Loading Tiles into Graphics Mode 1
It's been a while since I shared routines inside the Programing area.  So...
I lifted this out of Space Panic which runs under graphics mode 1.
I thought I would show it just in case any of you plan to make something in the future.
After I optimized this one routine it ran the same but was 10 bytes lighter.  Not that it matters in this day and age.
I did change some labels in order to make the routine generic but you can still use it none the less to load in a set of patterns mixed with ASCII and Number tables
Colors and Sprites as well.
You will have a bit of other setup like calling Mode 1, initializing the tables and such.
I wanted to share this portion now because I am bogged down with other projects.  Perhaps I will write a complete Mode 1 setup routing and share it down the road.
Personally, I don't know why this is not used more often.  I mean seriously, how many games out there use more than 1 color per tile when most of it are simple 1 color backgrounds.
Anyway, here is the routine I grabbed and reworked.
LOAD_TILES_AND_COLORS_TO_VRAM:
    CALL    LOAD_TILE_PATTERNS_TO_VRAM
    CALL    LOAD_NUMBERS_TO_VRAM_01      ; DONE TWICE FOR DIFFERENT COLORS (MODE 1)
    CALL    LOAD_ASCII_TO_VRAM                ; LOAD IN ASCII
    CALL    LOAD_NUMBERS_TO_VRAM_02      ; DONE TWICE FOR DIFFERENT COLORS (MODE 1)
    CALL    LOAD_COLOR_TABLE_TO_VRAM     ; MODE 1 COLOR TABLE.  EVERY 8 TILES GETS A SINGLE COLOR
    CALL    LOAD_SPRITES_TO_VRAM            ; LOAD SPRITES TO VRAM
RET
LOAD_TILE_PATTERNS_TO_VRAM:
    LD      IX, PATTERN_INDEX_TABLE
LOOP_UNTIL_DONE:
    LD      A, (IX+0)                  ; BYTES TO TRANSFER OR $00 TO TERMINATE FROM (IX+0)
    OR A
    RET Z                                ; RETURN IF A IS $00
    LD      B, 0                         ; ZERO OUT B
    LD      C, A                         ; TRANSFER BYTE COUNT TO C
    PUSH    BC                         ; PUSH BC ON THE STACK
    POP     IY                          ; POP ONTO IY FOR HOW MANY BYTES.  IY = BYTE COUNT TO TRANSFER (PUT_VRAM ROUTINE)
    LD      D, 0                        ; HIGH BYTE OF DE, START INDEX IN VRAM (PUT_VRAM ROUTINE)
    LD      E, (IX+1)                  ; LOW BYTE OF DE
    LD      H, (IX+3)                  ; HIGH BYTE OF HL, PATTERN TABLE SENDING TO VRAM (PUT_VRAM ROUTINE)
    LD      L, (IX+2)                  ; LOW BYTE OF HL
    LD      A, 3                         ; 3 = PATTERN GENERATOR TABLE IN VRAM (PUT_VRAM ROUTINE)
    PUSH    IX
    CALL    PUT_VRAM
    POP     IX
    LD      BC, 4
    ADD     IX, BC
    JR      LOOP_UNTIL_DONE
LOAD_NUMBERS_TO_VRAM_01:
    LD      HL, (NUMBER_TABLE)
    LD      DE, $D8                      ; WHERE IN TABLE TO PLACE PATTERN SET
    LD      IY, $0A                      ; 10 NUMBERS, 1-9 PLUS 0
    JR      SEND_PATTERNS_TO_VRAM
LOAD_ASCII_TO_VRAM:
    LD      HL, (ASCII_TABLE)
    LD      DE, $E2                      ; WHERE IN TABLE TO PLACE PATTERN SET
    LD      IY, $1A                      ; 26 LETTERS
LOAD_NUMBERS_TO_VRAM_02:
    LD      BC, $FFE0
    ADD     HL, BC
    LD      DE, $FC
    LD      IY, 3
    CALL    SEND_PATTERNS_TO_VRAM
    LD      BC, $4E
    ADD     HL, BC
    LD      DE, $FF
    LD      IY, 1
SEND_PATTERNS_TO_VRAM:
    JP      PUT_VRAM
LOAD_COLOR_TABLE_TO_VRAM:
    LD      HL, COLOR_TABLE
    LD      DE, $00
    LD      IY, $20
    LD      A, 4                         ; 4 = COLOR TABLE
    JP      PUT_VRAM
LOAD_SPRITES_TO_VRAM:
    LD      HL, SPRITE_PATTERNS
    LD      DE, $00
    LD      IY, $D8
    LD      A, 01                        ; 1 = SPRITE TABLE
    JP      PUT_VRAM                 ; JUMP INSTEAD OF CALL WILL RETURN OUT OF SUBROUTINE.  USE CALL TO PROCEED TO THE NEXT STATEMENT.
PATTERN_INDEX_TABLE:
    DB $01
    DB $00
    DW BLANK_PATTERN              ; FIRST CHARACTER IS BLANK AND COLOR 0, OTHERWISE AREAS ON THE SCREEN THAT USE A SPACE WILL HAVE A PATTERN, COLOR OR BOTH.
    DB $0D                               ; NUMBER OF PATTERNS
    DB $08                               ; WHERE IN TABLE TO PLACE PATTERN SET
    DW PATTERN_SET_01            ; PATTERN SET
    DB $02
    DB $18
    DW PATTERN_SET_02
    DB $02                               ; EXAMPLE NUMBER OF PATTERNS FOR THIS ROUTINE.  MUST BE MULTIPLES OF 8 FOR MODE 1.
    DB $20                               ; EXAMPLE LOCATION IN PATTERN TABLE FOR THIS ROUTINE.
    DW PATTERN_SET_03
    DB $0A
    DB $28
    DW PATTERN_SET_04
    DB $02
    DB $38
    DW PATTERN_SET_05
    DB $02
    DB $40
    DW PATTERN_SET_06
    DB $1B
    DB $48
    DW PATTERN_SET_07
    DB $08
    DB $70
    DW PATTERN_SET_08
    DB $00                                   ; END WITH $00 TO IDENTIFY THE END OF THE TABLE.
COLOR_TABLE:                             ; EXAMPLE COLOR TABLE FOR THIS ROUTINE.  1 BYTE FOR EVERY 8 TILES WHEN USING MODE 1.
    DB 000,080,080,176,033,096,096,208   ; 1ST BYTE MUST BE ZERO OR ANY AREA ON SCREEN THAT USES A SPACE WILL HAVE A PATTERN, COLOR OR BOTH.
    DB 208,018,018,018,018,018,176,176
    DB 033,033,033,033,033,033,033,033
    DB 033,033,033,241,241,241,241,241
O3 Cozmos
Edited by Captain Cozmos
