R.Cade Posted November 2, 2023 Share Posted November 2, 2023 I have a question about Drivewire (HDB-DOS) in a Rom Pak. I recently rescued a Coco3 and burned the HDB-DOS 1.4 to an EPROM, and put it in a Super Pitfall cartridge. This boots up OK, except I find it's unstable- I can't boot NitroOS, and even the RAM stress test fails on bank $03c. However, if I pull the cartridge and instead load with cassette port, it works fine. It seems like the cartridge is interfering with RAM. Is this just a known limitation of running HDB-DOS from a Rom Pak, or do I need to modify the cartridge in some other way? Quote Link to comment Share on other sites More sharing options...
linville Posted November 2, 2023 Share Posted November 2, 2023 On the CoCo, a DOS is intended to be loaded based on a signature in the ROM, whereas a game (like Super Pitfall) uses a different mechanism to autostart. I'm not 100% sure on the technical details of why HDB-DOS isn't working in your configuration, but I suspect that if you had the same ROM image loaded in a non-autostart cartridge (e.g. the Deluxe RS232) things might work better for you. Quote Link to comment Share on other sites More sharing options...
R.Cade Posted November 2, 2023 Author Share Posted November 2, 2023 Thanks. I'm going to first try cutting the autostart line to the cart, then look and make sure the cart enable line is properly connected to the CE and OE on the EPROM. Quote Link to comment Share on other sites More sharing options...
R.Cade Posted November 2, 2023 Author Share Posted November 2, 2023 Cutting the connection between 7 and 8 fixed it. Q and CART. 1 Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted November 4, 2023 Share Posted November 4, 2023 I have removed the chip and replaced it with a socket on a standard game cart. Wrote HDB-DOS on chips for the various coco versions so they would work properly with drivewire. Still have them somewhere and they worked just fine. Quote Link to comment Share on other sites More sharing options...
MrDave Posted November 8, 2023 Share Posted November 8, 2023 Most disk software is not worried about the interrupt from the cart ( autostart ..ie the q signal to cart ) so you have to fix any writes to ff23 . Also if you want the coco3 basic working properly it might be best to let it do its boot up routine and run your cart with the exec &HE010. Formally &HC000 on coco1,2 Also you new pcb's for your roms ! They are cheap ..work better .. i even have some that can bank switch.allowing 32k of data for coco1,2 ... Quote Link to comment Share on other sites More sharing options...
