bcb01 Posted October 3, 2023 Share Posted October 3, 2023 This is essentially a CX-40, but every one I can find online only has 1 button. This one has 2. It is an original and came with a 2600 I have had since childhood. I have been digging around to get more information but I can't even find another image of one with 2 buttons like this. I have 3 controllers identical, there are no other markings/labels on it other than what you see (including on sides/bottom), that might otherwise help identify it. Thanks team! 1 Quote Link to comment Share on other sites More sharing options...
jhd Posted October 4, 2023 Share Posted October 4, 2023 I have never seen anything like this. Do both fire buttons use the very same trigger? I realise that the 2600 only uses one button, but this function could be tested on a Genesis (or the case carefully opened and the circuit traced). This may give a clue if it was originally designed for another console. Quote Link to comment Share on other sites More sharing options...
bcb01 Posted October 4, 2023 Author Share Posted October 4, 2023 26 minutes ago, jhd said: I have never seen anything like this. Do both fire buttons use the very same trigger? I realise that the 2600 only uses one button, but this function could be tested on a Genesis (or the case carefully opened and the circuit traced). This may give a clue if it was originally designed for another console. It's been quite a while since I've booted the 2600 up, but I seem to recall that the second button didn't do anything. Or, possibly it did the same thing as the other button. I wonder if possibly a left / right hand feature if it was indeed designed for the 2600. I agree, it seems like it would have been designed for some other console otherwise, just so close to the style and look of the 2600 joystick. I just was really surprised that, upon doing image searches, I couldn't find a single other similar one. 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted October 4, 2023 Share Posted October 4, 2023 On 10/3/2023 at 1:08 AM, bcb01 said: This is essentially a CX-40, but every one I can find online only has 1 button. This one has 2. It is an original and came with a 2600 I have had since childhood. I have been digging around to get more information but I can't even find another image of one with 2 buttons like this. I have 3 controllers identical, there are no other markings/labels on it other than what you see (including on sides/bottom), that might otherwise help identify it. Thanks team! Is that a 3rd button on the top of joystick or just the design of the ball top? I can kinda see what looks like a seam around that top circle like it might be independent of the rest of the molding and able to be pressed? Quote Link to comment Share on other sites More sharing options...
The Mr. Video Posted October 4, 2023 Share Posted October 4, 2023 On 10/3/2023 at 1:08 AM, bcb01 said: I swear I've seen this controller but I don't remember exactly where I saw it. It may have been from a Youtube unboxing video years ago. Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted October 4, 2023 Share Posted October 4, 2023 Can you try it on a 7800 with a game like Xevious? 1 Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted October 4, 2023 Share Posted October 4, 2023 (edited) On 10/3/2023 at 8:08 AM, bcb01 said: This is essentially a CX-40, but every one I can find online only has 1 button. This one has 2. It is an original and came with a 2600 I have had since childhood. I have been digging around to get more information but I can't even find another image of one with 2 buttons like this. I have 3 controllers identical, there are no other markings/labels on it other than what you see (including on sides/bottom), that might otherwise help identify it. Thanks team! Two button clone of the CX-40 and quite similar to the Bebek and BP V-8801 joystick. You can find it on Atari Compendium. Edited October 4, 2023 by Rom Hunter 2 Quote Link to comment Share on other sites More sharing options...
Supergun Posted October 4, 2023 Share Posted October 4, 2023 I really like that joystick. And I would be very interested in having one just to try it out. Back in the day, I actually envisioned modding one of my spare 2600 joysticks by “adding” a second identical button on the other side just like that. And even adding a toggle switch so that I could place that second button into 7800 or ColecoVision mode. Fast forward to present day however (being older and wiser) and when you really process the idea and give it some thought, you soon realize it actually isn’t practical. Reason being there is no comfortable / convenient way of actually pressing a button over there. Granted, in a slow paced game where you only press it every so often, maybe so. But in a fast action game where you need to press it almost as often as the other button, it’s simply in a bad place. You simply cannot use any of the fingers on your right hand to press any button anywhere on a 2600 stick because you need it to hold the controller itself. Ideally, placing a second button on the front left edge of the controller, where your left hands index finger naturally rests, would be far better. Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted October 5, 2023 Share Posted October 5, 2023 6 hours ago, Supergun said: You simply cannot use any of the fingers on your right hand to press any button anywhere on a 2600 stick because you need it to hold the controller itself. Ideally, placing a second button on the front left edge of the controller, where your left hands index finger naturally rests, would be far better. Or use this: My favorite controller. Micro switches and unbreakable. 2 Quote Link to comment Share on other sites More sharing options...
tkarner Posted October 5, 2023 Share Posted October 5, 2023 23 hours ago, Supergun said: You simply cannot use any of the fingers on your right hand to press any button anywhere on a 2600 stick because you need it to hold the controller itself. Ideally, placing a second button on the front left edge of the controller, where your left hands index finger naturally rests, would be far better. Do I need to patent this before everyone steals my ideas? The first one is for the 2600, hence the second cable, for playing Stargate and Spy Hunter. The second is for the 7800 so I never have to use a pro-line again. I used Flashback joysticks for these hacks because they have more room inside for the switches and wiring than a real CX-40. Quote Link to comment Share on other sites More sharing options...
Supergun Posted October 6, 2023 Share Posted October 6, 2023 3 hours ago, tkarner said: Do I need to patent this before everyone steals my ideas? The first one is for the 2600, hence the second cable, for playing Stargate and Spy Hunter. The second is for the 7800 so I never have to use a pro-line again. I used Flashback joysticks for these hacks because they have more room inside for the switches and wiring than a real CX-40. OMG! Eureka! Quite literally exactly what I envisioned! Quote Link to comment Share on other sites More sharing options...
Zonie Posted October 6, 2023 Share Posted October 6, 2023 This one is my NES compatible stick. It was a chore getting that second button lined up and drilled perfectly to line up with the button it actuates. The red top on #2 is from a NES controller. The two little black ones handle the start and pause buttons. It has a hacked up NES controller board inside of it. This one is modded for 7800 dual buttons. I went the easy route and put a complete button in the #2 spot. 1 Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted October 6, 2023 Share Posted October 6, 2023 19 hours ago, tkarner said: Do I need to patent this before everyone steals my ideas? Kraft would like a word. Quote Link to comment Share on other sites More sharing options...
tkarner Posted October 6, 2023 Share Posted October 6, 2023 2 hours ago, BassGuitari said: Kraft would like a word. Touche' Quote Link to comment Share on other sites More sharing options...
Supergun Posted October 6, 2023 Share Posted October 6, 2023 Well, the key point here is to take notice how all of these joysticks place the second button on the left hand side near the first button. Having it on the right side looks great and is more symmetrical, but is impractical. It’s just impossible to reliably push the button as needed during intense gameplay. Quote Link to comment Share on other sites More sharing options...
tkarner Posted October 7, 2023 Share Posted October 7, 2023 I think back in the day, most aftermarket two-button joysticks for the 2600, like the original poster showed, had both buttons wired as button one. Essentially making it an ambidextrous one-button joystick. A lefty could hold the stick left handed and use the right button. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted October 7, 2023 Share Posted October 7, 2023 I love my hyperkin trooper because I am a lefty. It has 2 buttons just like this. But no ball top. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted October 8, 2023 Share Posted October 8, 2023 I found another 2 button stick. Ebay Quote Link to comment Share on other sites More sharing options...
pumaconcolor Posted October 8, 2023 Share Posted October 8, 2023 Behold, the greatest Atari-compatible joystick of all time, the Newport Controls Prostick II: 1 Quote Link to comment Share on other sites More sharing options...
