BriGuy_the_AtariGuy Posted November 4 Share Posted November 4 Hi everyone I have a new-to-me early model VIC 20 that has an odd characteristic during warmup (first min or two after power on). The borders of the screen will show some rainbows that move up and down before slowly fading away. Screen colors look off to me (I remember the screen to be much brighter). I had to replace U11 already to get the BASIC prompt (carts worked ok). Video trim pots don't really help much and crystal tests ok. Any thoughts on what to look at next? Using an av cable to lcd. During warmup (example... the rainbow lines move around) After warmup Thank you for your help! Briguy Quote Link to comment Share on other sites More sharing options...
R.Cade Posted November 4 Share Posted November 4 (edited) Looks like the video output is turned down too low or you are using the wrong video output. The VIC-20 has video "hi" and "lo" outputs. Have you tried the other one, or is your cable pre-made and wrong? The impedance is different. Edited November 4 by R.Cade 1 Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 4 Author Share Posted November 4 Hi R.Cade, I'm using the "hi" output. I made the av cable. I can switch to the "low" output and see if it helps. I haven't tried the rf box yet because it needs to be cleaned and recapped. I'll do this in a bit and post results. Thank you! Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 4 Author Share Posted November 4 When I was checking the cable, I found it was on "lo" (pin 4). I built a new av cable with higher quality components, still using pin 4 and it didn't help at all. I swapped to pin 5 ("hi") and have no output at all now. I guess lo is the way to go. I'll patch up the rf box next to see if I get the same result there, just to take the cable out of the equation. Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 5 Author Share Posted November 5 Out of curiosity, would it make sense to combine pin 4 and 5 to the composite out? I'm seeing posts that one is being used for chroma and the other for luma on s-video mods and since composite has these on one output, wouldn't it make sense to output them together to video? Quote Link to comment Share on other sites More sharing options...
R.Cade Posted November 5 Share Posted November 5 I don't think so... You only need one or the other. The difference is only impedance. Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 5 Author Share Posted November 5 I finished the rf modulator recap and while the rainbows didn't go away, it improved to normal much faster. Now that I can see the picture "correctly", its clear that colors arent right. Another issue to dig into... Quote Link to comment Share on other sites More sharing options...
hofster Posted November 6 Share Posted November 6 Looks like you need to adjust your video signal. https://sleepingelephant.com/denial/wiki/index.php?title=Video_signal_adjustments Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 6 Author Share Posted November 6 Hi hofster, I tried tweaking the two a bit. Unfortunately, neither affected the colors at all. The one on the left (video level control) just sort of sharpened the image (intensity, maybe?), while the one on the right (black level control) just turned the screen black when I turned it up (which makes sense). I didn't see any other things I could adjust except the crystal. Thank you for the link. Best writeup on those that I've seen! Briguy Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 6 Share Posted November 6 Try bringing down the colour setting on your TV by a lot, and increase brightness a bit. When I alternate between Atari 8-bit and VIC-20 on the same LCD screen, using the same composite video cable (because they share the same pinout), I find that I need to bring down the colour saturation a lot with the VIC and then bring it back up again when I switch to the Atari. But yeah, you should use pins 2 (ground), 3 (audio), 4 (video low) for the video cable. I'm not even sure all VICs output something on pin 5, or what signal strength it then has. Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 6 Author Share Posted November 6 Thanks! I'll try. The last pic was on rf, but that doesn't mean the TV doesn't need adjustment. It's just my bench tv anyway. 😀 Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 8 Author Share Posted November 8 Did some experiments tonight... Lcd monitor using rf with adjusted color and brightness as suggested by carlsson: Couldn't get any "cyaner" than that... Swapped to av with the same settings: better border, but white was still wacky. I broke out the crt and... wow, colors look really good! still have the original rainbows in the border until it warms up for about 60 seconds tho. 😮💨 getting closer! 1 Quote Link to comment Share on other sites More sharing options...
jc13 Posted November 16 Share Posted November 16 I recently had a similar symptom, but mine didn't clear up as it warmed up - it would lock up completely. I did a couple of troubleshooting things at once, but I believe it came down to one of the original MOS 245s because it fell apart as I was removing it to troubleshoot. Once I put in a new one everything looked good. I didn't really investigate how/if it could have been related, but the VIC's been stable ever since. Quote Link to comment Share on other sites More sharing options...
BriGuy_the_AtariGuy Posted November 17 Author Share Posted November 17 Hi jc13, Thank you! Do you mean UE8 and UF8? The LS245s? If so, I can pull and test them. Thanks! Quote Link to comment Share on other sites More sharing options...
jc13 Posted November 17 Share Posted November 17 Yep - specifically UE8. Mine were MOS branded though, so from what I've read not very reliable. I replaced all 3 while I was at it. Quote Link to comment Share on other sites More sharing options...
