TGB1718 Posted September 16, 2023 Share Posted September 16, 2023 When I first started using my 800, I was using mainly BASIC, The amount of times I would miss-type the filename when saving then try to find the mis-typed file on disk, I got into the habit of putting this at the end of mu programs, the just do a GOTO 30000 to save all my had work, I always SAVED and LISTED. Uses the old trick of stopping a program and letting it restart with a CONT 30000 ? Chr$(125):Position 2,4 30010 ? "SAVE ";Chr$(34);"D:DRAW2.BXE";Chr$(34) 30020 Position 2,7:? "CONT" 30030 Position 2,0:Poke 842,13:Stop 30040 Poke 842,12 30050 ? "SAVE COMPLETE" 30060 Position 2,14 30070 ? "LIST ";Chr$(34);"D:DRAW2.LST";Chr$(34) 30080 Position 2,18:? "CONT" 30090 Position 2,9:Poke 842,13:Stop 30100 Poke 842,12 30110 ? "LIST COMPLETE" Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 16, 2023 Share Posted September 16, 2023 (edited) I don't quite get it. I'm fairly sure you could just have somethjng like: 30000 SAVE "D:PROG.BAS" 30100 LIST "D:PROG.LST" Unlike other Basics, Atari Basic generally lets you put stuff inside programs that you'd normally only do in immediate mode, and do stuff in immediate that normally only goes inside the program. You can even have ENTER inside a program. And you can construct the text file without line numbers such that it gets executed sort of like a batch file. Some things you do though will terminate, fairly sure LOAD will always initialize first and abort any batch operation in progress before the load commences. The trick I had (generally before 64K and Dos 2.5 with Ramdisk) OPEN #1,6,0,"D:*.* : FOR A=1 TO 9999 : GET #1,D : PUT #16,D : NEXT A to get a disk directory without wiping your work - you could also put that inside a program (need to CL. #1 or END after the Error 136) PUT #16 is a handy trick too - annoyingly Basic doesn't normally allow some operations on IOCB #0 but just add 16 to the one you want and it works. Edited September 16, 2023 by Rybags 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 16, 2023 Author Share Posted September 16, 2023 @Rybags you are of course correct, I still can't remember why I did it that way, there must have been a reason but for the life of me I can't remember what it is Quote Link to comment Share on other sites More sharing options...
