Open Club  ·  76 members
StellaRT
Community-Built Unnamed 1970's Video Game Console-Compatible System (WIP)
Al_Nafuur
2 hours ago, Thomas Jentzsch said:
Let's compare these:
 #  address R/W description
1    PC     R  fetch opcode, increment PC
2    PC     R  fetch low address byte, increment PC
3  $0100,S  R  internal operation (predecrement S?)
4  $0100,S  W  push PCH on stack, decrement S
5  $0100,S  W  push PCL on stack, decrement S
6    PC     R  copy low address byte to PCL, fetch high address byte to PCH
// JSR
case 0x20:
  const uInt8 low = peek(PC++, DISASM_CODE); // #2
  peek(0x0100 + SP, DISASM_NONE); // #3
  poke(0x0100 + SP--, PC >> 8, DISASM_WRITE); // #4
  poke(0x0100 + SP--, PC & 0xff, DISASM_WRITE); // #5, 0x1FE access
  PC = (low | (static_cast<uInt16>(peek(PC, DISASM_CODE)) << 8)); // #6
Not sure if it is relevant, but lets talk about step #3, especially the "(predecrement S?)"
I thought this means that the stack pointer is decremented before it appears on the address bus, but in stella code it seems the original value of SP would appear on the bus ?
I don't think the original value of SP ever appears on the bus on the real console.
The way I understood above description of the cycles, in step #3 and 4, the wrong addresses would appear on the adress bus of our emulated console...
Yes, it looks so. The 650x emulation code is not ours but taken from a very reliable source.
It seems that step #3 is not 100% clear.
The way I understood above description of the cycles, in step #3 and 4, the wrong addresses would appear on the address bus of our emulated console...
If that would be the case, Stella would read the wrong values, no? Then it wouldn't work at all. At least in step #4 it has to be correct one.
Yes I agree, but it is confusing ... especially the part with (predecrement S?) ...
Here is the log with the next peek/poke after a $1FE access (first value is PC second the R/W value):
Spoiler
poke 0x1FE 13
peek lastAccessWasFE 61453 : 208
peek 0x1FE 13
peek lastAccessWasFE 510 : 13
poke 0x1FE 23
peek lastAccessWasFE 61463 : 209
peek 0x1FE 23
peek lastAccessWasFE 510 : 23
poke 0x1FE 26
peek lastAccessWasFE 61466 : 208
peek 0x1FE 26
peek lastAccessWasFE 510 : 26
poke 0x1FE 40
peek lastAccessWasFE 61480 : 208
peek 0x1FE 40
peek lastAccessWasFE 510 : 40
poke 0x1FE 104
peek lastAccessWasFE 61544 : 211
poke 0x1FE 13
peek 0x1FE 13
poke 0x1FE 23
peek 0x1FE 23
poke 0x1FE 26
peek 0x1FE 26
poke 0x1FE 40
peek 0x1FE 40
poke 0x1FE 104
peek 0x1FE 104
peek lastAccessWasFE 510 : 104
poke 0x1FE 136
peek lastAccessWasFE 61576 : 210
peek 0x1FE 136
peek lastAccessWasFE 510 : 136
poke 0x1FE 105
peek lastAccessWasFE 62569 : 211
peek 0x1FE 105
peek lastAccessWasFE 510 : 105
poke 0x1FE 220
peek lastAccessWasFE 62684 : 254
peek 0x1FE 220
peek lastAccessWasFE 510 : 220
poke 0x1FE 220
peek 0x1FE 220
poke 0x1FE 220
peek 0x1FE 220
poke 0x1FE 220
peek 0x1FE 220
poke 0x1FE 220
peek 0x1FE 220
poke 0x1FE 220
peek 0x1FE 220
poke 0x1FE 244
peek lastAccessWasFE 62708 : 254
peek 0x1FE 244
peek lastAccessWasFE 510 : 244
poke 0x1FE 5
peek lastAccessWasFE 62981 : 211
peek 0x1FE 5
peek lastAccessWasFE 510 : 5
poke 0x1FE 65
peek lastAccessWasFE 63041 : 211
peek 0x1FE 65
peek lastAccessWasFE 510 : 65
poke 0x1FE 68
peek lastAccessWasFE 63044 : 212
peek 0x1FE 68
peek lastAccessWasFE 510 : 68
poke 0x1FE 118
peek lastAccessWasFE 64118 : 212
peek 0x1FE 118
peek lastAccessWasFE 510 : 118
poke 0x1FE 23
peek 0x1FE 23
poke 0x1FE 26
peek 0x1FE 26
poke 0x1FE 40
poke 0x1FE 105
peek lastAccessWasFE 54377 : 211
peek 0x1FE 105
poke 0x1FE 53
peek lastAccessWasFE 65534 : 200
poke 0x1FE 78
poke lastAccessWasFE 509 : 205
poke 0x1FE 205
poke lastAccessWasFE 509 : 53
poke 0x1FE 13
peek 0x1FE 13
poke 0x1FE 23
peek 0x1FE 23
poke 0x1FE 26
peek 0x1FE 26
poke 0x1FE 40
peek 0x1FE 40
poke 0x1FE 104
peek 0x1FE 104
Agreed. The predecrement S makes no sense, since the value of S is used afterwards. However, the 650x does these dummy peeks while doing internal calculations. So I wonder what is done there.
12 minutes ago, Thomas Jentzsch said:
poke 0x1FE 104
peek lastAccessWasFE 61544 : 211 ($f068 : $d3)
That's the last byte of the JSR, we need the byte after the JSR.
No. The value is correct the high byte (bit5) of the address determines the bank.
FWIW, I believe the cycle sequence for JSR is as follows. I don't believe there are any dummy peeks.
                                                    Address bus        Data bus
1 read opcode                                        PC                opcode
2 read lo byte of operand                            PC                lo operand byte
3 push hi byte of PC to stack. decrement SP          SP                (PC >> 8) & 0x00ff
4 push lo byte of PC to stack. decrement SP          SP                PC & 0x00ff
5 read hi byte of operand                            PC                hi operand byte
6 load pc                                            -                -
what confuses me is the 1FE access with the value 53 shortly before the crash:
poke 0x1FE 53
it seems to be done from address 65534 ($FFFD !). After this access there are a few unusual accesses from 509 ($1FD )
28 minutes ago, Thomas Jentzsch said:
Yes, but I would like to know what happens directly after the switch.
If the bank switching was successful the PC will continue at the target address in new bank, if not it will continue at the target address in the old bank..
poke 0x1FE 53
🤔 53 (0x35) doesn't occurs once in the bin file of Decathlon NTSC.
Yes, and if the bankswitch is in progress (= too early), then the value is undetermined.
If it is from an earlier bankswitching "still in progress" then it can't be this single value. There must be a whole chain of "undetermined" values that lead to a write to exactly $1FE. That's very very unlikely..
2 minutes ago, JetSetIlly said:
I may have missed you mentioning it but do Tigervision, 3e+, and Superbank cartridges work?
good point!
3F is tested on the PlusCart working, but 3E+ is not on the list and untested. Do you have some example ROMs?
3F      Tigervision     River Patrol      OK                          untested              untested        untested (no cart)
7 hours ago, Al_Nafuur said:
good point!
I'd like to see Circus Convoy working. There's no reason why it shouldn't because it's no more complicated than Tigervision but it would be a useful test
