Thomas Jentzsch Posted October 9, 2023 Share Posted October 9, 2023 9 hours ago, MarcoJ said: I have also found this. Some more complex schemes are on the knife's edge of working. Especially during the beginning transition of the cycle, delaying the presentation of address can be fatal. If Harmony handles this with just 60 MHz, why can't the UnoCart handle this easily? 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 9, 2023 Author Share Posted October 9, 2023 [Deleted] Link to comment Share on other sites More sharing options...
DirtyHairy Posted October 9, 2023 Share Posted October 9, 2023 (edited) 4 hours ago, Thomas Jentzsch said: If Harmony handles this with just 60 MHz, why can't the UnoCart handle this easily? The Uno firmware is written in C and runs from flash, while the Harmony (to my knowledge) is hand-optimised assembly running from RAM. Edited October 9, 2023 by DirtyHairy 1 Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 9, 2023 Share Posted October 9, 2023 Tonight i've been reading the Stella source. From where are the calls to the Cart class functions Peek and Poke originated from in general? I'm a bit lost. Trying to find the main loop. I see a main loop in OSystem.cxx and OSystemRTStella.cxx but am not sure where it translates to peeks and pokes. Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 9, 2023 Share Posted October 9, 2023 8 hours ago, DirtyHairy said: The Uno firmware is written in C and runs from flash, while the Harmony (to my knowledge) is hand-optimised assembly running from RAM. So maybe there is a bit room for improvement? Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 9, 2023 Share Posted October 9, 2023 5 hours ago, MarcoJ said: Tonight i've been reading the Stella source. From where are the calls to the Cart class functions Peek and Poke originated from in general? I'm a bit lost. Trying to find the main loop. I see a main loop in OSystem.cxx and OSystemRTStella.cxx but am not sure where it translates to peeks and pokes. That happens in M6502::execute(). The peeks are in M6502.ins, which is included in the M6502 class. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 10, 2023 Author Share Posted October 10, 2023 On 10/6/2023 at 1:15 PM, MarcoJ said: @Al_Nafuur are you planning to write in AVR assembly or c? I'm starting with assembly. Looks like there's quite a few single clock instructions to form the delay. Seems like registerwise, there's PortB and DDRB (both 6 bits) for setting data direction. I have finally managed to setup my "development environment" for the ATtiny: I had no Arduino so I used a WeMos D1 mini clone as ISP (changes to the ArduinoISP script) For coding/uploading I use the Arduino IDE. The script is C code, for the delay I used ASM: Spoiler // Define pins #define START_CYLCE_PIN PB1 // Input pin of choice: PB1 (same as PCINT1) - Pin 6 #define CYCLE_ACTIVE_PIN PB4 // Output pin of choice: PB4 - Pin 3 // Define pin states #define ACTIVE HIGH // Define helper #define STR_HELPER(x) #x #define STR(x) STR_HELPER(x) void setup() { OSCCAL = 181; // TCCR1 = 1<<CTC1 | 0<<COM1A0 | 1<<CS10; // CTC mode, /1 // GTCCR = 1<<COM1B0; // Toggle OC1B PLLCSR = 0<<PCKE; // System clock as clock source // OCR1C = 0; cli(); // Disable interrupts pinMode(START_CYLCE_PIN, INPUT_PULLUP);// Set our input with a pullup to keep it stable pinMode(CYCLE_ACTIVE_PIN, OUTPUT); } void loop() { if(digitalRead(START_CYLCE_PIN) == ACTIVE ){ //digitalWrite(CYCLE_ACTIVE_PIN, HIGH); asm volatile ("sbi 0x18," STR(CYCLE_ACTIVE_PIN) ); // Port pin PB4 high, 2 clock cycles ~= 100ns asm volatile ("nop"); asm volatile ("nop"); asm volatile ("nop"); asm volatile ("nop"); // 4 cycles ~= 200ns asm volatile ("nop"); asm volatile ("nop"); asm volatile ("nop"); asm volatile ("nop"); // 8 cycles ~= 400ns asm volatile ("nop"); asm volatile ("nop"); asm volatile ("nop"); asm volatile ("nop"); // 12 cycles ~= 600ns //digitalWrite(CYCLE_ACTIVE_PIN, LOW); asm volatile ("cbi 0x18," STR(CYCLE_ACTIVE_PIN)); // Port pin PB4 low, 2 clock cycles ~= 100ns while(digitalRead(START_CYLCE_PIN) == ACTIVE); // Wait for active getting LOW again! } } The "digitalWrite" function is already replaced with ASM. The "digitalRead" still has to be replaced by ASM. Also I am not sure if "OSCCAL = 181;PLLCSR = 0<<PCKE;" is enough to set the CPU clock to ~20Mhz. Testing on the flash bread board with a LED (and longer delay) at the 3.3V of the WeMos worked fine. Testing on the Pi doesn't worked so far. I have to check the wiring, the voltage and my Pi test code. 2 Link to comment Share on other sites More sharing options...
DirtyHairy Posted October 10, 2023 Share Posted October 10, 2023 On 10/9/2023 at 8:03 PM, Thomas Jentzsch said: So maybe there is a bit room for improvement? Defintely. However, imo there is little reason --- so far, the bankings work find, and the way they are written is definitely easier to read than handcrafted assembly 😏 2 Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 11, 2023 Share Posted October 11, 2023 16 hours ago, Al_Nafuur said: on the flash bread board with a LED (and longer delay) at the 3.3V of the WeMos worked fine. Testing on the Pi doesn't worked so far. I have to check the wiring, the voltage and my Pi test code. Nice one. Presuming the avr i/os are running at 3.3v, rather than 5v? I had to install a second lv245 to duck the levels on mine. Are you using the timer as a substitute for nop delays with the current stella code? I’ve been been scratching my head trying to find a solution to allowing a full 6507 cycle length whilst being able to give some time to stella to do processing. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 11, 2023 Author Share Posted October 11, 2023 21 minutes ago, MarcoJ said: Nice one. Presuming the avr i/os are running at 3.3v, rather than 5v? I had to install a second lv245 to duck the levels on mine. The ATtiny should work with 2.7v, but unfortunately not at 20Mhz. I thought 3.3v would be enough, but it looks like they need 4.5v above 10Mhz: Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 11, 2023 Share Posted October 11, 2023 39 minutes ago, Al_Nafuur said: but it looks like they need 4.5v above 10Mhz Atmel, what an annoying little detail. i’ve been thinking that if GPIOs are used to set and reset the timer, potentially a software process could do the same and potentially supersede the hardware timer(software processes communicate with each other by gpio). 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 11, 2023 Author Share Posted October 11, 2023 11 hours ago, MarcoJ said: Atmel, what an annoying little detail. Yes. 11 hours ago, MarcoJ said: i’ve been thinking that if GPIOs are used to set and reset the timer, potentially a software process could do the same and potentially supersede the hardware timer(software processes communicate with each other by gpio). 🤔 That sounds like an interesting solution. We might add one more CPU to isolcpus for this process. 1 Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 13, 2023 Share Posted October 13, 2023 On 10/10/2023 at 4:06 AM, Thomas Jentzsch said: That happens in M6502::execute(). The peeks are in M6502.ins, which is included in the M6502 class. Ah, there it is, the heart of it. // Fetch instruction at the program counter IR = peek(PC++, DISASM_CODE); // This address represents a code section // Call code to execute the instruction switch(IR) { // 6502 instruction emulation is generated by an M4 macro file #include "M6502.ins" default: FatalEmulationError::raise("invalid instruction"); } IR= peek fetches the next instruction. The M6502.ins file has a comprehensive switch statement of how each instruction contextually peeks or pokes and what the operands do. What is interesting is that each instruction and operands are executed in a cluster; the peeks or pokes for the operand are done here in one go before exiting the function. This to some degree could give some control over timing between each operation. The trick is still finding some time for Stella to have breathing space to process the emulation with the read/write delays in place. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 13, 2023 Author Share Posted October 13, 2023 On 10/11/2023 at 3:07 PM, Al_Nafuur said: On 10/11/2023 at 3:43 AM, MarcoJ said: i’ve been thinking that if GPIOs are used to set and reset the timer, potentially a software process could do the same and potentially supersede the hardware timer(software processes communicate with each other by gpio). That sounds like an interesting solution. We might add one more CPU to isolcpus for this process. I did some tests on this. And it is possible to use a GPIO to communicate between to processes. First I added "isolcpus=domain,managed_irq,2,3" to "/boot/cmdline.txt" to isolate CPU 2 and 3 Then on the terminal: sudo echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor sudo echo -1 > /proc/sys/kernel/sched_rt_runtime_us CycleManager.c (compile: "gcc c++ -Wall -O2 CycleManager.c -o CycleManager"): Spoiler // Internal cycle length manager via GPIO 22 // //#define _GNU_SOURCE #include <stdio.h> #include <stdlib.h> #include <fcntl.h> #include <sys/mman.h> #include <unistd.h> #include <stdint.h> #include <sched.h> #define BCM2708_PERI_BASE 0x3F000000 #define GPIO_BASE (BCM2708_PERI_BASE + 0x200000) // GPIO controller #define PAGE_SIZE (4*1024) #define BLOCK_SIZE (4*1024) int mem_fd; void *gpio_map; // I/O access volatile unsigned *gpio; cpu_set_t mask; // GPIO setup macros. Always use INP_GPIO(x) before using OUT_GPIO(x) or SET_GPIO_ALT(x,y) #define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3)) #define OUT_GPIO(g) *(gpio+((g)/10)) |= (1<<(((g)%10)*3)) #define SET_GPIO_ALT(g,a) *(gpio+(((g)/10))) |= (((a)<=3?(a)+4:(a)==4?3:2)<<(((g)%10)*3)) #define GPIO_SET *(gpio+7) // sets bits which are 1 ignores bits which are 0 #define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0 #define GET_GPIO(g) (*(gpio+13)&(1<<g)) // 0 if LOW, (1<<g) if HIGH #define GET_DATA_BUS() ((*(gpio+13)&0x1fe000)>>13) // GPIO 13 - 20 ( 0b0001 1111 1110 0000 0000 0000 ) #define GET_CYCLE_ACTIVE() (*(gpio+13)&(1<<22)) // GPIO 22 ( 0b0100 0000 0000 0000 0000 0000 ) #define GPIO_PULL *(gpio+37) // Pull up/pull down #define GPIO_PULLCLK0 *(gpio+38) // Pull up/pull down clock void setup_io(); int main(int argc, char **argv) { uint32_t g; printf("Starting Cycle Manager\n"); // set CPU we want to run on CPU_ZERO(&mask); CPU_SET(2, &mask); int result = sched_setaffinity(0, sizeof(mask), &mask); printf("result %d \n", result ); // Set up gpi pointer for direct register access setup_io(); // Set GPIO pin 22 to output (Cycle active pin) INP_GPIO(22); // must use INP_GPIO before we can use OUT_GPIO OUT_GPIO(22); while(1){ if((*(gpio+13)&(1<<22)) ){ // printf("Cycle Start!\n"); g = 300; while(--g){ asm volatile("nop"); } GPIO_CLR = 1<<22; // printf("Cycle End!\n"); } } return 0; } // // Set up a memory regions to access GPIO // void setup_io() { // open /dev/mem if ((mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) { printf("can't open /dev/mem \n"); exit(-1); } // mmap GPIO gpio_map = mmap( NULL, //Any adddress in our space will do BLOCK_SIZE, //Map length PROT_READ|PROT_WRITE,// Enable reading & writting to mapped memory MAP_SHARED, //Shared with other processes mem_fd, //File to map GPIO_BASE //Offset to GPIO peripheral ); close(mem_fd); //No need to keep mem_fd open after mmap if (gpio_map == MAP_FAILED) { printf("mmap error %d\n", (int)gpio_map);//errno also set! exit(-1); } // Always use volatile pointer! gpio = (volatile unsigned *)gpio_map; } // setup_io start with "sudo nice -n -20 ./CycleManger" Here is the test routine (same compiler flags and start as CycleManager): Spoiler // Test for internal cycle manager. // //#define _GNU_SOURCE #include <stdio.h> #include <stdlib.h> #include <fcntl.h> #include <sys/mman.h> #include <unistd.h> #include <stdint.h> #include <sched.h> #define BCM2708_PERI_BASE 0x3F000000 #define GPIO_BASE (BCM2708_PERI_BASE + 0x200000) // GPIO controller #define PAGE_SIZE (4*1024) #define BLOCK_SIZE (4*1024) int mem_fd; void *gpio_map; // I/O access volatile unsigned *gpio; cpu_set_t mask; // GPIO setup macros. Always use INP_GPIO(x) before using OUT_GPIO(x) or SET_GPIO_ALT(x,y) #define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3)) #define OUT_GPIO(g) *(gpio+((g)/10)) |= (1<<(((g)%10)*3)) #define SET_GPIO_ALT(g,a) *(gpio+(((g)/10))) |= (((a)<=3?(a)+4:(a)==4?3:2)<<(((g)%10)*3)) #define GPIO_SET *(gpio+7) // sets bits which are 1 ignores bits which are 0 #define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0 #define GET_GPIO(g) (*(gpio+13)&(1<<g)) // 0 if LOW, (1<<g) if HIGH #define GET_DATA_BUS() ((*(gpio+13)&0x1fe000)>>13) // GPIO 13 - 20 ( 0b0001 1111 1110 0000 0000 0000 ) #define GET_CYCLE_ACTIVE() (*(gpio+13)&(1<<22)) // GPIO 22 ( 0b0100 0000 0000 0000 0000 0000 ) #define GPIO_PULL *(gpio+37) // Pull up/pull down #define GPIO_PULLCLK0 *(gpio+38) // Pull up/pull down clock void setup_io(); int main(int argc, char **argv) { // uint32_t t0, t1; char pp[1]; uint32_t test; int i,g,rep, delay_counter = 700; uint8_t a[0x1000], b; printf("Starting CartTester\n"); // set CPU we want to run on CPU_ZERO(&mask); CPU_SET(3, &mask); int result = sched_setaffinity(0, sizeof(mask), &mask); printf("result %d \n", result ); // Set up gpi pointer for direct register access setup_io(); // Set GPIO pins 0-12 to output (6502 address) for (g=0; g<=23; g++){ INP_GPIO(g); // must use INP_GPIO before we can use OUT_GPIO if(g < 13 || g > 20) OUT_GPIO(g); } // Set GPIO pin 21 & 22 to output (Level shifter dir, Cycle timer) *(gpio+(2)) = 0b001001000; // Set GPIO pin 21 to Low (ls dir read) GPIO_CLR = 1<<21; // Set GPIO pin 22 to Low (cycle timer off) GPIO_CLR = 1<<22; // Wait cycles length test g=100; while(g--){ // printf("1 Active PIN state 1 %d \n", GET_CYCLE_ACTIVE() ); // i = 10; // while(i--){asm volatile("nop"); } // printf("Cycle Start!\n"); GPIO_SET = 1<<22; i = 50; while(i--){asm volatile("nop"); } // printf("2 Active PIN state %d \n", GET_CYCLE_ACTIVE() ); i = 0; test = (*(gpio+13)&(1<<22)); while( test ){ i++; test = (*(gpio+13)&(1<<22)); } if(i == 0){ printf("0 cycles wait?! %d \n", g ); } i = 50; while(i--){asm volatile("nop"); } // printf("Cycle End!\n"); // printf("3 Active PIN state %d \n\n", GET_CYCLE_ACTIVE() ); } start_ROM_read_test: for (rep=0x000; rep<0x1000; rep++){ GPIO_CLR = 0b1111111111111; GPIO_SET = rep | 0x1000; i = 30000; while(i--){asm volatile("nop"); } a[rep] = (uint8_t)GET_DATA_BUS(); if(rep < 0x10){ printf("Read %d on address: %d \n", a[rep], rep ); } } scanf("%s", pp); for (g=0; g<100; g++){ // while(1) { for (rep=0x000; rep<0x1000; rep++){ GPIO_CLR = 0b1111111111111; GPIO_SET = rep | ( 0x1000 + (1<<22)); i = 3; while(i--){asm volatile("nop"); } while(GET_CYCLE_ACTIVE() ); b = (uint8_t)GET_DATA_BUS(); if ( b != a[rep]){ printf("Readings differ with delay_counter %d in round %d on address: %d a: %d b: %d !\n", delay_counter, g, rep, a[rep], b ); delay_counter += 10; goto start_ROM_read_test; // return 0; } } printf("."); } printf("\nAll the Same!! delay_counter %d \n", delay_counter); return 0; } // // Set up a memory regions to access GPIO // void setup_io() { // open /dev/mem if ((mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) { printf("can't open /dev/mem \n"); exit(-1); } // mmap GPIO gpio_map = mmap( NULL, //Any adddress in our space will do BLOCK_SIZE, //Map length PROT_READ|PROT_WRITE,// Enable reading & writting to mapped memory MAP_SHARED, //Shared with other processes mem_fd, //File to map GPIO_BASE //Offset to GPIO peripheral ); close(mem_fd); //No need to keep mem_fd open after mmap if (gpio_map == MAP_FAILED) { printf("mmap error %d\n", (int)gpio_map);//errno also set! exit(-1); } // Always use volatile pointer! gpio = (volatile unsigned *)gpio_map; } // setup_io But no matter what delay I choose in Cycle Manger the ROM reading fails mostly after 10 bytes or less 1 Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 13, 2023 Share Posted October 13, 2023 6 hours ago, Al_Nafuur said: I did some tests on this. And it is possible to use a GPIO to communicate between to processes. Wow! You have been busy. Code and all. 6 hours ago, Al_Nafuur said: But no matter what delay I choose in Cycle Manger the ROM reading fails mostly after 10 bytes or less I wonder if there's a binding problem where two threads trying to read or write to the GPIO at the same time gets bent and twisted. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 14, 2023 Author Share Posted October 14, 2023 20 hours ago, MarcoJ said: I wonder if there's a binding problem where two threads trying to read or write to the GPIO at the same time gets bent and twisted. They both have read/write access to the GPIO pin, but they shouldn't do same kind of access at the same time. While one is writing the other one is only reading, but maybe this is "disturbance" enough? But it occurred to me that instead of a GPIO pin the two processes should use shared memory? I tried some nmap and shmget examples, but I'll have to do further testing tomorrow. Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 14, 2023 Share Posted October 14, 2023 2 hours ago, Al_Nafuur said: But it occurred to me that instead of a GPIO pin the two processes should use shared memory? I tried some nmap and shmget examples, but I'll have to do further testing tomorrow. That would be the better solution. If it's possible, that would be good. Hopefully it's not too stifling to navigate protected memory. 1 Link to comment Share on other sites More sharing options...
DirtyHairy Posted October 14, 2023 Share Posted October 14, 2023 Why two processes? Two threads are sufficient, and they share memory. Use std::atomic to increment an atomic counter. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 14, 2023 Author Share Posted October 14, 2023 19 minutes ago, DirtyHairy said: Why two processes? Two threads are sufficient, and they share memory. Yes, with the shared memory I also switch to threads. 20 minutes ago, DirtyHairy said: Use std::atomic to increment an atomic counter. Maybe we don't need a atomic counter, a (atomic) flag in shared memory should be sufficient. 🤔 1 Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 14, 2023 Share Posted October 14, 2023 19 minutes ago, Al_Nafuur said: Yes, with the shared memory I also switch to threads. Does this mean the timer code needs to be embedded into the Stella build? I imagine it would only be necessary to exist under the rtstella build, perhaps some indef logic needed. I do think also that a simple flag system, perhaps a single uint8 could make inter thread communication possible. Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 14, 2023 Share Posted October 14, 2023 (edited) This is a bit of a Milestone post. My pi4 rig has had Dig dug running in demo mode for 2 days now, without glitches. Before that, Super Football had been running too for 3 days. The RTStella software is running with the CartridgePort GPIO driver, nop delay system, combined with the performance CPU governor and Linux scheduler off. This combination of software configuration has allowed many original cartridges with and without RAM to run at real time speed, without glitches in timing and/or execution. The nop delay system takes advantage of the fact that the original cartridges in many cases do not need the full 6507 read/write cycle to operate stably. A fixed delay is enforced between reads and writes to simulate a shrunken 6507 timing cycle. The reads and writes on the cartridge bus are much snappier than a normal Atari 2600, which leaves plentiful time for Stella to catch up on emulating the game. It is a kind of "overclocking", pushing the cartridge hardware to strobe faster than normal. Once Stella has done it's emulation catch up, its own internal timers allows the governing of real time speed, so that it doesn't emulate too fast. This first milestone works great for many original Atari 2600 cartridges. The downside of this approach is that some games which do rely on a full 6507 cycle will not work stably. Such games are where co-processors are used such as ARM chips. In such architectures, the co-processor is doing code bursts ,and needs to complete all of the required processing before the next 6507 cycle. In the nop delay system with shrunken cycle length, RTStella will ask for the next data too early, and the co-processor can't complete its job of processing within the full cycle. This typically results in the bus cycle being missed, and the game execution crashes. This has also proven true for flash carts emulating original game carts which require more of the 6507 bus cycle to be able to emulate a cartridge as compared to more primitive cartridges with industry standard ROM and RAM chips intended for cartridge use. In the case of flash carts, longer nop delays have been required for stability which has often prevented Stella working in real time due to lacking the correct quantity of time to process the cartridge emulation. This has lead to slowdown of some games on flash carts. The next milestone that is being worked towards is use of an accurate timer to enforce full length 6507 cycles. The hope is to support more or hopefully all cartridges that would otherwise work on the real console. The challenge of this approach is that apart from performing the low level strobing of the cartridge, Stella is also trying to emulate the game in real time. In the past, enforcing long delays made Stella run slow. Thankfully, the Raspberry pi has multiple CPU cores. The hope is that with accurate timing and some parallel tasking that the end goal of full 6507 cycle length, and real time emulation could be achieved. Until that time, hooray for Milestone 1 of the CartridgePort / RTStella project (nop delay method), where many original cartridges can be emulated in real time and flash cartridges work on / or close to real time. RTStella Raspberry Pi Interface Milestone 1 v0.2.pdf Edited October 14, 2023 by MarcoJ Milestone 1 Interface Schematic update 8 Link to comment Share on other sites More sharing options...
Kroko Posted October 14, 2023 Share Posted October 14, 2023 Is the sound ok now ? Link to comment Share on other sites More sharing options...
+MarcoJ Posted October 14, 2023 Share Posted October 14, 2023 6 hours ago, Kroko said: Is the sound ok now ? It works on headphone out socket for my pi4. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 14, 2023 Author Share Posted October 14, 2023 12 hours ago, Al_Nafuur said: Yes, with the shared memory I also switch to threads. Maybe we don't need a atomic counter, a (atomic) flag in shared memory should be sufficient. 🤔 I have pushed my WIP code for the threaded timer. It is on the branch "feature/cartridgeportThread" and currently works only if Stella is started with "-debug" to the debugger window. Switching to the emulation window freezes the Stella window. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 14, 2023 Author Share Posted October 14, 2023 39 minutes ago, Al_Nafuur said: I have pushed my WIP code for the threaded timer. It is on the branch "feature/cartridgeportThread" and currently works only if Stella is started with "-debug" to the debugger window. Switching to the emulation window freezes the Stella window. Just pushed a fix which changed the CPU for the cycle timer thread. Now the emulation works, but again I have trouble getting a stable emulation on my Pi 3. 1 Link to comment Share on other sites More sharing options...
