EpicRain Posted September 7, 2023 Share Posted September 7, 2023 Does anyone know if it's possible to run your own games on the new Atari 2600+ machine? Would be awesome! Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted September 8, 2023 Share Posted September 8, 2023 Is it powerful enough to run things other than emulated ROMs? I'm genuinely asking. I know the VCS machine that came out a few years ago had a multicore Ryzen processor so was basically an entry level budget computer but I'm not sure about this. An app/program that allows you to code and complile homebrew for the 2600 sounds like a great idea for both. Quote Link to comment Share on other sites More sharing options...
+Karl G Posted September 8, 2023 Share Posted September 8, 2023 Anything that is powerful enough to run Stella should be powerful enough to run a dev environment, assuming that there was some way to load software, and connect a keyboard. I can't think of any reason why a budget laptop with Stella wouldn't make a far superior dev system, though. 2 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted September 8, 2023 Share Posted September 8, 2023 to the OP: Yes. You can use batari Basic (or more complex methods) to make games for the Atari 2600, that will work in the Atari 2600+. There may be limitations based on the bankswitching method used, but "standard" Atari-style 4K through 32K games should work fine. I have no idea if there's a way to run games via USB port, etc., but definitely if you "burn" a game onto a PCB (contact me, Albert at AtariAge, or perhaps others), and that can be done quite easily, you can play your own game on the system. 1 Quote Link to comment Share on other sites More sharing options...
