Wrathchild Posted October 13, 2003 Share Posted October 13, 2003 Hi, Is there an online graph showing Pokey frequencies against real-note freqs? I think I recall seeing then in an Antic or Compute issue, one each for 8-bit and 16-bit sound settings. Thanks, Mark Quote Link to comment Share on other sites More sharing options...
emkay Posted October 14, 2003 Share Posted October 14, 2003 I know two formulas to calculate the 8-bit sound: [sound]=INT(31960/(f+2)) or ..................32000Hz Frequency=----------- ...................[AUDF] In theory there is 32000....125Hz possible. Let's calculate: 32000Hz/256=125Hz So the deepest Tone must be a cool base-tone, but it isn't, because it is square-wave based and you will only hear some resulting harmonics. Another problem is: 32000Hz/440=72,72~ But you can set AUDF only to 72 or 73 etc... To get clear notes you have only the chance to create a very good, for a musician understandable Sound-editing tool, and he will adjust the sounds by ears... Another bad thing is: 32000Hz/100Hz=320 This value you can only set by 16Bit So, a Tool with real 16Bit-support is needed for higher note-accuracy... Even here, a musician has to "finetune" by ears... Same thing for Filtering and Triangle-sounds...(and all other sounds POKEY can produce by hardware... But remember: a Guitar-Man will only play on a Guitar and not on a plank with wires... So build a guitar and he wil play great music on it A plank with wires and an automated player will not help out here. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 14, 2003 Author Share Posted October 14, 2003 Thanks for the tips, I compared the 16-bit values in the Antic article @ http://www.atarimagazines.com/v4n5/soundpower.html against an equation I found elsewhere: 440*2^(n/12) e.g. n=0 for A. Generally the 16-bit notes @ 1.79MHz are faithful enough, but like you point out - its in the ears of the beholder Regards, Mark BTW: Here's a 16-bit RMT tune I'm working on, hopefully some of you may recognise it ff3_2.zip Quote Link to comment Share on other sites More sharing options...
emkay Posted October 14, 2003 Share Posted October 14, 2003 Thanks for the tips, I compared the 16-bit values in the Antic article @ http://www.atarimagazines.com/v4n5/soundpower.html against an equation I found elsewhere: 440*2^(n/12) e.g. n=0 for A. Generally the 16-bit notes @ 1.79MHz are faithful enough, but like you point out - its in the ears of the beholder Regards, Mark BTW: Here's a 16-bit RMT tune I'm working on, hopefully some of you may recognise it Did you use the generator "A" or "6"... ? 16 Bit is very nice. Especially, the waveforms, an YM can't play But the lower tones are a kind of to distorted (no filter). They can be enhanced by "vibratos". OK.... by using 2 16Bit channels you can get very good results... but, two channels are lost, which could be used with the "voltage"-Bit to create a very good baseline...the sound-tool has to vary between 50 and 200 updatings and the two "voltage" Voices can be used together for FM... So, with relative small CPU usage, you will get a cool 16Bit soundchip... with 3 channels for 1 Main voice 2 Attendace 3 Baseline Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 14, 2003 Author Share Posted October 14, 2003 Did you use the generator "A" or "6"...? '6', I tried with 'A' and setting AudCtl values but this doesn't seem to work for me in RMT, each instrument shouldn't have different AudCtl values? But the lower tones are a kind of to distorted (no filter). They can be enhanced by "vibratos". I've notice that too I'll give that a go as its not a par on the NES version yet OK.... by using 2 16Bit channels you can get very good results... but, two channels are lost, which could be used with the "voltage"-Bit to create a very good baseline...the sound-tool has to vary between 50 and 200 updatings and the two "voltage" Voices can be used together for FM... So, with relative small CPU usage, you will get a cool 16Bit soundchip... with 3 channels for 1 Main voice 2 Attendace 3 Baseline More C64 and ST tunes on the way then... This tune only has two voices so I'm lucky, the battle tune which I'll do after, has a lot more going on. Mark Quote Link to comment Share on other sites More sharing options...
Bryan Posted October 14, 2003 Share Posted October 14, 2003 Here's the beginnings of some pitch correction stuff I was writing. It's a BASIC/ML program that allows you to choose a pitch, then by pressing START/SELECT/OPTION you can hear: PITCH, PITCH+1, or the 2 pitches alternated 50/60 times a second. With lower pitches it can give the illusion of a half-step, but the trick is obvious at higher pitches. If the alternating speed was faster (120/100Hz) it would work much better, but I haven't written that yet. Try a pitch of 100 to start with and oh yes, the mixing sounds better on real hardware than in Atari800Win+. The ML VBlank routine: .org $0600 CLV LDA $D01F;Consol AND #$07 EOR #$07;Invert BNE skip LDA $CD ;If 0, use old settings skip STA $CD ;CD is the previous setting LSR A ;Start? BCC sel LDX $CB ;Tone1 BVC sound sel LSR A ;Select? BCC opt LDA $14 ;Time0 AND #$01 TAY ;Low bit in Y LDX $CB,Y;Alt Tone BVC sound opt LSR A BCC end LDX $CC ;Tone2 sound STX $D200;Audf1 end JMP ($00CE) -Bry P.S. I re-uploaded the ATR after modifying the program to make it easier to put in different values. sndtest.zip Quote Link to comment Share on other sites More sharing options...
Bryan Posted October 14, 2003 Share Posted October 14, 2003 Today I wrote another version that changes the pitch on a scanline basis. It can produce higher pitches with better accuracy, but it seems to be outrunning the emulator (it only works right on real hardware). -Bry Quote Link to comment Share on other sites More sharing options...
raster/c.p.u. Posted October 15, 2003 Share Posted October 15, 2003 '6', I tried with 'A' and setting AudCtl values but this doesn't seem to work for me in RMT, each instrument shouldn't have different AudCtl values? In RMT there distortion '6' means AUDC=$0c (bass tones) with automatically AUDCTL set up for join of two generators and 1.79MHz, and 16bit frequency values are stored to two AUDF registers. Distortion 'A' is for normal "pure" tones, AUDC=$0a (pure tones) and 8bit frequency value is stored to one AUDF register. If you use "manual AUDCTL" instrument setting and distortion '6' isn't used, no 16bit values are stored. So, if you urgently need to use some exact own 16 bit value set up, you can use 2 instruments in 2 tracks (one of them with zero volume) and both your 8bit frequency values will be stored to two AUDF registers (low and high byte of 16bit value). Of course, it is quite laborious, but if you really need it, it's possible... Quote Link to comment Share on other sites More sharing options...
