Wrathchild Posted October 5, 2023 Author Share Posted October 5, 2023 Limited success... I can support an OSS type A (034M) type cartridge (e.g. MAC/65 1.02) along with BW-DOS ATR image. This can load with the Pico ATR loader to the point of asking for the driver (Y - used) and then I don't run the ROM.COM. At this point I can type CAR to enter the MAC/65 editor and within that type DOS to return to the editor. However, if ROM.COM is run or RESET is pressed then the machine re-enters MAC/65 but the DOS seems to be lost. Hopefully something that can be debugged so I should have a go at building the patched emulator. Tomorrow (well today here 😆 - 5th Oct) I'll setup a GIT branch and upload the latest code along with firmware/os-rom/tweaked BW-DOS ATR Quote Link to comment Share on other sites More sharing options...
dmsc Posted October 5, 2023 Share Posted October 5, 2023 Hi! 3 hours ago, Wrathchild said: Can you please post chkdos.inc? I'm wanting to build a driver with these changes: CART_RESPONSE equ $D5C0 CART_STATUS equ $D5C1 CART_ATR_HEADER equ $D5C2 CART_DCB_DEVICE equ $D5C0 CART_DCB_SECTOR_LO equ $D5C1 CART_DCB_SECTOR_HI equ $D5C2 CART_DCB_PAGE equ $D5C3 CART_SECTOR_BUFFER_READ equ $D540 CART_SECTOR_BUFFER_WRITE equ $D540 [Edit] I've built an A8PICO.COM file with the include commented out and this runs ok for testing purposes It is my github: https://github.com/dmsc/bwdos-mads/blob/main/utils/chkdos.inc I could not test the A8PICO in real hardware because I realized that my raspberry pico was not compatible - so I ordered a couple of "purple" rp20240 boards... After further testing, I will need to add 256 bytes sector support to A8PICO, and better error detection to the driver. And about the Atari800 emulator, I added more A8PicoCart commands in the attached patch, now it also emulates reading directories, searching, ATR and XEX loading. You need to pass a folder to the "-a8pico" command line parameter. Have Fun! atari800-a8pico-2.patch.gz Quote Link to comment Share on other sites More sharing options...
