Microjak Posted November 21, 2023 Share Posted November 21, 2023 (edited) After rediscovering the Atari 2600 thanks to the 2600+ I am considering picking up an original PAL woody but would also like to collect some of the newer homebrews.Are they available anywhere in the UK or would I have to import them (carts) with huge postage costs? and would they be available in PAL format? I would probably consider a harmony cart but would I be able to buy/download new homebrew roms to load onto it? Cheers Edited November 21, 2023 by Microjak Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 21, 2023 Share Posted November 21, 2023 I lost contact with the one guy who wanted to publish normal sized homebrew in Europe. So, only have Dragon Chalice available from the states that is NTSC but you can switch it to PAL60 in-game. 1 Quote Link to comment Share on other sites More sharing options...
351cougar Posted November 21, 2023 Share Posted November 21, 2023 if you want actual carts you are stuck with the crazy fees and tariffs moving between wherever they originate and you. pal or not is usually easily found in dev threads here or other atari sites, or on actual dev release sites. Champgames for one. 1 Quote Link to comment Share on other sites More sharing options...
juansolo Posted November 22, 2023 Share Posted November 22, 2023 If it's homebrew you're after you'll ideally want an NTSC console or a RGB modded PAL one as that essentially makes it multi-standard. Importing is really the only option for physical releases and quite frankly that's now so prohibitively expensive ROMs make way more sense. Champ and Muddyvision sell their games as ROMs, hopefully others will follow. Collecting physicals in the UK will die out soon enough the way things are going. If you've not already got an existing collection, and you've got a TV that supports it, I'd look to getting an NTSC console. It's the path of least resistance when it comes to compatibility. If you get a 2600 slap a Harmony cart in it, if you get a 7800 Get a GameDrive. The latter also supports 2600 games on the 7800. 1 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted November 22, 2023 Share Posted November 22, 2023 11 hours ago, Microjak said: After rediscovering the Atari 2600 thanks to the 2600+ I am considering picking up an original PAL woody but would also like to collect some of the newer homebrews.Are they available anywhere in the UK or would I have to import them (carts) with huge postage costs? and would they be available in PAL format? I would probably consider a harmony cart but would I be able to buy/download new homebrew roms to load onto it? Cheers Most releases of WIP, demo and public full version of hombrew ROMs are uploaded to the PlusStore which is maintain by @Prizrak. So with a PlusCart you are mostly up to date on the homebrew scene without the hassle of searching the web for new ROMs and fumbling around with SD-Cards. 1 Quote Link to comment Share on other sites More sharing options...
Microjak Posted November 26, 2023 Author Share Posted November 26, 2023 Thanks everyone for the very informative replies,I certainly have a few things to consider.The harmony cart with roms is probably my best route or move to the USA ! thanks again. Quote Link to comment Share on other sites More sharing options...
