Cisano Posted November 29, 2023 Share Posted November 29, 2023 (edited) Hi, someone knows what happen if I plug the module 1 NTSC on a PAL console? Does it work? And with which standard? Thanks. Edited November 29, 2023 by Cisano Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted November 29, 2023 Share Posted November 29, 2023 3 hours ago, Cisano said: Hi, someone knows what happen if I plug the module 1 NTSC on a PAL console? Does it work? And with which standard? Thanks. Module 1 will send NTSC-encoded composite video. The PAL RF modulator will place this on whatever frequency the PAL system uses (I think some use channel 3, others use something up in the 60's or 80's or something). It will add the audio subcarrier according to its PAL spec. So a PAL TV will fail to sync with it due to different timing requirements, but will have sound. If you manage to find the channel with an NTSC TV, it will have video but the audio will likely be missing or static. Quote Link to comment Share on other sites More sharing options...
Cisano Posted November 29, 2023 Author Share Posted November 29, 2023 (edited) Then, a big mess. Thanks. Edited November 29, 2023 by Cisano Quote Link to comment Share on other sites More sharing options...
Ruggers Customs Posted December 1, 2023 Share Posted December 1, 2023 On 11/29/2023 at 2:14 PM, ChildOfCv said: Module 1 will send NTSC-encoded composite video. The PAL RF modulator will place this on whatever frequency the PAL system uses (I think some use channel 3, others use something up in the 60's or 80's or something). It will add the audio subcarrier according to its PAL spec. So a PAL TV will fail to sync with it due to different timing requirements, but will have sound. If you manage to find the channel with an NTSC TV, it will have video but the audio will likely be missing or static. AV modding the PAL console would fix that right? (I'm just learning PAL stuff for repairs). Quote Link to comment Share on other sites More sharing options...
Ruggers Customs Posted December 1, 2023 Share Posted December 1, 2023 Nvm, I'm an idiot. Disregard previous comment. 😕 Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted December 3, 2023 Share Posted December 3, 2023 On 11/30/2023 at 11:50 PM, Ruggers Customs said: AV modding the PAL console would fix that right? (I'm just learning PAL stuff for repairs). Yeah the easiest thing to do is to make an edge connector to plug in to the Module 1 that provides power and ground (needs +12 and +5 I believe, I don't think it needs -5). The connector can then tap the composite output and the audio output. Composite should have a capacitor and 68 ohm resistor to couple with the TV. Of course the result is NTSC composite video Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted December 4, 2023 Share Posted December 4, 2023 On 12/2/2023 at 5:59 PM, ChildOfCv said: Yeah the easiest thing to do is to make an edge connector to plug in to the Module 1 that provides power and ground (needs +12 and +5 I believe, I don't think it needs -5). The connector can then tap the composite output and the audio output. Composite should have a capacitor and 68 ohm resistor to couple with the TV. Of course the result is NTSC composite video Also, the module uses the crystal oscillator within the CV console and doesn't have one within the module itself. So one would also need to provide an appropriate clock signal to the module through the connector. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted December 5, 2023 Share Posted December 5, 2023 5 hours ago, Ikrananka said: Also, the module uses the crystal oscillator within the CV console and doesn't have one within the module itself. So one would also need to provide an appropriate clock signal to the module through the connector. Oh yeah that too. The PAL version has an onboard clock due to its different clock speed. You could fill in the blank components of the oscillator circuit and move a jumper to skip that step on the interface board though. Quote Link to comment Share on other sites More sharing options...
