+Lewis2907 Posted September 21, 2023 Share Posted September 21, 2023 Here is a mock up of something I'm working on. It strangely looks like something from my child hood. It was something I played for hours, just wish you could have sone more even back then. I think I know enough from the Pacman Eat N Run to make something playable. Doubt I can do a Multisprite version because of all the colors unless there is a way (probably ASM). Currently can't kill anything etc. Just something I started on and was looking for feedback etc. 20230921 - SeaQuential_DPC.bas.bin 3 Quote Link to comment Share on other sites More sharing options...
Prizrak Posted September 21, 2023 Share Posted September 21, 2023 I like it, sort of a cross between Sea Wolf and Sea Quest. Quote Link to comment Share on other sites More sharing options...
TrekMD Posted September 21, 2023 Share Posted September 21, 2023 It looks nice! Quote Link to comment Share on other sites More sharing options...
+Lewis2907 Posted September 29, 2023 Author Share Posted September 29, 2023 (edited) Making some progress. Then I run into issues lol. Does anyone have a simple program to shoot a missile. I tried to use RT's program and the missile get's stuck. Probably something I did wrong porting over as I have always struggled with the missile. The the next nice to have is how I have the Titlescreen colors like the top title. I tried it with the other two ones and still the same color. Thoughts / suggestions? 20230929 - SeaQuential_DPC.bas.bin 20230929 - SeaQuential_DPC.bas.asm 48x1_1_image.asm 48x1_2_image.asm 96x2_1_image.asm titlescreen_color.asm titlescreen_layout.asm Edited September 29, 2023 by Lewis2907 2 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted September 30, 2023 Share Posted September 30, 2023 You forgot to attach the basic source file. What issues are you having firing a missile? Basically you will want to set the missile x/y variables to match the sub's (maybe offset a little bit), then increment or decrement the variable a certain number of pixels each frame until it collides with something or reaches the edge of the screen. Quote Link to comment Share on other sites More sharing options...
+Lewis2907 Posted October 1, 2023 Author Share Posted October 1, 2023 Karl G, Thanks. I just noticed that. I have always struggled with the missile for some reason. Then I was trying to do a multi-color for the other two items in the Titlescreen. Thanks for looking at this for me as I continue to work on it and come up with some ideas. One is to use the "OpenWorld" to do a few other things or use the "Eat-n-Run" to have a few different screens that is still a WIP. For others who are still learning to program. Delete the below in the .bas to make the program to work. Something I learned over time when looking at other peoples code. The other option is to download the stuff above and put it into the same file as the .bas code. I also attached a PowerPoint I had to basically reteach myself on how to use the Titlescreen "scroller". I may play around with the others to see if I can make it easier as it took me a long time to understand what was going on here. gosub titledrawscreen bank5 frame=frame+1 temp1=frame&%00000111 if temp1=0 && bmp_48x1_2_index<190 then bmp_48x1_2_index=bmp_48x1_2_index+1 if joy0fire || switchreset then goto __Start_Restart goto __Titlepage 20230929 - SeaQuential_DPC.bas Titlescreen Templates.pptx Quote Link to comment Share on other sites More sharing options...
