sarnau Posted September 8, 2023 Share Posted September 8, 2023 I've never really wrote any code for the Atari 400/800 computers, so this is my first look into the hardware and software by using Pharaoh's Curse as a learning example. 6502 I knew via the C64, etc, but I knew almost nothing about the graphics and sound capabilities. Documented source code for Pharaoh's Curse for the Atari 400/800 computers. Requires the CA65 assembler to compile. I am using a Macintosh, but it should work on other operating systems as well or with trivial changes. I also wrote some Python scripts to extract the artwork, etc. If you like to have a look into the earlier development of games, this seems to be fun. https://github.com/sarnau/PharaohsCurse Interesting "cheat": press Control-Shift-9 to immediately "win" the game… It shows the end of game animations. I also attach all 16 levels as an image. That was generated by one of my scripts. 16 4 Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 9, 2023 Share Posted September 9, 2023 Synapse games often had similar protection attributes - checksum of code to prevent tampering, poll disk drive and not work if drive present/not present depending on original media type. I believe some also used illegal opcodes which is more towards confusing reverse-engineering efforts than efficiency. Some also used undocumented OS calls which made them partially or totally incompatible with XL machines. One game I'd like to see reverse engineered is Spelunker. From what I've seen, it uses encryption for most of the disk which should be easily removed. If new levels could be made it would invigorate that game. 4 Quote Link to comment Share on other sites More sharing options...
Bobo Cujo Posted September 9, 2023 Share Posted September 9, 2023 I believe @Eyvind Bernhardsen already decrypted Spelunker's disk obfuscation back when we were working on adding Joy2B+ support for it... Quote Link to comment Share on other sites More sharing options...
idavis Posted September 9, 2023 Share Posted September 9, 2023 (edited) synistops Edited September 9, 2023 by idavis 2 1 Quote Link to comment Share on other sites More sharing options...
sarnau Posted September 9, 2023 Author Share Posted September 9, 2023 i also did work on Electronic Arts games (Seven Cities of Gold is interesting, because two versions with different copy protection schemes exist). EA in Atari used some of the most interesting protections so far: the game loader is written in FigForth and some 6502. Later versions even encrypt the PCODE. Plenty of checksums as well and ROM/RAM checks to avoid hacking. 4 Quote Link to comment Share on other sites More sharing options...
devwebcl Posted September 9, 2023 Share Posted September 9, 2023 19 hours ago, sarnau said: Interesting "cheat": press Control-Shift-9 to immediately "win" the game… It shows the end of game animations. Nice finding! I didn't know that cheat; I think nobody knew it Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted September 9, 2023 Share Posted September 9, 2023 10 minutes ago, devwebcl said: Nice finding! I didn't know that cheat; I think nobody knew it Was about to say the same thing. Thanks! Quote Link to comment Share on other sites More sharing options...
ijor Posted September 9, 2023 Share Posted September 9, 2023 (edited) 7 hours ago, sarnau said: EA in Atari used some of the most interesting protections so far: the game loader is written in FigForth and some 6502. Very interesting. I knew long ago that some EA protections use pseudo code. I even fully reverse engineered the MULE pseudo code loader. But I had no idea it was based on FigForth, or any Forth dialect, for that matter. I understand this wasn't developed by EA. You will find almost the same protection, with the same, or very similar, PCODE, in some later Synapse releases. I've been told by a former EA employee that this was implemented by an external developer. I was curious and I asked his name. He didn't remember, unfortunately, but he remembered it was an extremely clever guy. Edited September 9, 2023 by ijor Quote Link to comment Share on other sites More sharing options...
sarnau Posted September 9, 2023 Author Share Posted September 9, 2023 FigForth was open-source and the 6502 code is available. You will find that they clearly used the _exact_ code and just stripped the symbols. I will publish the Code, because it is actually interesting to see how they checked for "illegal" ROM patches and tested the actual copy protection. 1 Quote Link to comment Share on other sites More sharing options...
sarnau Posted September 9, 2023 Author Share Posted September 9, 2023 BTW: Very first time in the real-world that I had to work with Forth in my 40 year career as a software developer 🙂 1 1 Quote Link to comment Share on other sites More sharing options...
ijor Posted September 9, 2023 Share Posted September 9, 2023 (edited) 1 hour ago, sarnau said: FigForth was open-source and the 6502 code is available. You will find that they clearly used the _exact_ code and just stripped the symbols. Open source, but not public domain, I guess? Because there is no copyright notice in the protection. I am wondering if they had a valid legal license. I assume EA wouldn't use unlicensed copyright code, at least not knowingly, but may be they were not aware since the protection was implemented by a third party. And probably nobody realized it was based on FigForth, until now ... Quote I will publish the Code, because it is actually interesting to see how they checked for "illegal" ROM patches and tested the actual copy protection. IIRC there are three different variants. I'm talking about releases with the older, Skew Align based, protection (never checked the software side of the later protection, so called SuperTrack). The earliest version, used in Worms?, is not compatible with XL/XE machines, it requires a 400 or 800. I don't recall the difference between the two later versions. May be one didn't check for PAL/NTSC? Edited September 9, 2023 by ijor Quote Link to comment Share on other sites More sharing options...
sarnau Posted September 10, 2023 Author Share Posted September 10, 2023 It was a different times. But FigForth was AFAIK in the public domain: "September 1980 This public domain publication is provided through the courtesy of Forth Interest Group, P.O. Box 1105, San Carlos, CA 94070. Further distribution must include this notice." EA used Forth even for 6502 assembly loaders without any Forth code in it. It must have been horrible to read as source code, because the opcodes and parameters are in reverse… How do I know? Well, 6502 Forth routines always start with a pointer to the beginning of the assembly code. In assembly code nobody would do that, because that pointer serves no purpose, but the Forth compiler generates it, so there you have it. The track alignment protection is clearly older than the overlapping sectors within a track. You can see that the code evolved (they added encryption, etc). But even within the same scheme the code changed, e.g. "Murder on the Zinderneuf" is older than "The Seven Cities of Gold" and has therefore slightly older source code, e.g. they all have a check for the Atari 1200XL (yes!), but only Seven Cities of Gold detects the 600/800XL correctly. Does anybody have a list of all EA games for the Atari 8-Bits? 2 Quote Link to comment Share on other sites More sharing options...
em_kay Posted September 10, 2023 Share Posted September 10, 2023 On 9/9/2023 at 6:23 AM, idavis said: synistops any more after that ? I've got as far as synistops <space bar> <space bar> 2 but havent had any luck finding the next character if there is even one Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted September 10, 2023 Share Posted September 10, 2023 52 minutes ago, sarnau said: Does anybody have a list of all EA games for the Atari 8-Bits? AtariMania filter Quote Link to comment Share on other sites More sharing options...
ijor Posted September 10, 2023 Share Posted September 10, 2023 (edited) 3 hours ago, sarnau said: The track alignment protection is clearly older than the overlapping sectors within a track. You can see that the code evolved (they added encryption, etc). Of course that the Skew Align protection is older. Not only that the Supertrack is a much more advanced protection, also the titles are later releases. Quote But even within the same scheme the code changed, e.g. "Murder on the Zinderneuf" is older than "The Seven Cities of Gold" and has therefore slightly older source code, e.g. they all have a check for the Atari 1200XL (yes!), but only Seven Cities of Gold detects the 600/800XL correctly. That's what I was saying, there are variants. There are two Murder on the Zinderneuf releases. The older one use the oldest variant that doesn't run on later computers (same as the one used in Worms?), the newer release has the fixed, updated, loader. Murder on the Zinderneuf and Seven Cities of Gold are the only two EA titles (as far we know) with two different releases that affect the loader or copy protection. Edited September 10, 2023 by ijor Quote Link to comment Share on other sites More sharing options...
sarnau Posted September 10, 2023 Author Share Posted September 10, 2023 (edited) I never used an Atari 400/800 during its hay days – except for 2 days as a loaner. I was in the C64 camp during that time (and later the Atari ST/TT before eventually ending up on the Mac). So I am reading the Atari documentation, etc. for the very first time now! It seems while a couple of EA games are available as ATX files, a lot are not. Or not in a functional state. Or I simply can't find them. I found a couple of originals plus I found both copies of Seven Cities of Gold and a few others, but I am simply missing a lot as well. Some are pretty clear: e.g. Hard Hat Mac seems _identical_ to the first version of Seven Cities of Gold. 100% the same protection. Edited September 10, 2023 by sarnau Quote Link to comment Share on other sites More sharing options...
+MrFish Posted September 10, 2023 Share Posted September 10, 2023 From the Atari Preserved Software archive. Activision ATX.zip 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted September 10, 2023 Share Posted September 10, 2023 Oh, my mistake. I thought you said Activision. Here's EA. EA ATX.zip 1 Quote Link to comment Share on other sites More sharing options...
idavis Posted September 11, 2023 Share Posted September 11, 2023 15 hours ago, em_kay said: any more after that ? I've got as far as synistops <space bar> <space bar> 2 but havent had any luck finding the next character if there is even one I only knew about these three listed here. https://www.ataricompendium.com/game_library/easter_eggs/a48/a48pharaohscurse.html I knew about them way before the web was a thing. Maybe I read about it on a bbs back in the day. Quote Link to comment Share on other sites More sharing options...
ijor Posted September 11, 2023 Share Posted September 11, 2023 15 hours ago, sarnau said: It seems while a couple of EA games are available as ATX files, a lot are not. Or not in a functional state. Working ATX images for all EA titles should be available. Let us know if there is something that you are missing. Quote Link to comment Share on other sites More sharing options...
sarnau Posted September 11, 2023 Author Share Posted September 11, 2023 20 hours ago, MrFish said: Oh, my mistake. I thought you said Activision. Here's EA. EA ATX.zip 1.54 MB · 6 downloads Thanks a lot, that was extremely helpful! Quote Link to comment Share on other sites More sharing options...
+MrFish Posted September 11, 2023 Share Posted September 11, 2023 35 minutes ago, sarnau said: Thanks a lot, that was extremely helpful! No problem. All the work was done by people in this thread: Atari 8-bit Software Preservation - Thread They have a website too, but it seems to be down at the moment: Atari 8-bit Software Preservation - Website Somebody hosts an archive with all the files too. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 11, 2023 Share Posted September 11, 2023 ATX and cracks aside, nothing beats a clean copy of software that can be run from nearly all Hard disk, floppy and other drives / differing DOS variants Quote Link to comment Share on other sites More sharing options...
Display Name Posted December 7, 2023 Share Posted December 7, 2023 This was a favorite game for me back in the day. I'd always hoped for a sequel or a hack with new levels. Very interesting stuff! 1 Quote Link to comment Share on other sites More sharing options...
