Officepot Posted October 16, 2023 Share Posted October 16, 2023 I recently acquired a XEGS that passes all tests besides the 3rd and forth row of RAM tests. Are these RAM chips easy to come by? Figure I can determine which RAM chip is bad and replace it. The console only boots directly to the self test. I am assuming the bad RAM is the reason it will do nothing other than boot to the self test. Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted October 16, 2023 Share Posted October 16, 2023 An XEGS has 2 RAM chips of a 4464 type (4x64Kbit). They are easy to find. Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted October 16, 2023 Share Posted October 16, 2023 (edited) bad ram operations will make it boot to self test replacement RAM chips are obtainable and you can piggy-back them to determine the faulty one(s) here is the schematic set xegs.zip Edited October 16, 2023 by xrbrevin Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted October 16, 2023 Share Posted October 16, 2023 (edited) @OfficepotRemember the xegs isn't socketed so order 2 x 18pin double wipe sockets at the same time and take real care when removing the old chips from the pcb. Edited October 16, 2023 by Beeblebrox 2 Quote Link to comment Share on other sites More sharing options...
Officepot Posted October 16, 2023 Author Share Posted October 16, 2023 I read that this board is very easy to pull up trace lines... I will be as careful as one can be. Thanks for the help on determining this is why it boots to self test. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted October 16, 2023 Share Posted October 16, 2023 (edited) 59 minutes ago, Officepot said: I read that this board is very easy to pull up trace lines... I will be as careful as one can be. Thanks for the help on determining this is why it boots to self test. Yup. The Xegs pcb is slightly better build quality than the main XE line, but still not as robust as the XLs. I've upgraded two xegs's recently (replacement ram and and socketed os and MMU for u1mb, plus the 74ls08 socket to swap for a 74f08 replacement. So long as you clear all the solder and don't force the chips off the board if there is notable resistance you should be OK. Remember also to make sure it's all clean both sides of the board before putting the sockets in. Also make sure the sockets are flush. There may well be a slim chance their are also other issues which you might find after fixing the ram, but fingers crossed it's straightforward. Edit: also bear in mind if you do find other issues and these are with the os or MMU chips, the xegs doesn't use the same os or MMU chips as the other XE line, ( or the 600/800xl). It has it's own custom ones. Edited October 16, 2023 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
