pin5 from this side with 8bitdo too to Pin 7 on the Atari side of the Crossover cable All other WIREs Remain the Same. It will then enable Bluetooth controller including wake from sleep. Edited September 6, 2023 by Trioptrooper Update 2 Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted September 6, 2023 Share Posted September 6, 2023 Nifty! Just to be clear: the adapter you're referring to is this one, correct? Quote Link to comment Share on other sites More sharing options...
Trioptrooper Posted September 6, 2023 Author Share Posted September 6, 2023 (edited) Correct that's it. New 8Bitdo Retro Mini Bluetooth Classic Edition Receiver Adapter for Original Mega Drive Sega Genesis https://a.aliexpress.com/_mq3v0fu And the Male, Female DB9 Solder-free Connector 9-pin D-SUB Breakout Terminal ishttps://a.aliexpress.com/_mKEdgb0 I have several Bluetooth controls that work with this including Wiimote and an EasySMX ESM -4108. To Synchronise hold pair on remote then hold the blue button on the 8bitdo slow blue flashing should be more rapid when it Syncs it should turn solid blue and the control should rumble. Press select for 3 seconds and you will see the light on the dongle flash a couple of times to indicate it switched to 2 button mode. If the control falls asleep the Blue light will stop until you wake the controller. It should still be Synchronised. Edited September 6, 2023 by Trioptrooper Edit 1 Quote Link to comment Share on other sites More sharing options...
Trioptrooper Posted September 8, 2023 Author Share Posted September 8, 2023 2 Quote Link to comment Share on other sites More sharing options...
Trioptrooper Posted September 8, 2023 Author Share Posted September 8, 2023 (edited) This Configuration without the 8bitdo plugged into the crossover and A Wired Sega Genesis/Megadrive Controller plugged into this crossover cable also allows the use of SEGA Megadrive or GENESIS Controller's to work on the Atari 2600 when plugged into the Atari 2600 With The Megadrive control B button as Atari 2600 trigger button. Edited September 8, 2023 by Trioptrooper Quote Link to comment Share on other sites More sharing options...
Trioptrooper Posted September 11, 2023 Author Share Posted September 11, 2023 Upon further testing and updating the 8bitdo megadrive/genesis dongle to firmware 1.25 . The 8bitdo Synced to the controller but it seems a bit glitchy pressing Right on the d pad. If I use a Wired Sega Megadrive/Genesis Control with this Crossover Cable It works smoothly as Dpad and with B button as trigger. Quote Link to comment Share on other sites More sharing options...
Hawkangel Posted October 25, 2023 Share Posted October 25, 2023 Will this work on an Atari 2600 Jr? Quote Link to comment Share on other sites More sharing options...
Trioptrooper Posted February 15 Author Share Posted February 15 (edited) It is Glitchy Right Dpad with 8bitdo 2 but is ok with wired megadrive 3 button controler . MEGA 7800 with 8bitdo 2 on Junior is Good. Edited February 15 by Trioptrooper update Quote Link to comment Share on other sites More sharing options...
