+dhe Posted November 11 Share Posted November 11 I've always liked the MyARC 512K card. You get a ramdisk, you get bank switched memory, you get a print spooler, you can even run a mega fast 99/8 extended basic. I now have three of these cards, one an unmolested 512K unit, one a Foundation 128K card wired up to be a Myarc 512K card and one wired to be a myarc geneve memory expansion. myarc512.pdf myxbdoc.pdf foundation 128k card doc.pdf foundation.txt ti99_myarcmem.zip XBII211.ZIP XBII212.ZIP Myarc memory expansion card ad.pdf 5 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 11 Share Posted November 11 And I found this Mod to use it with the Geneve. From Paolo Bagnaresi 1989. (Is this still the up to date version?) Myarc512K-MODIF.pdf 2 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted November 11 Share Posted November 11 4 hours ago, Schmitzi said: And I found this Mod to use it with the Geneve. From Paolo Bagnaresi 1989. (Is this still the up to date version?) Myarc512K-MODIF.pdf 58.75 kB · 4 downloads I think that is the modification that everyone used for these cards BITD. 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted November 11 Author Share Posted November 11 As you can tell from the back of the card, they run hot, like an HFDC or Geneve. I spoke to one of the Guru's, who thinks it should be possible to outfit it with the newer cooler running voltage regs. 1 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted November 11 Share Posted November 11 4 minutes ago, dhe said: As you can tell from the back of the card, they run hot, like an HFDC or Geneve. I spoke to one of the Guru's, who thinks it should be possible to outfit it with the newer cooler running voltage regs. It's possible, but I'm not a guru! 😁 Quote Link to comment Share on other sites More sharing options...
