F.G. Kaal Posted November 25, 2023 Share Posted November 25, 2023 Hi all, There is a new version of Du2k v3.0 available here hexbus.com/ti99geek/Projects/du2k/du2k.html and here. Du2k now allows the creation of 8 partitions for an IDE (master or slave) device. The maximum number of IDE devices is still 8 (IDE1 - IDE8) but now you don't need a slave device if you need more than 4 partitions or you can have i.e. 6 partitions on a master IDE device and 2 partitions on a slave IDE device. The download also contains a Du2kv30.bin file for use with the FlashRom99 and FinalGrom99 modules. Fred du2k_v30.zip 4 10 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 25, 2023 Share Posted November 25, 2023 To the UberGROM gurus: can this be easily integrated into the Extended BASIC 2.7 Suite? Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted November 25, 2023 Share Posted November 25, 2023 3 hours ago, OLD CS1 said: To the UberGROM gurus: can this be easily integrated into the Extended BASIC 2.7 Suite? I'll have to look at @Gazoo's code to see what can be done there, as he used a bit of a brute force approach to build it (this was done before the regular UberGROM programming tools were released). 3 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted November 25, 2023 Share Posted November 25, 2023 Where would one acquire the above-mentioned "Ubergrom tools"? 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 25, 2023 Share Posted November 25, 2023 4 hours ago, Ksarul said: I'll have to look at @Gazoo's code to see what can be done there, as he used a bit of a brute force approach to build it (this was done before the regular UberGROM programming tools were released). while you are at it dm2k is updated as well 3 Quote Link to comment Share on other sites More sharing options...
