H4plo Posted September 7, 2023 Share Posted September 7, 2023 (edited) Hi all, I am porting my game Tenebra (https://h4plo.itch.io/tenebra) to Atari 8-bit. I'm trying to add sound effects, but for the life of me I can't get any sound generated, no matter what I do. I have verified that sounds works in the emulator (Altirra) by playing a couple of games. I think I must be missing some initialisation steps, because even this code doesn't give me any sound: https://www.chibiakumas.com/6502/platform3.php#LessonP23 Can anyone give me an assembly listing that generates a short beep (any channels, any frequency, noise/square wave)? I just need a starting point that works, because I must be misunderstanding something. Thanks in advance! Edited September 7, 2023 by H4plo 2 Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 7, 2023 Share Posted September 7, 2023 No sound occurring can often be that Pokey isn't properly initialized. Sound initialization - store 00 in D200 thru D208, store 03 in D20F. The simplest sound, a pure tone. Store E0 in D200 (freq), store A8 in D201 (control/volume) - store 00 in D201 to stop. For a full Pokey Init, store 00 in D200 through D20F. Then 03 in D20F and C0 in D20E (to enable key/Break IRQs) Quote Link to comment Share on other sites More sharing options...
vitoco Posted September 7, 2023 Share Posted September 7, 2023 (edited) You should get simple tones in the A8 by writing to audio channel 1 at $D200 and $D201 (AUDF1 and AUDC1). Just try: lda #$80 ; Frequency sta $D200 ; AUDF1 lda #$A0+$08 ; Distortion+Volume sta $D201 ; AUDC1 Use even numbers only for distortion. Initialize as Rybags said. Edited September 7, 2023 by vitoco Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 7, 2023 Share Posted September 7, 2023 Simple assembler program, I used in a disk copy program, just wrapped it in a loop with a small delay org $2000 z sound ldy #0 ldx #20 loop dey bne loop dex bne loop jmp z SOUND .proc LDA #0 STA SOUTEMP LDA #$69 STA $D201 SO LDA SOUTEMP STA $D200 INC SOUTEMP BEQ SOUOUT LDX #0 SO1 DEX BNE SO1 BEQ SO SOUOUT LDA #0 STA $D201 RTS SOUTEMP .byte 0 .endp Quote Link to comment Share on other sites More sharing options...
mono Posted September 7, 2023 Share Posted September 7, 2023 https://forums.atariage.com/topic/320982-sfx-engine/ Quote Link to comment Share on other sites More sharing options...
tebe Posted September 7, 2023 Share Posted September 7, 2023 https://github.com/tebe6502/Mad-Pascal/tree/master/samples/a8/sound/sfx xSFX (Mad Pascal) Quote Link to comment Share on other sites More sharing options...
H4plo Posted September 8, 2023 Author Share Posted September 8, 2023 Thank you all! After initialising Pokey as Rybags suggested, all my various attempts at making a noise started working. The thing is that all the code and references I had found on the net assumed that the ROM or Basic had performed the necessary initialisations, so they didn't mention anything about it. I am running Altirra with "NoKernel" ROM and with the interrupts disabled. Now the next challenge is figuring out the keyboard scanning with no ROM and no interrupts. Thanks again! Quote Link to comment Share on other sites More sharing options...
phaeron Posted September 9, 2023 Share Posted September 9, 2023 18 hours ago, H4plo said: Thank you all! After initialising Pokey as Rybags suggested, all my various attempts at making a noise started working. The thing is that all the code and references I had found on the net assumed that the ROM or Basic had performed the necessary initialisations, so they didn't mention anything about it. I am running Altirra with "NoKernel" ROM and with the interrupts disabled. Now the next challenge is figuring out the keyboard scanning with no ROM and no interrupts. That's an odd configuration to be testing against. The NoKernel ROM in Altirra is an OS ROM that literally prints a message saying that you have no OS ROM and then halts, so you know what happened. Practically the only way you can get it these days is to delete an OS ROM image that's still registered, and it doesn't boot any disks or carts so it's not meant to run any software. Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 9, 2023 Share Posted September 9, 2023 Keyscan is automatic by Pokey if it's enabled (which it normally is) To get it going the OS generally fills D200-D20F with 00. Then set SKCTL to 03 and IRQEN to C0. Note it's not needed to have the keyboard IRQ active for keyscan to work. Although keyscan is automatic there's still some complexity in processing it, mainly due to debounce and auto-repeat. But if you're just doing a game or something that can do without repeat you can process the keys yourself. There's bits in SKSTAT that reflect key down condition which you could test during VBlank. When a key is registered you generally compare it to the previous keypress and ignore it if it's the same code within 3 frames which handles the debounce. But as phaeron says, you're generally better off using an OS. A cartridge image can be a handy way to do a program that gets control early, but autoboot Xex in most emulators will load a binary file without needing a Dos or menu loaded first. Quote Link to comment Share on other sites More sharing options...
H4plo Posted September 9, 2023 Author Share Posted September 9, 2023 (edited) 7 hours ago, phaeron said: That's an odd configuration to be testing against. The NoKernel ROM in Altirra is an OS ROM that literally prints a message saying that you have no OS ROM and then halts, so you know what happened. Practically the only way you can get it these days is to delete an OS ROM image that's still registered, and it doesn't boot any disks or carts so it's not meant to run any software. Thanks. I just wanted to make sure my code didn't depend on any ROM initialisation or services, or interrupts. Also, I am new to the Atari 8-bit scene and thought there might be people who have their emulators set up in the NoKernel mode and play the games by using the XEX autoboot feature, therefore I wanted to be certain that I was initialising everything properly. I have also tested my game with various ROMs and configurations to make sure nothing was amiss. 2 hours ago, Rybags said: Keyscan is automatic by Pokey if it's enabled (which it normally is) To get it going the OS generally fills D200-D20F with 00. Then set SKCTL to 03 and IRQEN to C0. Note it's not needed to have the keyboard IRQ active for keyscan to work. Although keyscan is automatic there's still some complexity in processing it, mainly due to debounce and auto-repeat. But if you're just doing a game or something that can do without repeat you can process the keys yourself. There's bits in SKSTAT that reflect key down condition which you could test during VBlank. When a key is registered you generally compare it to the previous keypress and ignore it if it's the same code within 3 frames which handles the debounce. But as phaeron says, you're generally better off using an OS. A cartridge image can be a handy way to do a program that gets control early, but autoboot Xex in most emulators will load a binary file without needing a Dos or menu loaded first. Yes, I only needed to detect a couple of simple keypresses. I managed it by inspecting $DF09. Thanks again everyone for your help. Edited September 9, 2023 by H4plo 1 Quote Link to comment Share on other sites More sharing options...
