Sirius7 Posted September 25, 2023 Share Posted September 25, 2023 I am trying to play Mercenary and the game loads fine, but when I try to save my game it makes the sound like it is saving to a cassette tape rather than a disk. Eventually it does seem to successfully save, but when I try to load a save game it doesn't seem to work at all. Is anyone else having this problem? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 25, 2023 Share Posted September 25, 2023 2 hours ago, Sirius7 said: I am trying to play Mercenary and the game loads fine, but when I try to save my game it makes the sound like it is saving to a cassette tape rather than a disk. Eventually it does seem to successfully save, but when I try to load a save game it doesn't seem to work at all. Is anyone else having this problem? not an expert on Fujinet but probably it's defaulting to saving to emulated cassette rather than disk. I'd imagine it's a Fujinet config setting tweak? Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted September 25, 2023 Share Posted September 25, 2023 It's rather a Mercenary setting - save to a tape by default. Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted September 25, 2023 Share Posted September 25, 2023 3 hours ago, Sirius7 said: I am trying to play Mercenary and the game loads fine, but when I try to save my game it makes the sound like it is saving to a cassette tape rather than a disk. Eventually it does seem to successfully save, but when I try to load a save game it doesn't seem to work at all. Is anyone else having this problem? Did you properly prepare your savegame disk? (https://www.gamingalexandria.com/highquality/atari8bit/Mercenary/Mercenary - Manual.pdf) I assume, you must mount it at the second slot. After the game is loaded, before you want to save current state, you should press the disk swap button on your FN so that the savegame disk lands in the first slot, and only then save (Ctrl+S and a slot number). Quote Link to comment Share on other sites More sharing options...
Sirius7 Posted September 28, 2023 Author Share Posted September 28, 2023 On 9/25/2023 at 3:39 AM, Peri Noid said: Did you properly prepare your savegame disk? (https://www.gamingalexandria.com/highquality/atari8bit/Mercenary/Mercenary - Manual.pdf) I assume, you must mount it at the second slot. After the game is loaded, before you want to save current state, you should press the disk swap button on your FN so that the savegame disk lands in the first slot, and only then save (Ctrl+S and a slot number). Yep. That is exactly what I did. Used Fujinet to make a new ATR, then formatted it with DOS. When I try to save & load a game with Mercenary it sounds like it is treating it like a cassette drive. Is this a problem unique to Mercenary? Has anyone here ever played it with a save disk and had this problem? Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted September 28, 2023 Share Posted September 28, 2023 I tried to save a game state but failed. Out of 4 different ATR images, two of them printed only something like "Do you want to save?" while the other two showed slot selection message. In all cases, in the next step the computer rebooted. It was the same for FujiNet and SIO2SD, so I think, I was doing something incorrectly. Or was it maybe my Atari 800 with Incognito installed? Maybe. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted September 28, 2023 Share Posted September 28, 2023 does the process work fine under plain 800XL emulation under Altirra? if not your chasing ghosts Quote Link to comment Share on other sites More sharing options...
Sirius7 Posted September 28, 2023 Author Share Posted September 28, 2023 10 hours ago, Wrathchild said: does the process work fine under plain 800XL emulation under Altirra? if not your chasing ghosts So I just tried it with Atar800Win and it's doing the same thing. So the next question is, why, and is there any way to make it work? Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted September 28, 2023 Share Posted September 28, 2023 What if you set the machine to an original 400/800 (with 48K of RAM)? Maybe it's the matter of OS version? Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted September 28, 2023 Share Posted September 28, 2023 This ATX crack just worked for me under emulation, was able to load and save to a blank disk Mercenary - Escape from Targ (1985)(Datasoft)(US).atr 1 Quote Link to comment Share on other sites More sharing options...
Sirius7 Posted September 29, 2023 Author Share Posted September 29, 2023 6 hours ago, Wrathchild said: This ATX crack just worked for me under emulation, was able to load and save to a blank disk Mercenary - Escape from Targ (1985)(Datasoft)(US).atr 90.02 kB · 2 downloads Thank you! You just made my day! I must have only had cassette versions. This version works perfectly. Quote Link to comment Share on other sites More sharing options...
