RickyDean Posted November 9 Share Posted November 9 I found this on Ebay today. Does anyone know if it will work to use, say the IDE Card, with an USB adapter to allow a thumb drive to be seen as an Ide drive? Without additional driver work? https://www.ebay.com/itm/143620917615?hash=item217079496f:g:-QEAAOSwythesd2d&amdata=enc%3AAQAIAAAA4IdGEJAkEUVrviCHinVBRNnzq5STE%2F2CYOmZYGrQRA%2BFVqkgnbQkIortepwO%2BJ%2BYhm2kOYcdIKpDCR68hX543CNL27OepU0CUMhkoUdkUIUopRaLnuLoY80g4fpxu3FNeODea47YzttZnB8Vc%2FqL6pDUGFQVV%2Fia1YC%2F0Eq64gu%2BXZmcaHtfWPMhxIJ96ctAwqzY0Bve3PBXjr2yTZVo%2F1Wx%2FmzHE5gK39gNQmVLfRbUvaqvfDd%2FuggyTa2ckkakeTo7Q%2BxdpLw3X90ROmVIpMt6xSAyOmd5HbtfAbgBH%2Frs|tkp%3ABk9SR5bIscv2Yg 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted November 9 Share Posted November 9 I would think since all the logic circuitry is in the adapter itself that it should work, but I cannot guarantee it. I may have to purchase one to find out. 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted November 9 Share Posted November 9 Yea I had one that works and had a SCSI to EIDE and SCSI to IDE adaptor. Never needed the IDE to USB one as I have so many docks that do it. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted November 9 Author Share Posted November 9 4 minutes ago, RXB said: Yea I had one that works and had a SCSI to EIDE and SCSI to IDE adaptor. Never needed the IDE to USB one as I have so many docks that do it. Understood, but I'm believing this will work on our IDE cards for the TI, to maybe give another storage medium option. Hard drive, CF, SD, Thumb drive, etc. 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted November 9 Share Posted November 9 5 minutes ago, RickyDean said: Understood, but I'm believing this will work on our IDE cards for the TI, to maybe give another storage medium option. Hard drive, CF, SD, Thumb drive, etc. I have tested various IDE2CF and IDE2SD adapters similar to the below and they work fine. I have even tested a IDE to Dual CF Card to give a primary and slave. https://www.amazon.com/outstanding-Adapter-Compact-Bootable-Converter/dp/B09FPRDCY7/ref=sr_1_2?crid=3F33DR2SF8IP0&keywords=IDE2CF&qid=1699551239&sprefix=ide2cf%2Caps%2C109&sr=8-2 https://www.amazon.com/SDHC-40Pin-Adapter-Memory-Drive/dp/B08SK28S2Y/ref=sr_1_4?crid=1VUA9J44NS4MY&keywords=IDE2SD&qid=1699551261&sprefix=ide2sd%2Caps%2C77&sr=8-4 3 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 10 Share Posted November 10 @RickyDean First moment I thought "this will not work" because you´ll need an USB-2-IDE adapter but not an IDE-2-USB one... But then I saw it says "Bridge", so it should work in your way (direction) , right ? The shown SD-2-IDE and CF-2-IDE do say it correct: a CF-Card (or SD) will work as IDE drive, but NOT the other way around but OK, these are adapters, not bridges... Quote Link to comment Share on other sites More sharing options...
RickyDean Posted November 10 Author Share Posted November 10 6 hours ago, Schmitzi said: @RickyDean First moment I thought "this will not work" because you´ll need an USB-2-IDE adapter but not an IDE-2-USB one... But then I saw it says "Bridge", so it should work in your way (direction) , right ? The shown SD-2-IDE and CF-2-IDE do say it correct: a CF-Card (or SD) will work as IDE drive, but NOT the other way around but OK, these are adapters, not bridges... Yes sir, that's what I'm thinking. A IDE to USB bridge suggest cross communication. I think it only means for storage here, say like a usb drive, not for mouse or keyboard, but that would still be useful. Maybe you could plug in an extension cable to the front of the PEB and change out and use portable drives (thumb drives, small external hard drives, etcetera)as you needed to, easily and quickly? 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 10 Share Posted November 10 I would be wary of putting so much faith in the wording of Chinesium products. 3 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted November 10 Author Share Posted November 10 33 minutes ago, OLD CS1 said: I would be wary of putting so much faith in the wording of Chinesium products. I perfectly understand, they're pretty cheap though, so I've bought a couple to see if they are worth trying out. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 10 Share Posted November 10 30 minutes ago, RickyDean said: I perfectly understand, they're pretty cheap though, so I've bought a couple to see if they are worth trying out. I am curious as to the results. That it only has a USB-A connector on it seems dubious for bridge functionality. At the same time, some of these Chinesium products perform small miracles. 2 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted November 17 Share Posted November 17 On 11/9/2023 at 4:54 PM, RickyDean said: I found this on Ebay today. Does anyone know if it will work to use, say the IDE Card, with an USB adapter to allow a thumb drive to be seen as an Ide drive? Without additional driver work? https://www.ebay.com/itm/143620917615?hash=item217079496f:g:-QEAAOSwythesd2d&amdata=enc%3AAQAIAAAA4IdGEJAkEUVrviCHinVBRNnzq5STE%2F2CYOmZYGrQRA%2BFVqkgnbQkIortepwO%2BJ%2BYhm2kOYcdIKpDCR68hX543CNL27OepU0CUMhkoUdkUIUopRaLnuLoY80g4fpxu3FNeODea47YzttZnB8Vc%2FqL6pDUGFQVV%2Fia1YC%2F0Eq64gu%2BXZmcaHtfWPMhxIJ96ctAwqzY0Bve3PBXjr2yTZVo%2F1Wx%2FmzHE5gK39gNQmVLfRbUvaqvfDd%2FuggyTa2ckkakeTo7Q%2BxdpLw3X90ROmVIpMt6xSAyOmd5HbtfAbgBH%2Frs|tkp%3ABk9SR5bIscv2Yg I found a similar one like this in my drawer. It is for connecting an IDE harddisk to a USB port of a PC. 1 Quote Link to comment Share on other sites More sharing options...
